Vizio M65Q6-J09 lines come and go
  • x_orange90_x
    • May 2015
    • 834
    So I have this Vizio M-series that appeared fine when I first got it, then after leaving it on for a while I came back to a screen full of vertical bars of horizonal lines. I did the quick "panel test" by removing the right side ribbon; still lines on left. Removed the left side ribbon; still lines on right. Hmm, that's odd, didn't change at all. After messing with it for another 10 minutes or so, just unplugging and wiggling the ribbons and turning it off and back on, much to my surprise it looks perfect now.
    So I start wondering if it's thermal related and I leave the back cover off and use it for a few hours playing some games. No issues at all. Then I leave it on for several more hours the next day, no issues. I leave it on for 12hrs overnight. No issues. I put the cover back on and aim a heater at it for hours, NO ISSUES.
    So I assume the problem has somehow resolved because it's worked perfectly under all of these stress tests. Well, I knew deep down the issue HAD to still be there. Sure enough, last night I had it on for a few minutes, turned it off, turned it back on a few minutes later, and there they are; a full screen of lines again. They initially ghost and crawl up from the bottom and fill the screen. I played around with the ribbons again and the same thing happened with lines on each side with the other disconnected. I unplugged one of them completely and the screen went blank but the sound was still going. I plugged it back in but it remained black, and I powered off and on and it still was blank. I unplugged the power cable from the main board (that comes from the power supply), plugged it back in and the tv rebooted and came back on perfectly with no lines. I left it on for about 2hrs and ZERO issues.
    I really, really don't think this is a panel issue. I've never seen a panel intermittently work like this, and certainly not pass the kind of testing that I did. I'm 95% certain this is a main board issue, specifically the TCON section of it (integrated). Before I throw money at a new main board, I wanted to get some opinions.
    Back Again?
    • 32840
    This is most likely a panel issue just because of how you described it: "They initially ghost and crawl up from the bottom and fill the screen."
    If the lines were always present on the whole screen then maybe it could be an issue with the VGH or VGL voltages being out of tolerance sometimes, but even that is quite rare. The only thing that can cause this effect on part of the panel is the panel itself.
    The effect is analog in nature. You're seeing bright pixels bleed over into the column because they're not being deselected correctly. If you look at those columns, it's usually the case that a column lines up with bright text for instance. LCD panels work by loading pixel data in from the top or bottom, row by row. A brighter pixel usually needs a higher voltage. The VGH (or VON) voltage selects a row, and VGL (or VOFF) deselects it. Typically VGH will be around 20-30V, and VGL around -5V to -10V. If VGL is too high (too close to zero) then you may see the effect where the brightest pixels turn on every pixel in that same column, effectively "over-selecting" that column. But this would appear across the whole panel. To get only a localised effect like this, it has to be something at a certain point in the panel drive that is selecting too few rows or the signal breaking at a point causing this artefact.
    Some other advice on this forum regarding various 'mods' to try to improve issues with the panels by disconnecting drive signals on one half or the other of the panel. Look up LCD panel CKV short killer. Though this issue isn't always repairable. It being intermittent means it's more likely to be a bad COF flexi in my mind, this can be tricky to solve.
    For service manual, bios, schematic, boardview (board view), datasheet, cad - use our search.
    Subscribe to support us. It only takes 1 minute: https://www.badcaps.net/settings/subscriptions
    • x_orange90_x
      • May 2015
      • 834
      It just seems very odd that it can work for several hours per day, several days in a row, numerous on/off cycles, and be a short in the panel. I know what you're saying about how the issue presents, and it does seem like a classic symptom of a shorted panel. I just have hard time believing that is the problem when it works perfectly MORE often than not.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4889
        • Italy - Milan
        post a photo of the tcon, follow my sticky post... Haw are you at QFN chip soldering?
          Back Again?
          • 32840
          It might not be an actual short in the panel, it might be an open circuit connection driving the VGL to the panel for instance. That could be due to a failing COF solder joint or similar.
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8882
            what tom66 said or someone "washed" the TV screen.
            • x_orange90_x
              • May 2015
              • 834
              "Washed"?
              If it was a COF collection failure I should be able to manipulate them and reproduce SOMETHING, right? Maybe that'll be the next step, popping off the bezel and playing around with them. So you're saying it is a signal issue that is affecting the both sides of the screen rather than a single zone like how a broken COF would do? When I unplugged the power cable from the power supply to main board and plugged it back in, the tv rebooted and has been perfect since.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4889
                • Italy - Milan
                indeed since the fault is on both sides better to investigate on the tcon, there was a tipical issue on a couple of samsung series
                  Back Again?
                  • 32840
                  Originally posted by x_orange90_x
                  "Washed"?
                  I imagine that if you did get your hands on the COFs and applied pressure to each you may find the cause quickly enough.
                  • x_orange90_x
                    • May 2015
                    • 834
                    No tcon on this model. See attached image of the main board
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8882
                      Pretty sure there is another board on the bottom under that plastic in pic 2. Follow the 2 LVDS ribbon cables.
                      • x_orange90_x
                        • May 2015
                        • 834
                        There wouldn't be two LVDS cables to a tcon. The tcon is part of the main board on this model and those two ribbons go straight to the panel boards.
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4889
                          • Italy - Milan
                          i would try to resolder these two chips, starting from the Qfn one:
                            Back Again?
                            • 32840
                            This is a panel where the main board drives the LCD panel directly, there are at least 12 differential pairs heading to the panel, likely one for each COF. I doubt the chips near the connector are the issue because as I've stated previously, the only part of the TV that can cause a 'regional defect' like this is the panel itself.
                            • CapLeaker
                              Leaking Member
                              • Dec 2014
                              • 8882
                              Did you try cleaning these ribbon cables? Other than that, to me the fault is at the COF or inside the panel. Davi.p has a valid point, but I wouldn’t get my hopes up that fixes it. You could put some heat or freeze spray to it.
                              • Diah
                                • Feb 2013
                                • 6763
                                TV some time working fine and some time not never being Parts defect,
                                since you have AUO Panel, i would suggest disconnect the LVDS between MB and T-CON, and feed the T-CON F101 with 12V DC from PSU, leave the screen starting self diagnose RGB.. this will help too to reset the T-CON
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4889
                                  • Italy - Milan
                                  A bit of explanation, one of the two chips, i guess the QFN one, contains almost surely the clocks generator, a single faulty clock , like for example due to bad solder or bad chip, but since it is working and not i guess bad solder, determines a floating series of lines gates, where the gates due to capacitance of mosfets can asssume the state of "line selected", when i was working on the Samsung UE46B6000, i probed all clocks test points on tcon with volt meter and frequency meter and did noticed one of the clocks was erratic, totally out of values, there are some lines like STV (start vertical pulse) tipically at 100hz, and line clocks tipically at 15khz, if you manage to find on near resistors these signals, you can see, but with no testpoints its hard, this is a poor chinese board from innolux. all rubbish.. Bye..
                                  • x_orange90_x
                                    • May 2015
                                    • 834
                                    I'm eventually going to pull off the bottom bezel and check the cofs and panel ribbons.. but as of now I've left it on for over 36hrs straight without a single anomaly. Now, keep in mind when I first got this tv it appeared fine, but I left it on for a few hours and came back to the lines. So, time/temp HAD to have been a factor then, and would therefore STILL be a factor now. The question is WHY does it work for very long periods of time now without inside when it couldn't before?
                                    I can't imagine the cofs change temperature much during usage. I expect that once they reach a certain high temperature they remain there because they have no real passive or active cooling. The chips on the main board are a different story. They certainly do fluctuate temperature depending on load, content type, and utilization. This is why I've done all tests in various scenarios; No Signal screen, Home Screen, playing 4k content, playing HD content, paused.
                                    I did this one time with a Pioneer that was not displaying an image. It had backlights on but no picture. I got a small spark when I applied the 12v to the tcon and the tv powered off. When I turned it back on I reconnected the LVDS and the tv was working perfectly and never had another issue.
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4889
                                      • Italy - Milan
                                      36h is too long for a test, what a waste, you have only two variables, temperature and moisture, the temperature affects especially faulty connections, hope that you had moisture case
                                        Back Again?
                                        • 32840
                                        COFs do vary in temperature according to picture content. Content with high contrast will cause more power dissipation than content with muted tones. The basic problem is that the LC pixels are AC driven, which means that on each half-cycle their polarity is reversed. Mid grey is displayed with mid voltage so there is minimal change in bias. Whereas full white or full black will require pixels to slew between AVDD and 0V on each half-cycle. Additionally, if row data has high frequency content, e.g. a row-inversion pattern where every other row is a different voltage, then it will require source driver to work harder to drive the column.
                                        Whilst there is some advice online that darker images save power on LCD panels, I don't think that has ever been true.
                                        • DrvLikHell
                                          Sharp (Hisense) LC-55p6050u - Flashing/dimming row of pixels
                                          by DrvLikHell
                                          Hello again! I have come back for some wisdom and hopefully for some guidance with this problem I'm having. The TV is a 4k 55" Sharp LC-55p6050u and the problem is every other line of the bottom 32 lines flickers out, comes mostly back, then flickers out again, and repeats this continually. The lines on the bottom right of the screen go out completely while the lines on the bottom left are affected so slightly that it's almost impossible to see it. There is a gradual gradient from appearing almost perfectly fine on the bottom left, to an obvious problem on the bottom right.
                                          The...
                                          02-05-2025, 01:44 AM
                                        • jdawg99
                                          LG 47LA620V Same LED Failing Back Light Issues
                                          by jdawg99
                                          Hi All,
                                          I need some help with this one please. I am attempting a repair on the backlight. TV turns on and flashes the LG logo so stripped it down and found one faulty LED. Replaced it and tested on an LED tester and the strip was good. Put it back onto the PSU and it lasted about 20 seconds before going out again. Same LED had blown. Changed it for another type of SMD one (same voltage) and it seemed fine. Put the TV back together but it was quite dim. Noticed it was in power save mode so turned it off and the screen was bright. Left it on for half an hour only to come back to the...
                                          04-23-2023, 01:04 PM
                                        • x_orange90_x
                                          Vizio V585-J01 dancing lines and image doubling
                                          by x_orange90_x
                                          I got this tv yesterday and it shows a screen full of colored vertical bars and horizontal lines that move, change, and dance around. When the set is powered on there is a slight buzz from the tcon. I removed one ribbon at a time and this was the result:
                                          Right side connected, left side disconnected = half image on right (somewhat distorted, see photo attached) white screen on left. NO buzzing from TCON
                                          Left side connected, right side disconnected = right side black, left side white with distorted horizontal lines near top of screen. Buzzing from TCON
                                          I swapped...
                                          06-12-2024, 07:57 AM
                                        • spice_disc
                                          Vizio TV M50-C1 reboot cycle and static on screen
                                          by spice_disc
                                          I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                                          The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                                          09-08-2024, 02:37 PM
                                        • Jidis
                                          Need T-Con Advice (Vizio P602ui-B3)
                                          by Jidis
                                          I made a big-ass mess here of my father's beloved P602, and I'm trying to figure out if I should order a batch of overpriced ribbons or if I'd just be throwing more good money at the bad.
                                          He woke up recently to a bunch of white bars going down the right side of the screen. From what I'd seen in these places, I figured the T-con board has gone out or has a bad connection. I took the back off and gently poked at the socketed ribbons and sure enough, got the image back. It was mainly the far left ribbon, and it would snap back to stripes if I let off the pressure....
                                          09-22-2025, 05:10 PM
