Samsung UN46EH6000 LED ERROR Codes
  • Michale32086
    • Nov 2011
    • 1453
    Re: Samsung UN46EH6000 LED ERROR Codes
    OK I thought I would try something else...
    When I put 20.8V at the "front" of the LED strip, I get 6.2V at the midpoint of a whole strip..
    When I put 20.8V at the "front" of the LED strip that has been pulled from the array, I get 16.8V at the other end..
    Not sure if that means anything, but.....
    • Michale32086
      • Nov 2011
      • 1453
      Originally posted by budm
      Those plastic LENS for the LEDs are snap in place, you should be able to remove them so you can get to the LED's to test each LED.
      Similar to this one:
      https://www.badcaps.net/forum/showpo...3&postcount=59
      That's awesome! I'll try that now...
      Thanx
      • CapLeaker
        Leaking Member
        • 8087
        I guess now you are down to test each individual LED and find the bad ones.
        • Michale32086
          • Nov 2011
          • 1453
          Unfortunately, my little redneck battery tester thingy is not very reliable... I am going to dig around my shop tomorrow and see if I can find a 3V wall wart to use..
          Until then I am going to operate under the assumption that I, at the very least, have to replace the one right side half-strip...
          Thanx for all the help and replies.. Even if this doesn't pan out to fixing the TV, I learned a helluva lot..
          And THAT'S a win, no matter how ya slice it...
          • Michale32086
            • Nov 2011
            • 1453
            DING!!! DING!!!! DING!!!!
            I think I found the problem.
            A big black burn in the middle of one of the LEDs on the right side half-strip that didn't function..
            So, we now why THAT one doesn't work..
            Like I said above, I am going to operate under the assumption that the left side strips are good, I am just missing something on powering them up...
            Replacing one half-strip is going to run me about $25.. Worth it if I only have to replace one..
            Not so much if I have to replace 7...
            Anyways, thanx again... I'll follow up when the replacement comes in..
            EDIT: Is there a trick to snapping these LED covers back into place??
              Great news, how are the other LEDs, any of them showing brown tint for the heat?
              It is so sad that the LED is supposed to be an improvement from CCFL which required high voltage to operate, but they cut down on the LED design by not using proper heat management, so many of these TV with LED backlights are failing a lot.
              • Shinju
                • Mar 2014
                • 1239
                ^ one would think, I believe the huge push for manufactors to go LED is environment preservation CCFL and EEFL are pretty toxic.
                Wonder if those LED shields are causing them to die premature due to best capture?
                • CapLeaker
                  Leaking Member
                  • 8087
                  sweet! Good going!
                    CCFL and EEFL bulbs contain a SMALL amount of mercury. About 0.02g per TV. Eating three tuna sandwiches releases more mercury into the environment than a 32" TV contained.
                    Actually LED TVs are better environmentally because they require less coal power to operate... more than any mercury saved from the bulbs!
                    I am convinced far more damage is done to the environment by dumping ~15kg of electronics, metal and plastic, than a few milligrams of mercury ever would, or even considering the extra power used by the display.
                    • Shinju
                      • Mar 2014
                      • 1239
                      True, but here in the states things we do never really make sense, rest of the world thinks we are crazy!
                      You are right about the power consumption LED/CCFL.
                      Give me a plasma any day of the week! If I am going to drive a car its going to be a flashy gas guzzling machine of beauty
                      • Michale32086
                        • Nov 2011
                        • 1453
                        One thing that this project (and the Westinghouse project before) taught me was that breaking a TV down to it's bare components wasn't nearly the horror I thought it was going to be..
                        But then it hit me today..
                        These were LED TVs. My only experience before was with LCD laptop displays and those were a nightmare..
                        How does breakdown of an LCD compare to the breakdown of an LED??
                        Anyone have any firsthand experience??
                          It's roughly the same.
                          The only real difference is there are fluro bulbs in the panel instead - these are quite thin and can potentially be damaged if you are careless.
                          • Michale32086
                            • Nov 2011
                            • 1453
                            I seem to remember from the LCD laptop display that there were like a half dozen different mylar sheets. That's what frustrated me so much about that...
                            In this latest project, there was the glass display, a single mylar sheet and a think white plastic diffuser and that was it..
                            Well, I'll tackle an LCD next and see
                            Thanx again...
                              It's worth noting there is no difference between "LED" TVs and LCD TVs, they both have LCD panels, but one has LED backlights and other has CCFL backlights.
                              Picture wise, virtually no difference (maybe slightly brighter), energy saving is better.
                              • johnboy1313
                                • Nov 2012
                                • 1959
                                Originally posted by Michale32086
                                OK, found a wall wart that did not blow anything up... It's rated at 12v, but the meter says it was putting out 16v..
                                Referring to the attached pic..
                                I touched the 16v to the points indicated by the boxes...
                                On the Green points, all the LEDs to the RIGHT of the box lit up fine.. The LEDs to the LEFT of the box did not light up...
                                Except for the one red box on the right. No LEDs lit up at all...
                                Touching the 16v on all the boxes on the left.. No LEDs lit up...
                                Apparently, the one strip on the right side is bad.. Just to confirm, I pulled that entire strip off and tested them individually. Still no joy..
                                But I find it hard to believe that all the strips on the left are bad..
                                The reason the left strings don't work when tested is because the connector on the end that accepts the right string of LEDs acts as an open circuit. You need to short the pins in that connector or test both strings together with 42V.
                                • Michale32086
                                  • Nov 2011
                                  • 1453
                                  Thanx, JB. That's good to know...
                                  That simply re-enforces my hope that, once the replacement comes in, I should be able to get this puppy up and running..
                                  Thanx again..
                                  • Michale32086
                                    • Nov 2011
                                    • 1453
                                    Well, unfortunately a sad ending.I got in the new LED strip.. I tore down the TV again and installed the strip.. When I went to put on the actual picture glass, I had torn one of the cellophane connectors completely off the glass..
                                    I didn't handle that very well and ended up sweeping a million glass shards off the floor..
                                    So, this one was a bust.. But, at least I have a working set of LEDs... At least I think they are working.. The TV might have been slammed down on the counter a few times.. things are a bit fuzzy...
                                    Anyways, thanx for the assists.. At least I learned alot..
                                      Oh dear, that sucks. LCD panels are very delicate, so you must be careful to avoid damaging the tab bonds.
                                      • Michale32086
                                        • Nov 2011
                                        • 1453
                                        Yea, lesson learned.. I thought I was careful with them, but I had a houseful of grandkids... So it's likely I wasn't concentrating enough..
                                        Ah well, like I said. Lesson learned..
                                        Hopefully, it's like leaving the boat plug out of your boat when you put it in the water..
                                        It's a mistake that only happens once...
                                          I used 46" SAMSUNG LED backlights with broken screen as the light source in my garage, it is also good for light table.
                                          • AK_777
                                            Sony KD-65A1 Repair – 4 Red Blinks Error
                                            by AK_777
                                            Hi everyone!
                                            I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
                                            Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
                                            02-20-2025, 04:15 PM
                                          • Sus256
                                            HISENSE 65E7KQ PRO - no boot
                                            by Sus256
                                            Hi all!
                                            HISENSE 65E7KQ PRO
                                            RSAG7.820.13512 - chassis
                                            MT9618BAATAB - cpu
                                            RSAG7.820.12059 - power
                                            HD650Y3U77 - panel
                                            KLM8G1GETF - emmc
                                            The TV does not turn on, the standby indicator is on. All voltages are present.
                                            Emms is dead. Not readable, not detected.
                                            Replaced emmc.
                                            But with another dump there is no launch
                                            Terminal log
                                            UART
                                            AC_ON
                                            RPMB key is not yet programmed
                                            HASH1_VERSION=0x00000000 64bit
                                            E-B
                                            FDE enabled
                                            layout pattern onebin by SAR7,0...
                                            06-01-2025, 02:11 AM
                                          • brithepi2k
                                            Samsung UE75TU7020k No picture, Standby blinks 2 times
                                            by brithepi2k
                                            My Samsung UE75TU7020k lights up fine when one of the ribbon cables are disconnected from the main board, lights stay on but not getting half a picture, I do the same with the other ribbon and put the other one in and lights stay on but not getting half a picture. The standby light flashes 2 times then reboots then it then tries to come back on again and just keeps looping until I take either one of the ribbon tables out (doesn’t matter which one I take out it stays lit when either one is out). I’ve tested the backlights but all working with none shorting out, I’ve replaced the main board...
                                            04-23-2025, 10:05 AM
                                          • Caimano
                                            hp Pavilion 14 CE-1XXX 5 fast 3 slow blinks or cmos checksum error if restarted immediately after shutdown or suspend
                                            by Caimano
                                            MB G7AD-2G DAG7ADMB8D0 REV D
                                            Processor i5 8265U
                                            AFAIK schematics or boardview are not available for this MB, but I used a similar board as a reference (G7AL-2G)
                                            Laptop came in not booting with caps lock blinking 3 fast- 2 slow indicating RAM error. Charging works fine. Found bad soldering on the only ram socket present (2 outer left pins and 2 outer right pins).
                                            Once soldered the laptop started fine and I was able to install Windows 11, upgrade BIOS to version F30 from Windows without a problem, BUT I found a strange and annoying...
                                            02-06-2024, 10:14 AM
                                          • Grunder
                                            Samsung UA55NU7100 2 blinks then reboots
                                            by Grunder
                                            Hi please some assistance with my Samsung UA55NU7100 that is stuck in reboot.
                                            I've read the post by Itelite on a Samsung UA65NU6900 with the same problem but this main board is different and doesn't have the 25v VGH voltage which was the problem that he had.
                                            There is no legend indicating voltages on the socket/ cable going to the main board just a link marked 11.80 volts. This voltage reads 12.71v. Pins 3 to 9 also 12.71v. Pins 2,6,8,10,11 & 12 all 0.0v. Pin 1 fluctuates 3.01 to 0.0 volts and pin 4 fluctuates 3.25 to 0.0 volts.
                                            The cpu gets very hot after 10...
                                            01-26-2024, 07:43 AM
