42PJ350 clicking noise
  • Jim1303
    • 3
    • The Netherlands
    I know that there are multiple treads on this subject but none of them seem to be exactly like mine, as far as I understand them (I am no technical guy...) So here is the problem, whenever I power it on, the TV shows nothing on the screen whatsoever (nothing at all!), it clicks twice, gives a kind of buzzing sound, clicks once and then repeats this cycle. The threads that I have read, mention buying all kinds of new boards or parts....isnt it better to just buy a new TV, I mean this one is from 2010...
    So I am open to any suggestions on how to fix this one...
    Cheers!
    Jim
    Re: 42PJ350 clicking noise
    First please post pictures of the parts inside the set... it is important they are of your set because manufacturers can frequently change the design.
    Do you have a digital multimeter available?
    • Jim1303
      • 3
      • The Netherlands
      Hi Tom,
      Thanks for getting back to me mate! I have attached the pictures as you asked. Its one picture of the entire back of the TV and three pictures of the left, middle and right part. I hope they are good enough to work with. As for the meter, as we speak I'm trying to get my hands on one. As soon as I have one I'll get back to you. In the mean time, can you tell anything just from looking at the pictures? Many thanks!
      Jim
      • NConstantinou
        HP Z840 workstation power supply clicking noise
        by NConstantinou
        No power
        i have the above ps which i change the TOP258eg ic.
        Now i have power but is clicking and voltages are flutuating. I change all capacitors, i test all mosfets and all are ok.
        i am wondering what is the value of R901! I am getting 0.5Ohms. Is that correct!
        the colours look like R,R,W or silver,G Bl.
        Thanks...
        12-25-2024, 02:24 AM
      • tony359
        by tony359
        11-28-2023, 05:18 AM
      • MegaZAC
        Onkyo TX-SR805 noise in one channel
        by MegaZAC
        Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
        Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
        There's some logic behind it. As soon as I select an input I get only left...
        04-23-2025, 10:09 PM
      • B0r1s
        Samsung UE49KS7000SXXH - fast clicking sound in standby mode
        by B0r1s
        PSU - BN44-00878A
        Symptoms:
        The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
        A weak clicking sound was coming from the transformer.
        Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
        Progress:
        After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
        01-17-2023, 04:58 PM
      • Sisko
        Onkyo-593 No power and now clicking sound
        by Sisko
        Hi all!!
        Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
        10-03-2025, 02:18 PM
