lower part of picture shifted upwards LED TV
    This is a UN50EH5000 bought in april 2013. Already failed!. A big chunk of the lower picture is shifted upwards and the part that is missing due this this shift is replaced with a part from the top...
    There is only a tiny main board, and power supply and T-Con in this TV.
    Everything is shifted including the menu.
    Not sure if I am looking at a defective main board, T-con or even panel... My guess would be T-con.
    Any ideas?
    Re: lower part of picture shifted upwards LED TV
    Can you go into the user menu and see if changing the ASPECT RATIO makes a difference? (Sometimes "P.SIZE")
      I will try to do that when back home.
      I assume that if it changes with aspect ratio it's more likely to be the main board?
        Ok, I checked it, changing the aspect ratio doesn't affect the fault. The size of the shifted block doesn't change (the cut remains at the same position).
          If you're lucky,--It'll be the T-Con but I'm suspecting the Panel itself more TBH.....
          TELEFIX
            I have to agree with Alastair.
              Ok, thank you guys.
              I will try my luck then with a T-con. If that doesn't work --- trash can :-)
                I'm sure someone could live with this fault. So don't chuck it straight away.
                Would be a real shame if it is panel. More and more common these days. Either that or open circuit LED!
                  The LVDS lead has been known to fail (erratically!) on this era of Samsung sets.
                    If the original owner bought this with a credit card, they may have double warranty or extended warranty which would be good until April 2015.
                    I know when I buy consumer electronics, I use my credit card which has this feature.
                    --- begin sig file ---
                    --- end sig file ---
                      thanks for your comments. I don't think there is any warranty on this item but it may be something I could explore.
                      This fault happened suddenly, one day it was good next day faulty. Nothing is sensitive to heat, cold or shock/vibration.
