I am a relative novice when it comes to electronics. I am in the process of fixing a 50” Onn tv. No voltage getting to t-con board (V12, VGH, VCON all reading near zero). On closer inspection, the transistor (on the main board) close to the LDVS socket looks to have blown. I am assuming that replacing this transistor will get the tv going again. Question is, how do I get the transistor part number?
Onn model 100012585 main board transistor is blown
Tags: None
Two possibilities.
1. Transistor failed for unknown reasons.
2. Transistor failed because the T-con board has a short on it.
I suggest:
- Replace transistor
- Disconnect T-con board
- Power up TV and check if you have 12V at both DRAIN and SOURCE of transistor (The output is on the DRAIN)
- Power off TV
- Re-connect T-con
- Power up TV - if transistor blows, the T-con board has a short... if not hopefully TV works...
You can also check the resistance across VDD at T-con board beforehand, but in some cases this doesn't appear if the short is behind another MOSFET or only occurs after some time.
As for part numbers, given its location it's almost certainly a P-Channel high side MOSFET in SOIC-8, at a guess I'd fit Si9430DY or IRF7416TRPBF, there are many other options as well though.Last edited by tom66; 09-07-2026, 04:38 PM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, bios, schematic, boardview (board view), datasheet, cad - use our search.
Subscribe to support us. It only takes 1 minute: https://www.badcaps.net/settings/subscriptions -
Thanks for the advice. Upon looking at the transistor in a picture of the same board on eBay, the part appears to have 3 “legs” whereas the parts you mentioned have 8 legs. Perhaps my board needs a different part number?1 PhotoComment
The part is a mosfet AO3407A (top mark is A77E) This is likely the switch for the panel vcc, so the panel may have a shortComment
In this case I found an image of the board online and was able to read the numberComment
The footprint for the transistor is dual load, this is used so the manufacturer can fit different types according to the supply conditions in the market, think of it like a car manufacturer being able to use several tyre manufacturers. So I suggested the larger 8 pin transistor because it will be easier to source and generally they have lower on resistance (less heating of the component when running).Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Subscribe to support us. It only takes 1 minute: https://www.badcaps.net/settings/subscriptionsComment
Thanks! I did not know that. Just learnt something new. Part is now on the way to me. Next challenge is soldering ... not my strong suit. Thanks!!!!The footprint for the transistor is dual load, this is used so the manufacturer can fit different types according to the supply conditions in the market, think of it like a car manufacturer being able to use several tyre manufacturers. So I suggested the larger 8 pin transistor because it will be easier to source and generally they have lower on resistance (less heating of the component when running).Comment
Good luck. The secret is to clean the pads well and use flux. Use a temperature controlled iron if possible, as it is easy to damage pads with a basic iron. (The pads are the electrical connections that the component is soldered to.) Take it slow and be careful about the force you apply - the pads on the board are effectively very thin slices of copper held on with a very thin layer of temperature resistant adhesive, but if you get them too hot or use too much force you can separate them and that's a world of hurt you'd rather avoid.
If you have a steady hand it is sometimes easier to cut the component off carefully with an x-acto knife (other knife brands are available) and then remove the legs one by one.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
I see AVDD on the left side of the board, but it looks like a test point. Or is AVDD the small black chip to the right of (upside down) AVDD print? And does the tv need to be on while I check the resistance? And what (order of magnitude) resistance should be expected?Two possibilities.
I suggest:
- Power off TV
- Re-connect T-con
As for part numbers, given its location it's almost certainly a P-Channel high side MOSFET in SOIC-8, at a guess I'd fit Si9430DY or IRF7416TRPBF, there are many other options as well though.1 PhotoComment
You can check across the red component for a short. The green component is a fuse; check it is not blown.
I put my multimeter in continuity mode. When I placed the multimeter leads to each side of the fuse, it has continuity (i.e. fuse is good), but so does the chip (in the red box). Additionally, both fuse and the other chip have continuity to the tv chassis. What is this chip in the red box? And should it have continuity when multimeter probes are on each terminal of the chip? Should both chips have continuity to ground?
This indicates the T-con board has a short on it. How experienced are you with locating shorts on complex boards like this?
There are a few techniques, but they require electronics engineering equipment (lab power supplies, thermal camera ideally, or freezer spray/isopropyl alcohol).
It is worth checking if the short is still there when the two ribbon connectors at the bottom of the board are disconnected. If they are, the short may be on the panel boards and this can be terminal as it can indicate a bad LCD panel. Hopefully that is not the case here.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
I disconnected the 2 LVDS cables from the LCD panel. The chip in the red box still has connectivity from terminal-to-terminal and also terminal-to-ground. Since I do not have a power supply to inject 12V onto the board nor do I have an IR camera, I guess I will just buy a t-con board. I'll replace the transistor on the mainboard and replace the t-con board, and hope the tv will come back alive. Will report back later this week once I get those done. Thanks!!
Sounds good, hope it works out for you.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Hi, All right on the Tom's first post, but he probably didn't noticed well the last post, first, the power switch mosfet on the main b. can be replaced by a jumper, in case this can turn back useful in future, tv is still usable and you'll have few seconds of graphic artifacts on screen at the power up of set, anyway the mosfet is easily replaceable with tons of parts from junk boards, if you will not receive the part i can help you how to... for the last of your posts, what you marked in red is a protection TVS diode, check it in ohms with probes one way and the counterwise, if both returns zero ohms it is a nose poop and needs replacing, to make a fast check of the tv, remove it with hot air and test the tv if works (after mosfet fix)Comment
The TVS diode is a convenient place to check for short at the 12V input.Hi, All right on the Tom's first post, but he probably didn't noticed well the last post, first, the power switch mosfet on the main b. can be replaced by a jumper, in case this can turn back useful in future, tv is still usable and you'll have few seconds of graphic artifacts on screen at the power up of set, anyway the mosfet is easily replaceable with tons of parts from junk boards, if you will not receive the part i can help you how to... for the last of your posts, what you marked in red is a protection TVS diode, check it in ohms with probes one way and the counterwise, if both returns zero ohms it is a nose poop and needs replacing, to make a fast check of the tv, remove it with hot air and test the tv if works (after mosfet fix)
It might be the culprit but there are lots of other possible parts so I asked OP if he was comfortable tracing that and the answer is "no", so new T-con needed.
Probably OK to replace FET with a jumper but I like to put things back the way I came, and only do "bodges" if there isn't another good option...Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
The diode tests shorted but it wasn't removed from the board so anything else on that board in the parallel path could be shorted. Let's see what happens when the t-con is installed.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Well, the mosfets came today and I have the t-con board coming. So, I soldered the mosfet onto the mainboard and powered up the tv .... pofffff, the mosfet caught on fire. I had accidentally left the t-con plugged in. Stupid, stupid, stupid!! So I tried the remove the burned mosfet, but this time the trace came off. I don't deserve to live!! Now I am on ebay looking for a mainboard. Now I just hope that a new t-con and main board will make the tv live again. Fingers crossed.Comment
by advantThis thread is about trying to get an Universal Main Board to work with a Sharp TCON and panel.
I have a Sharp LC-46D85UN TV that has had a main board issue. Since this model is from 2009, I am not able to find an exact replacement of the main board. Instead, I decided to see if I can future proof this tv by getting a Universal Main Board (T53U21.2) from China to work with the Sharp TCON (CPWBX4291TPZA) and panel. The universal main board supports a 8 bit dual channel LVDS interface whereas the TCON requires a 10 bit dual channel LVDS input. I have modded the LVDS connector to match... -
by TheIbzMy 34GN850-B (2023 unit) suddenly started showing dense vertical stripes across the entire screen — backlight fine, image actively driven but completely shredded. OSD doesn't render either, which rules out GPU/cable/source. Tore it down and did the full diagnostic pass:
- Reseated and cleaned the LVDS/data cable at both ends (board side P302 and panel side CN1) — no change
- Backlight connectors (F1/F2) reseated — no change (backlight was never the issue)
- No bulged caps, no burn marks, board visually clean
- This model has no discrete...-
09-22-2026, 10:25 AM -
by Dani_2024Hi and thanks in advance for any input you might provide!
Last Sunday I was watching a dvd and fell asleep for about half hour, when I awoke the tv screen was black and couldn't get the dvd menu to show, so I changed the input to antenna and had sound but no picture, turned it off. I then got online and found this great site! ....read many troubleshooting tips and this...5 Photos -
by ygorsanHi everyone,
🧩 Problem Summary:- The TV keeps scrolling through the menu or selecting items by itself.
- I removed the physical button board (the entire panel with power and volume buttons) and also disconnected the flat cable (CN202) from the main board.
- The remote control is not in use (batteries removed), and the TV still shows the same behavior.
- I
07-28-2025, 08:34 AM -
I’m troubleshooting a Westinghouse WD55UW4620 with a strange, very repeatable failure mode and I’m looking for insight on whether this points to the panel itself, T-CON/FRC board, or mainboard.
Any ideas as to what would cause these symptoms?
Symptoms:- From cold power-on, picture is perfect.
- After ~2–3 minutes, the image slowly degrades:
- contrast collapses
- colors wash out / look incorrect (greens especially bad)
- image looks “milky” / flat
- Turning the TV off for a few minutes fully resets it; behavior repeats almost exactly each time.
- Internal
- Loading...
