Why the ac driving of pixels is a problem with temperature? i do not understand, but anyway orange90 said correctly how can a cof be working and not working together? isnt the black the more stable color? isnt colors driving from full bright Avdd/0 to less bright vcom? where vcom is at middle to 0-->avdd, grey is half avdd-com and half vcom i.e. (avdd-vcom)/2 and vcom/2...... in moment T1 colors travels vcom --> avdd, in moment T2 vcom--->0 (negative travel)..... i read so...
Vizio M65Q6-J09 lines come and go
much likely you disconnect the LVDS from T-CON side, it should always done from MB side to stop T-CON 12VDC , any way if it play good don't bother it any more.I did this one time with a Pioneer that was not displaying an image. It had backlights on but no picture. I got a small spark when I applied the 12v to the tcon and the tv powered off. When I turned it back on I reconnected the LVDS and the tv was working perfectly and never had another issue.Comment
I replaced the main board a couple nights ago. I'm going to try and put this thing through the ringer this weekend and see if the problem manifests again or if it's fixed. The board was only $20 on eBay so I figured why not. I strongly feel that the board was the only logical cause of such a rare occurrence at this was, like literally 2 times in 100 hours of useComment
by DrvLikHellHello again! I have come back for some wisdom and hopefully for some guidance with this problem I'm having. The TV is a 4k 55" Sharp LC-55p6050u and the problem is every other line of the bottom 32 lines flickers out, comes mostly back, then flickers out again, and repeats this continually. The lines on the bottom right of the screen go out completely while the lines on the bottom left are affected so slightly that it's almost impossible to see it. There is a gradual gradient from appearing almost perfectly fine on the bottom left, to an obvious problem on the bottom right.
The... -
by jdawg99Hi All,
I need some help with this one please. I am attempting a repair on the backlight. TV turns on and flashes the LG logo so stripped it down and found one faulty LED. Replaced it and tested on an LED tester and the strip was good. Put it back onto the PSU and it lasted about 20 seconds before going out again. Same LED had blown. Changed it for another type of SMD one (same voltage) and it seemed fine. Put the TV back together but it was quite dim. Noticed it was in power save mode so turned it off and the screen was bright. Left it on for half an hour only to come back to the... -
by x_orange90_xI got this tv yesterday and it shows a screen full of colored vertical bars and horizontal lines that move, change, and dance around. When the set is powered on there is a slight buzz from the tcon. I removed one ribbon at a time and this was the result:
Right side connected, left side disconnected = half image on right (somewhat distorted, see photo attached) white screen on left. NO buzzing from TCON
Left side connected, right side disconnected = right side black, left side white with distorted horizontal lines near top of screen. Buzzing from TCON
I swapped... -
by spice_discI'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...1 Photo -
by JidisHi all,
I made a big-ass mess here of my father's beloved P602, and I'm trying to figure out if I should order a batch of overpriced ribbons or if I'd just be throwing more good money at the bad.
He woke up recently to a bunch of white bars going down the right side of the screen. From what I'd seen in these places, I figured the T-con board has gone out or has a bad connection. I took the back off and gently poked at the socketed ribbons and sure enough, got the image back. It was mainly the far left ribbon, and it would snap back to stripes if I let off the pressure.... - Loading...
