Samsung UN46EH6000 LED ERROR Codes
Re: Samsung UN46EH6000 LED ERROR Codes
I know this is old post, but still, if any one finds it like i did, i found the issue (not the solution yet).
I have a UE48H6200 with the same issue, sound no image no backlight, Cause? Short in the rigth panel board (i dont know the name, the one between the tcon and the panel).
If i connect one flat cable from the tcon to the panel at a time i get backilight but no image, when i connect both, no backlight at all.
Measuring the componentes i found on the right board some ceramic capacitors shorted, gnd to 2 lines in each buffer line.
Dont know if its one buffer shorted or a cap going short.
Probably will try to inject 1V to both sides of one of the caps and see if anything heats up, but im inclined to be a buffer line gone bad...
So sad, great tv, what a waste. Ill post if i find out any solution other then new panel.
Cheers.Comment
One shorted mlcc cap can make the ones next to it read short too, maybe take the first one in the row that reads short out and check it out of circuit, recheck the others see if they still read short, lots of times it's only one bad cap, video example there, I've seen others too, this is the one I found in English: https://www.youtube.com/watch?v=jLd6QO7Z7m4Last edited by nomoresonys; 12-27-2019, 07:45 AM.Comment
by CurtissimoHi everyone.
I have a HP Elitebook 850 G8.
Serial: 5CG2324XM0
ProdID 6L8D5EC#ABA
It has a Winbond W25Q256JVEN Chip.
I need to remove BIOS Password.
I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
Attached my dump.
I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
What I did:...-
Channel: BIOS Requests ONLY!
by NairolfHello,
I have a Samsung DM32D display.
When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
Here’s what I have tried so far:- Disconnected the cable between the mainboard and the power supply → the backlight turns on.
- Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
- Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
From these tests, I suspect the problem might be on the mainboard. Could anyone...3 Photos08-24-2025, 03:47 AM -
by peterwangSamsung NP750QGK-KG3US BIOS program error seeking help
PCB:BA41-03025A BA92-25486B
I opened the Modular Flash Image Tool-v16.50.00.1120 software and encountered the following error message. I am seeking help.
by AK_777Hi everyone!
I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and... -
by Sus256Hi all!
HISENSE 65E7KQ PRO
RSAG7.820.13512 - chassis
MT9618BAATAB - cpu
RSAG7.820.12059 - power
HD650Y3U77 - panel
KLM8G1GETF - emmc
The TV does not turn on, the standby indicator is on. All voltages are present.
Emms is dead. Not readable, not detected.
Replaced emmc.
But with another dump there is no launch
Terminal log
UART
AC_ON
RPMB key is not yet programmed
HASH1_VERSION=0x00000000 64bit
E-B
FDE enabled
layout pattern onebin by SAR7,0... - Loading...
