Panasonic TV TX-50DXW784, Mainboard TNPH1147, Processor dead
  • g1150
    Hardware Devel
    • Feb 2013
    • 14
    • germany
    I have a Panasonic TV with a main board TNPH1147.
    The Problem is:
    - not turn on
    - no LED indication
    - Mains power consumption 5Watt = STandby current
    - all voltages 5V, 3.3V 1.2V, 1V are OK
    - crystal pins voltage = 0.7V, Scope didnt show any oscillation. (24MHZ)
    The main Processor is completely dead.
    The MediaTek MT5810PEHJ is a quad-core Smart TV system-on-chip (SoC) featuring a combination of ARM Cortex-A17
    and Cortex-A7 cores running at 1000 MHz.
    Has anybody ever had such a problem?
    and found a root cause?
    Inputs welcome
    Back Again?
    • 32842
    Can sometimes be due to power surge/lightning hitting HDMI port or similar. Also worth checking if there is a reset controller IC around as sometimes they can fail causing SOC to get stuck.
    For service manual, bios, schematic, boardview (board view), datasheet, cad - use our search.
    Subscribe to support us. It only takes 1 minute: https://www.badcaps.net/settings/subscriptions
    • g1150
      Hardware Devel
      • Feb 2013
      • 14
      • germany
      I progreesed a bit.
      i put an oscilloscope probe on the data lines of the emmc chip.
      then when pluging in the TV = Powering On Standby,
      i observe brief activity on the data lines for about 1 to 2 seconds, then evrything shuts down.
      That is, poweroff, put probe on another emmc datapin, poweron, watch scope for activity.
      Ok, so it looks like the processor isnt dead.
      It trys to read from the emmc, but for some reason fails .
      Hmm, if the emmc firmware it trys to read is corrupt, it does not even show blink codes.
      that means, it trys to load the boot-loader but even that fails.
      ok , whats next ?
      • g1150
        Hardware Devel
        • Feb 2013
        • 14
        • germany
        at the end of the day...TV runs again.
        I was experimenting with these emmc datapins for a while.
        all of them have weak pullups to 3.3V, so you might be able solder small wires in parallel to your emmc programmer
        to read and write with the chip still in place and no need to interrupt any traces.
        doing these poweron/off cycles to see data activity on the emmc pins.
        as said before, there is, briefly.
        then after maybe 20 cycles, it stayed on, the emmc databus shows constant activity.
        The CPUs 24mhz clock is running.
        The TV sucks 10Watt instead of 5 Watt in standby.
        The LED turn on in green.
        The CPU gets warm.
        pressing power on button.....
        green LED starts blinking for about 3 second, then stops and menue is shown on screen.
        The 3 sec blinking is indicating that the TV is looking for valid video sources.
        After i hooked up the SAT cable, i could watch TV.
        Hooking up a usb mouse gave me access to the menue controls and channel browse.
        (no remote available)
        So,,what made this happen?
        I dont know.
        guessing...:
        applying a 1K resistor between a datapin and GND for testing how weak the pullup is, might
        have caused an "emmc not ready" error in the OS, causing it to do some reinit stuff.
        Or by touching these datapins, they have series resistors, one might have had a loose contact.
        After all, it has to do with this emmc chip.
        They age fast because the OS uses emmc as hard drive.
        Then at some stage, they become readonly.
        maybe i was just lucky
          Back Again?
          • 32842
          Sounds like defective eMMC chip, TV reads bootloader from it but it is corrupt and it gets stuck. Unfortunately eMMC has short operating lifespan, a decade is optimistic. Tesla learned this with their earlier cars.
          https://www.tesla.com/en_gb/support/...sked-questions
          One thing you can try doing is reading a copy whilst the flash memory still works and then updating it with a new chip with the same data on it.
          Unfortunately this requires desoldering the BGA and copying it off, not easy if you haven't done that before.
          • g1150
            Hardware Devel
            • Feb 2013
            • 14
            • germany
            Hi Tom66,
            Yes it is the emmc chip.
            its a notorious problem in various modern TVs. Limited write cycles.
            Reading out the emmc chip with a programmer/adapter is a good idea.
            As i found out, the emmc datalines have weak pullups to 3.3V.
            So just connecting your adapter to the emmc data/cmd lines might work without desoldering the chip.
            You should hold the CPU in RESET while doing so. This might even set the emmc lines to HighZ.
            Worth a try.
            So far the TV is working again. Dont know how long.
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4889
              • Italy - Milan
              hello..
              My view is different, your emmc needs only balls renewing, the reason of weak pullup is probably weak signal from emmc, the reason of logical "bad" emmc is that file system inside collects errors in months and allocates spare blocks to be able to store data until the few ones ends and emmc logic tells "emmc end of life" to cpu, this can be reversed with an uart session and a e2fsck command or the like, this is what i usually think by years, and usually starts the battle on the forums, this means your tv will malfunction again soon with no action.
              PS: the fsck command is not enough to be precise, i made a guide for a certain Akai set with a lot of commands and descriptions, or one can also proceed in another way..
                Back Again?
                • 32842
                Only about 15 balls on the eMMC are actually used, since it uses SDIO interface, 4-bit or 8-bit plus CMD/CLK, like a big SD card. Bad balls are rare.
                e2fsck cannot fix bad blocks on the eMMC. The operating system has no influence on the eMMC chip's decision to go into read only or fail to read certain blocks.
                I have implemented eMMC chips on Linux kernels before and seen what happens when the chip fails. 9/10 it hangs the kernel because some critical boot library or firmware can't be loaded and dmesg log fills up with thousands of errors about page/filesystem faults. Sometimes chip will boot in read only mode, but maybe the application layer isn't happy about running in read only mode, so it fails to boot.
                • g1150
                  Hardware Devel
                  • Feb 2013
                  • 14
                  • germany
                  Well, it doesnt. CPU finds out the hard way, writes are failing.
                  Asto reballing, i dont think it is usually a bad contact on the balls.(maybe in same cases)
                  it is usually the state where emmc is no more able to write the requested blocks to disk.
                  Asto my knowledge, it is not possible to "Reset" the emmc to a state where it is again able to write to
                  flash memory. Its exhausted.
                  As Tom66 stated, linux then floods the kernel log with error messages, which also want to go to the emmc chip.
                  so bad shit is happening.
                  Only proper solution is to replace the emmc chip.
                  Does it need to be the exact same one ???????????
                  i dont think so.
                  you need to replicate the disk structure of the original emmc-disk.
                  that is , same partitions and sizes. same software which goes into each partition.
                  i dont know if there are any crypto security stuff going on like on android phones.
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4889
                    • Italy - Milan
                    Unfortunately these for me are memories of several years ago,
                    1) i know for sure EPROM programmers like RT809H are able to delete the BBT=bad block table and reuse the support
                    2) For what i understand (well or not) internal hardware management (controller) of emmc and file system operates in conjunction, software can fill BBT , is it so or not?
                    3) For what i understand or i read, dumping the present content copies also the BBT , so inside programmers sw tool like RT809 there is a function to erase BBT inside a dump before write the dump to a new support
                    4) Recently i posted in an user's request about a non booting or bootlooping tv, i suggested emmc reballing, he after some days replied that kept pushed the emmc while turning on tv, it booted and worked like normal, no furthers news on this case
                    please keep in mind i'm not a professional, so these are partial infos
                    bye
                    • Diah
                      • Feb 2013
                      • 6763
                      we do know Panasonic suffer from Firmware corrupted, the way you are reading / scoping data from eMMC pads , as there no label of them, you some how did reset the eMMC boot loader,, so it was glitch at firmware, not the chip self, now look after firmware for this TV and flash it again.. so it will have new chance.
                        Back Again?
                        • 32842
                        There may be some tools that can erase the bad blocks table on an eMMC, these would be using private vendor extensions. However doing so would not be advisable since eMMC would then use defective cells to write data to, causing filesystem corruption eventually.
                        A major design error that is made is placing eMMC chip too close to system on chip because signals need to go that way. SoC gets very hot and kills eMMC. Maybe it is deliberate. When we designed products with eMMC, we placed it far away from main processor in the coldest area of the board. Still, in simulated testing we found chip failed at 4 years at 40C ambient, so if you left the product in sunlight then it would not last too long. If you kept it cooler you could get 10 years out of it. Still in my mind neither option is acceptable and product engineers should be aiming for 20 years.
                        • g1150
                          Hardware Devel
                          • Feb 2013
                          • 14
                          • germany
                          Diah, i didnt quite understand what you are saying.
                          Lets agree on that it was a design flaw to use emmc as system disk.
                          Or at least writing to it all the time.
                          Are there any success stories of replacing the emmc chip and reflash it ?
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4889
                            • Italy - Milan
                            So what happened here? All lost court cases?
