Sony XR-77A80J - 2 red blinks?
  • Darksabre
    • Nov 2016
    • 13
    Distinguished Badcaps members (and otherwise ),
    I've got a 5 year old Sony 77A80J with low hours that just turned off randomly one day and the standby LED flashes twice, pauses, then flashes twice, pause (...ad nauseum). I disconnected the power and waited a few minutes, plugged it back in, and was able to continue using the TV for a few months. Fast-forward to today, and now the TV will only stay on for about 1-2 minutes before shutting itself off. As far as I can tell, the picture is still great, it just only stays on for a minute or two.
    I was able to get into diagnostics mode and get a picture before it shut off. I've seen a lot of threads about 4 blinks and 5 blinks, but I have yet to find one about 2 blinks. I'm guessing a component is heating up, pulling too much current, and triggering an overcurrent failsafe of some kind, but not sure. Any ideas where to start looking? Easiest to just throw a new power supply board at it?
    Thanks for your time!
  • Diah
    • Feb 2013
    • 6763
    Bad soldering or BGA, start with PSu re solder all big transformer
    • ikmpch
      • Jul 2020
      • 23
      • repair non functional appliances
      Hi, Two red blinks generally mean issue with power supply board for the SONY TVs
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4889
        • Italy - Milan
        Probably an interference by the PSB due to some bad filter or even bad mains wall socket (outlet)
          Back Again?
          • 32841
          I'd recommend checking PSU voltages with a DMM and seeing if any are out of tolerance or if the voltages drop/change over time.
          For service manual, bios, schematic, boardview (board view), datasheet, cad - use our search.
          Subscribe to support us. It only takes 1 minute: https://www.badcaps.net/settings/subscriptions
          • Darksabre
            • Nov 2016
            • 13
            Yep, that is a good plan. I'm hoping to pull the board soon.
            Is there a guide out there on this PSU board for which pins I need to jumper to trick it into activating the 12V and 21V bus?
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4889
              • Italy - Milan
              post a photo of the table printed near connector of P. board that goes to main board with cable
                Back Again?
                • 32841
                For now, I would test with the main board connected, since you know it works for a minute or two. Just have to cycle it on and off a bit, but try to see what voltages have done before and after fault and if any start wavering before the fault.
                • Darksabre
                  • Nov 2016
                  • 13
                  here is the silkscreen pin layout
                  • Darksabre
                    • Nov 2016
                    • 13
                    Bad news. Finally got it opened up to test, and it goes straight to 2 red flashes now. Won’t boot up normally at all. Seems that whatever went bad is “all bad” now.
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4889
                      • Italy - Milan
                      Oh but this is an OLED , i promised i would never participated more to an oled discussion, but now i'm in, measure the STBY, if it's no more than 5v you only need a jumper betwen this and the 3 signals ended with ""_ON", if it's above 5v you need a 4,xx v zener diode and a 2,2-10k ohm resistor
                      Bad news. Finally..........
                      actually this is the best situation, be quiet..
                      MESSAGE TO STAFF: using a tablet or cellphone in landscape in the editor it is impossible to show the quoting command until you rotate in portrait..
                      as usual landscape mode is the more loser one..
                      • Diah
                        • Feb 2013
                        • 6763
                        Disconnect only the socket on the T-CON with name EVDD, turn on the TV icheck if come on, ( screen stay black ) yours sign its on the Optic Audio Port on Mainboards will lit red color. report back
                        • Darksabre
                          • Nov 2016
                          • 13
                          Thanks Diah.
                          Unplugging the EVDD and turning on the TV, the red optic audio port turned on.
                          After about 2 minutes, I heard a click from the PSB, the red optic audio port light turned off, and the standby light is flashing red twice.
                          • Diah
                            • Feb 2013
                            • 6763
                            Thanks Diah.
                            its ok, because no signal, the TV went to STBY, if you feed it with HDMI ARC Port signal you will be able to hear the sound,,, this is not what we want,,at
                            keep the EVDD disconnected, from T-CON side, TV plugged out from wall socket... if you have Joystick on the push it and bring it down, keep it in this position then plug tv at wall back,, only when the front LED change from white to green cound 1-5 then release the Joystick... TV will have hard reset keep it do what it should, it could be reboot 2-3 time , the time no more reboot and you can hear the first install melody, plug EVDD back to T-CON and watch the screen it will remain on... notice at first or second reboot you will hear the melody,,, so you need to wait until the melody remain on long time
                            • Darksabre
                              • Nov 2016
                              • 13
                              Hi Diah,
                              I do have the remote control. If I hold the power button down while plugging in the power to the tv, the status light turns white, then red, then turns off. About 5 seconds later, the status light turns white again, but this time the red led is also flashing twice. I kept the power button held down this entire time, but it never stopped this pattern.
                              here is a video of the led from start to finish.
                              https://youtube.com/shorts/cM5QpAw37..._Ex1_IwsLNAoHE
                              anything else I can try?
                              • Diah
                                • Feb 2013
                                • 6763
                                you didn't follow any things as i wrote,, i never wrote any about remote control... just keep the EVDD socket disconnected , and do hard reset in blind way hard reset as i described before.
                                please ready Sony OLED Threat i joined and there i did wrote many time how to.
                                • Darksabre
                                  • Nov 2016
                                  • 13
                                  You said use the joystick. Please let me know what joystick means. A joystick is usually a remote controller of some sort, although usually reserved for game controllers or other industrial machinery
                                  I’m assuming this is just a translation communication issue.
                                  I followed the hard reset steps from Sony by holding the physical power button down while plugging in the power cable, but it does the same thing as described above. The led never turns green. I tried it with the remote and with the physical power button on the tv. No difference.
                                  I will try to find the reset thread you mentioned.
                                  • Diah
                                    • Feb 2013
                                    • 6763
                                    LOL
                                    the Joystick if you have on the TV to control it, VOL+ VOL- etc, not RC, if there push it and back rest read again my post again,,, in Joystick it may power and Vol- together pressed and keep pressed then TV plug it back in wall socket, you may try other to push together till you have the white led changed to Green
                                    what sony wrote wasnt hard reset its cold start...... try what i worte
                                    • Darksabre
                                      • Nov 2016
                                      • 13
                                      Sony XR-77A80J's dont have a directional Joystick on the TV panel. The only button they have is a single momentary power button.
                                      • Diah
                                        • Feb 2013
                                        • 6763
                                        then start with power + other key like VOL-, try any other till you have the green LEDa
                                        • BoardHoarder
                                          Help With Troubleshooting Sony OLED XR-55A80L 4 Red Blinks
                                          by BoardHoarder
                                          Fairly new at diagnosing OLED products, but I was able to make a few checks so far. Friend had this TV in a room where it wasn't often used and had a notification on the screen for a software update from Sony for a little while that he never installed. Went to turn on the set, got a white light and then a loud "click" and 4 red blinks. I tried to unplug the set and do a hard reset, but I never get the green light to come on no matter how long I hold the button. If I remove the LARGER of the 2 LVDS cables from the TCON I can get the TV to turn on with a black screen and pressing the single...
                                          04-01-2026, 12:27 PM
                                        • matwan
                                          Sony XR-55X90J 5 blinks
                                          by matwan
                                          I have problem with SONY 55X90J. After several check status is as below;
                                          1. Running power board as stand alone:
                                          TCON_12V =~ 12.6V
                                          EVDD V On Max 24V= 19V.
                                          2.
                                          Running power board with TCON as stand alone:
                                          Effect as below, attched.
                                          3. When bottom LVDS cable is disconnected no blinks, but of course no TCON 12V and EVDD.
                                          "I'm almost sure it's a defective panel, but maybe someone has encountered a similar issue on their screen.
                                          Best regards....
                                          09-28-2025, 04:26 AM
                                        • GoodCapDude
                                          Sony XBR-75X940E intermittent 6 blinks error code
                                          by GoodCapDude
                                          Hi everyone. First post on Badcaps!
                                          I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot....
                                          09-20-2025, 06:07 AM
                                        • ggil44
                                          Sony XBR-75X850C 6 blinks
                                          by ggil44
                                          Hi, Have a friend that has a Sony XBR-75X850C, 2015 that just quit on him. Now when he turns it on, it begins the startup process but when the backlight comes on for a second, it shuts down and goes to a 6 blink code. He said it just happened all of the sudden without any prior indication of a problem. I suspect it is a back light issue but would like your opinion before I give him the bad news. Thanks for the help. Regards,
                                          06-09-2026, 10:20 AM
                                        • mmbaba
                                          Seeking help with Sony XR-77A80J
                                          by mmbaba
                                          TL/DR - My XR-77A80J stopped showing any image about a month ago. I’ve swapped out the PSU, T-CONN and Main boards and cannot get it to show anything. I’m looking for a method to verify if the panel is still ok - if so, I’ll continue troubleshooting, otherwise - it’s heading for recycling.
                                          Details - About a month ago, the TV failed to startup and show any image at all, it provided a 4-red-LED error state. There was no physical damage, it’s been hung to my wall for the past 4 years. This was during a period where some builders were tripping a separate circuit in the house...
                                          05-09-2026, 10:49 AM
