E552VL 0500-0507-0790 Clicking.
  • IRace93
    Resorceful Nub!
    • Dec 2011
    • 44
    Ok First off I have the same TV in this previous thread.
    https://www.badcaps.net/forum/showth...ghlight=E552VL
    But here is My Difference. When I got the TV upon powering the cord it would light the Vizio emblem amber push the power button and it would let out a Fast Buzz Pulse from Relay L802. Then CLICK the set Powers off.
    I Did the board by board disconnect. to No Avail.
    But here is the weird thing After poking around the PS board a Bit I put pressure to the back of the relay and the Ticking Subsided and the set powered on! worked for a while! LIGHT BULB! Bad Solder! So I did some solder tune up on the relay leads and anything else that Jumped out at me! Bingo she fired right up! So with hopes of giving this fine unit to a family member I put a Blu-ray in repeat and let the TV go. I thought I was in the clear. NOPE I came home tonight to the TV still working but the L802 relay is Buzzing like mad.
    after one by one disconnecting the leads same story it clicks slow then fast them powers off. with the main board disconnected I Jumper the 5V to PS ON pin the L802 relay starts to let out a steady TICK TICK TICK and nothing else powers up. the Tick is less frequency that the Buzz it has when the back light lights up.
    Am I safe to assume the PS just needs to be replaced or do any of you have an idea what I need to test or replace on the PS? Is this common of a bad component that I just cant see Caps look fine and No Hot spots on the board.
    When it was working The picture was clear as a Bell everything looked good sound was perfect.
    Thanks In advance. again the pics in the other thread are identical to my tv. I can post close ups if anyone would like.
  • Ltank
    • Jun 2013
    • 776
    Re: E552VL 0500-0507-0790 Clicking.
    Did you locate a P.S. schematic? Got a good pic of board that clearly shows the part#?
      'L802' L = INDUCTOR, not relay, so please show us the pictures of YOUR boards.
      L802 is PFC INDUCTOR, same for L801.
      RL1 is the relay on the power supply board.
      Picture provided by shopjimmy.
      • ERICSSON89
        • Oct 2014
        • 46
        • NIGERIA
        please I need the SCH to this same SMPS board.
        thanks
        ERIC
        • IRace93
          Resorceful Nub!
          • Dec 2011
          • 44
          Having Issues getting good pics Will these work? And no where would I locate a Schematic?
          • tibimakai
            • Jan 2012
            • 3680
            I don't think that Vizio has schematics.
              Power supply board is made by DELTA, so DELTA will not allow VIZIO to publish the SCH for the board.
              What you can do is to look up the spec sheet of the ICs which will tell you what they are and how to use them, then you just trace out the connections.
              The board has Standby power supply: IC900, Q905.
              PFC Voltage Booster: IC801, Q801A, Q801B, D803, D807, D809.
              12V/24V Power supply: IC601, Q601, Q603.
              • IRace93
                Resorceful Nub!
                • Dec 2011
                • 44
                Budm I guess I am over my head.... Should I just order a Good board? I mean what are you suggest I do? as far as voltages to test for or a path to follow? is there something allowing unclean voltage to the inductors or something what would make the inductor Click and Hum ? I swore it was clicking like a relay Sorry for being such a Noob..... But I want to learn I hope I am not frustrating anyone.
                • IRace93
                  Resorceful Nub!
                  • Dec 2011
                  • 44
                  Also when I do the Jump 5V to PS on should it just Light up normally or is the CLICK CLICK CLICK Normal?
                    Clicking and humming form PFC Inductor is not normal.
                    Is the PS_ON signal from the main board steady? The RL1 relay should click on.
                    When you jump 5VSTBY to PS_ON, the PFC Voltage booster will kick on which then you should see the DC Voltage on the main filter cap to jump up from 160VDC to >360VDC, at the same time the 12V/24V will also be turned on.
                    You will not see any backlights until you jump the 5VSTBY to the BL_ON pin (I do not remember which one of the 'A', 'B', or 'C' pin is the BL_ON pin), so do not worry about the backlights right now.
                    You may be better off with new board.
                    • IRace93
                      Resorceful Nub!
                      • Dec 2011
                      • 44
                      Ok I will Order a New Board. I may continue to Play with this one. I Thank you for your help you are awesome! I don't mind replacing the board as long as I am fairly confident that's the Issue!
                      You Guys rock!
                        BTW, you can disconnect the cables to the backghts inverter board to see if the TV will power up OK, you just will not have backlghts.
                        • IRace93
                          Resorceful Nub!
                          • Dec 2011
                          • 44
                          I did that as stated above I did the board by board disconnect and the symptom was unchanged.
                          • tibimakai
                            • Jan 2012
                            • 3680
                            The power on signal, is steady? If it is not, then the mainboard is the fault.
                            • IRace93
                              Resorceful Nub!
                              • Dec 2011
                              • 44
                              Um...... with the main board disconnected it will not power up. With all boards disconected and jumped no power up....
                              • tibimakai
                                • Jan 2012
                                • 3680
                                Just the mainboard has to be disconnected from the power supply.
                                  I think you mean the main board must be connected to the power supply to check the PS_ON signal (as I mention to check in post 7) which is generated by the main board to feed the power supply board. If the PS_ON is going up and down then the power relay will click on and off.
                                  • IRace93
                                    Resorceful Nub!
                                    • Dec 2011
                                    • 44
                                    With the main board uuhooked and 5v jumpered to ps on it just cycles on and off with the board hooked up the voaltage to the ps on voltage is constant till the board times out. Is that what you mean?
                                      So you are hearing the relay RL1 clicking?
                                      • IRace93
                                        Resorceful Nub!
                                        • Dec 2011
                                        • 44
                                        NO! I just walked back out an Verified this. When I turn the set on RL1 Clicks. the Hummm Starts everything Loads and CLICK RL1 Clicks off. I PROMISE YOU the L802 Inductor is where the Hum comes from. That being said. I just Jumped the 5V to the PsOn TICK TICK TICK From L802. Jumpering to PsOn and the A Terminal Lights the Backlight. when the back Light comes the Tick tick tick turns to the High Frequency Hummm that I have noted. That Hum remains when ever the back light is lit and the Main board is not even hooked up. and the sound is coming from L802. the relay comes on and stays on as it should. I even left it jumped only thing getting hot is the Inductor but not terribly hot like its going to burn up it. I have no idea why its making noise I now understand its not a Relay As I mistakenly called it out as.
                                        • beetle1303
                                          Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                          by beetle1303
                                          I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                          On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                          01-13-2025, 08:49 PM
                                        • CoinCoin88
                                          Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                                          by CoinCoin88
                                          I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                                          Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                                          09-15-2025, 03:36 AM
                                        • DodgyTech
                                          60" LG 60PB690V relay clicking issue
                                          by DodgyTech
                                          I require some help with my TV. The TV standby light blicks on and off with a clicking sound (relay?) from the back. After I opened up the TV, I set about troubleshooting by unplugging the boards to try and isolate the problem. My troubleshooting suggests that the logic board is causing the issue, but it could entirely be the YSUS board which is only activated once the logic board is connected.
                                          I have recorded a video which I thought would be an easier way to explain the problem and show the boards at the same time.
                                          I would like to try and identify...
                                          07-07-2023, 10:30 AM
                                        • GraphicMan
                                          Pioneer amplifier A-205 Relay not clicking after a mistake i made
                                          by GraphicMan
                                          Hello guys
                                          Because the unit is old (but only occasionally used) the loudness button causes some noise due to bad contact,
                                          sprays did not work, so i decided to solder the pins that it connects on the pcb at the on (loudness on) position
                                          i did that and it worked fine, i know from the bottom of my heart that the switch connects 2 pins and also d/c other 2 pins
                                          on every position it have (6 pin switch), so i was curious what would happen if i clicked the switch off while the pins are soldered at on (so basiclly on and off at the same time), when i did so the sound is gone, nothing...
                                          05-05-2024, 06:20 AM
                                        • Sisko
                                          Onkyo-593 No power and now clicking sound
                                          by Sisko
                                          Hi all!!
                                          Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
                                          10-03-2025, 02:18 PM
