Fuji-com plasma won't comes on. HELP PLS
  • predator0357
    • Jul 2014
    • 159
    • Israel
    I am a newbie in plasma TV's so my Q is:
    I got a Fuji-com model NR 42 B45 and it doesn't come on at all only the led that indicate that it on, i opened the TV and no caps where blown and nothings seem to be fried, so what should i do? what to check with Multi Meter?
    P.S
    U do hear the relay open/close.
    so pls guide me what to check and where(-:
  • predator0357
    • Jul 2014
    • 159
    • Israel
    Re: Fuji-com plasma won't comes on. HELP PLS
    Some1 pls��
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      Thats an LG 42V7....
      Search for posts on LG 42V7 as well as the service-manuals, but prob have a short IPM....
      TELEFIX
      • predator0357
        • Jul 2014
        • 159
        • Israel
        tnx a bunch(-:
        • predator0357
          • Jul 2014
          • 159
          • Israel
          oooo i 4got to say that the fuses on Y-SUS and Z-SUS was blown, n now i was checked the Y-SUS IPM and nothing was showing (GND, SUS-OUT below 0.4V even nothing), so both Y and Z are fried?
            Probably only the Y-sustain IPM is bad if there are no shorts on the Z-sustain.
            • predator0357
              • Jul 2014
              • 159
              • Israel
              but the fuse on the Z-SUS was blown also, so its still just the Y-SUS?
                Ok, that's odd. Check the Z-sus IPM for shorts too, is it good?
                • predator0357
                  • Jul 2014
                  • 159
                  • Israel
                  its the same checks like the Y-SUS? (GND, SUS-OUT)
                  • predator0357
                    • Jul 2014
                    • 159
                    • Israel
                    ok, i just checked the Z-SUS and its the same as Y-SUS nothing is showing/
                    dumb Q: when i am checking what option in the multi-meter do i need?
                      Use 200 or 2000 ohm range. You need to tell us what "nothing" is... is that zero, or out-of-range (the single "1" on lots of meters, on the right, indicates "out of range")
                      • predator0357
                        • Jul 2014
                        • 159
                        • Israel
                        OK, but what to check on the IPM?
                        • ArMaaN376
                          Samsung PS51E550 Plasma TV
                          by ArMaaN376
                          I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
                          Opened TV cover & observed foll
                          a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
                          b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
                          c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
                          How to confirm Y -Buffer board...
                          06-19-2024, 04:05 AM
                        • jm1234
                          Panasonic plasma TX-P42ST50 - 6 blinks
                          by jm1234
                          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                          I checked that board for any obvious faults...
                          05-22-2024, 06:59 AM
                        • KYBOSH
                          Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                          by KYBOSH
                          Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                          No picture but you hear the TV static (white noise) playing loud and clear.
                          The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                          But it seems they didn't get too far and just left it.
                          When I first took a look I was amazed at how pristine the inside looked.
                          Its as if the TV had been in a time capsule.
                          Caps looked like they were just pulled off the self.
                          Copper coils had no sign of corrosion on...
                          02-01-2023, 11:10 PM
                        • porfyriadhs
                          Samsung Plasma PS51D6900DS Bootloop
                          by porfyriadhs
                          Hello . I have a problem with a samsung plasma tv stuck in bootloop . The TV is Samsung PS51D6900DS plasma smart tv .Need help if anyone have any suggestions
                          Thanks a lot !!
                          10-19-2023, 11:31 AM
                        • SurrealMustard
                          What parts can be salvaged from a plasma with a damaged display panel?
                          by SurrealMustard
                          I recently found myself the proud owner of a later-model Samsung plasma (the PN59D7000 for those keeping score at home) whose panel was, unfortunately, damaged in transport. I'm now preparing to part it out, but am curious as to whether or not any damage would have come to any of the components by attempting to power it up with the panel being broken. I read in one Avsforum thread (for whatever that's worth 😂) that the "scan driver boards" (by which I assume he means buffer boards) could be impacted by doing so. Is that actually the case? If so, since I don't intend on selling bad...
                          03-09-2025, 08:29 PM
