Sony XR-77A80J - 2 red blinks?
  • Darksabre
    • Nov 2016
    • 13
    Originally posted by Diah
    then start with power + other key like VOL-, try any other till you have the green LEDa
    There are no volume controls on the TV either. Only button is power. Should I use the remote control's volume +/- buttons in conjunction with the power?
    • Diah
      • Feb 2013
      • 6763
      how it come TV sold with out this control.. LOL, then never being sold.. what did user do if RC defect ???
      so the Power you are talking on are located under the front LED indication ?? if yes this is Joystick can move left right back front ..LOL
      • Darksabre
        • Nov 2016
        • 13
        That's how Sony does it on their newer units. If you lose the remote control, you can do limited control with the single power button by using short and long presses. There's no volume buttons, and the button is a single press. The button mounted to the main PCB is a standard 90-degree momentary pushbutton.
        • Diah
          • Feb 2013
          • 6763
          however i have doubt , because this android so how to call the recovery... !!
          then try to press is and keep it pressed , while you plug tv in wall... don't release it until white change green doesn't matter how long you pressing
          • BoardHoarder
            Help With Troubleshooting Sony OLED XR-55A80L 4 Red Blinks
            by BoardHoarder
            Fairly new at diagnosing OLED products, but I was able to make a few checks so far. Friend had this TV in a room where it wasn't often used and had a notification on the screen for a software update from Sony for a little while that he never installed. Went to turn on the set, got a white light and then a loud "click" and 4 red blinks. I tried to unplug the set and do a hard reset, but I never get the green light to come on no matter how long I hold the button. If I remove the LARGER of the 2 LVDS cables from the TCON I can get the TV to turn on with a black screen and pressing the single...
            04-01-2026, 12:27 PM
          • matwan
            Sony XR-55X90J 5 blinks
            by matwan
            I have problem with SONY 55X90J. After several check status is as below;
            1. Running power board as stand alone:
            TCON_12V =~ 12.6V
            EVDD V On Max 24V= 19V.
            2.
            Running power board with TCON as stand alone:
            Effect as below, attched.
            3. When bottom LVDS cable is disconnected no blinks, but of course no TCON 12V and EVDD.
            "I'm almost sure it's a defective panel, but maybe someone has encountered a similar issue on their screen.
            Best regards....
            09-28-2025, 04:26 AM
          • GoodCapDude
            Sony XBR-75X940E intermittent 6 blinks error code
            by GoodCapDude
            Hi everyone. First post on Badcaps!
            I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot....
            09-20-2025, 06:07 AM
          • ggil44
            Sony XBR-75X850C 6 blinks
            by ggil44
            Hi, Have a friend that has a Sony XBR-75X850C, 2015 that just quit on him. Now when he turns it on, it begins the startup process but when the backlight comes on for a second, it shuts down and goes to a 6 blink code. He said it just happened all of the sudden without any prior indication of a problem. I suspect it is a back light issue but would like your opinion before I give him the bad news. Thanks for the help. Regards,
            06-09-2026, 10:20 AM
          • mmbaba
            Seeking help with Sony XR-77A80J
            by mmbaba
            TL/DR - My XR-77A80J stopped showing any image about a month ago. I’ve swapped out the PSU, T-CONN and Main boards and cannot get it to show anything. I’m looking for a method to verify if the panel is still ok - if so, I’ll continue troubleshooting, otherwise - it’s heading for recycling.
            Details - About a month ago, the TV failed to startup and show any image at all, it provided a 4-red-LED error state. There was no physical damage, it’s been hung to my wall for the past 4 years. This was during a period where some builders were tripping a separate circuit in the house...
            05-09-2026, 10:49 AM
