Onn model 100012585 main board transistor is blown
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4889
    • Italy - Milan
    I think you need to find a way to calm down and reflect before act, that piece of trace isn't important, you could have grabbed some sop8 mosfet for free and solder it there, the sop8 pads are ok and you save a lot of money/time, now desolder the tcon diode and feed 12v at bench, you can test the various output stage voltages, if you do not understand so the only your source is to swap boards, not what a real technician do
    • frannyjunk
      frannyjunk commented
      Editing a comment
      I was so disgusted with myself at that point that I just gave up. The truly sad part was that if I had not ruined the mainboard, I would have tried to fix the bad component on the t-con as well. This was the first time I replaced a mosfet, so it was a learning experience. If I get more project tvs, I will consider buying a variable voltage power supply to inject 12V to find the bad components. But on this particular tv, I did end up replacing both t-con and main boards that successfully revived the tv. Thanks for the help!!
    Back Again?
    • 32839
    Ahh don't panic, it's just a TV, stupid mistakes happen that's how we learn! I once blew up an entire plasma TV sustain board because I left the screws out, and broke another plasma TV by pushing on the back too hard. As Forrest Gump said, "Shit happens!"
    I would replace the MOSFET with a SOIC8 part as I indicated.
    For service manual, bios, schematic, boardview (board view), datasheet, cad - use our search.
    Subscribe to support us. It only takes 1 minute: https://www.badcaps.net/settings/subscriptions
    • frannyjunk
      Editing a comment
      Thanks for the encouragement. This was a good lesson for me on a few fronts. I have been doing more component fixes as my tv fixing hobby progressed over the years. This tv, with your help, was the first mosfet I successfully replaced. And if not for my dumb mistake, I would have tried to troubleshoot the t-con board on the component level as well. No matter .... I eventually ended up replacing both t-con and main boards and successfully repaired this tv. Thank you again for the encouragement and help!!!
    Back Again?
    • 32839
    Glad to hear you fixed it.
    • advant
      by advant
      02-03-2020, 12:25 AM
    • TheIbz
      LG 34GN850-B full-screen vertical stripes — diagnosed to the main board, sourcing from China.
      by TheIbz
      My 34GN850-B (2023 unit) suddenly started showing dense vertical stripes across the entire screen — backlight fine, image actively driven but completely shredded. OSD doesn't render either, which rules out GPU/cable/source. Tore it down and did the full diagnostic pass:
      - Reseated and cleaned the LVDS/data cable at both ends (board side P302 and panel side CN1) — no change
      - Backlight connectors (F1/F2) reseated — no change (backlight was never the issue)
      - No bulged caps, no burn marks, board visually clean
      - This model has no discrete...
      09-22-2026, 10:25 AM
    • Dani_2024
      by Dani_2024
      10-28-2024, 05:06 PM
    • ygorsan
      by ygorsan
      🧩 Problem Summary:
      • I
      07-28-2025, 08:34 AM
    • tvguy12012012120
      Picture degrades over ~2–3 minutes (washed out / low contrast) – panel vs T-CON/FRC vs main board diagnosis help
      by tvguy12012012120
      I’m troubleshooting a Westinghouse WD55UW4620 with a strange, very repeatable failure mode and I’m looking for insight on whether this points to the panel itself, T-CON/FRC board, or mainboard.
      Any ideas as to what would cause these symptoms?
      Symptoms:
      • From cold power-on, picture is perfect.
      • After ~2–3 minutes, the image slowly degrades:
        • contrast collapses
        • colors wash out / look incorrect (greens especially bad)
        • image looks “milky” / flat
      • Turning the TV off for a few minutes fully resets it; behavior repeats almost exactly each time.
      • Internal
      01-07-2026, 03:30 PM
