LG 50PC3D won't turn on
  • d0rkster
    • Nov 2014
    • 3
    Tv is around 8 years old.
    I have had ongoing problems with this tv for a while now. Whenever I turned on the tv, the screen would flash and would turn off right afterwards. I had to turn it on multiple times before the screen stabilized to allow me to continue watching it. Perhaps, it had to warm up first?
    Recently, my tv is unable to turn on at all and has completely died on me. There is no led light or anything that flashes (normally should be red).
    I opened up the tv and the capacitors have gone bad. I am about to order the capacitors on ebay but I was wondering if there's any other parts that would be preventing my tv from turning on. I don't want to waste money on capacitors and then find out it still doesn't work. Would buying new capacitors solve the issues I am currently facing? Thank you.
  • d0rkster
    • Nov 2014
    • 3
    Re: LG 50PC3D won't turn on
    Forgot to add pictures. I have posted some pictures in my dropbox. https://www.dropbox.com/sh/k2nzeiu2c...iRk4FrB_a?dl=0
    • steves7839
      • Nov 2014
      • 200
      I'm new to FPD TV repair myself. I would order and replace in a heartbeat. It worked the first time in my case. The only precaution I advise is use a decent 40W soldering iron, care, and good technique to avoid damage to the board. Either order a preselected cap repair kit or search the forum for selection guidelines. My LG50PC turned out to have another issue as well, so I had to send off the Y-Sustain board for warranty repair.
      • MagicSmoke
        • Feb 2011
        • 275
        DO NOT waste your time on ebay for capacitors. Some sellers have genuine products some have fakes.
        Buy from Digikey or Mouser and get good quality capacitors.
        And yes most of the time replacing the caps will fix the problem, but not always. Failing caps can cause damage to other parts in the circuit sometimes.
        I will say that I repaired a PSU with the same symptoms out of a Vizio P50hdtv10a just by replacing the caps on PSU. Yours appears to be the same PSU as in mine. It has LG components in a Vizio case.
        • pajdek
          Lenovo Y700-17ISK turn on and off
          by pajdek
          Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
          09-20-2023, 02:49 AM
        • RdeveLabs
          MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
          by RdeveLabs
          To all the members here...
          Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
          So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
          05-05-2025, 04:59 AM
        • dragon3x
          After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
          by dragon3x
          Hi, I have some 32 bits computer motherboards that need repair, as they fail to
          power on.
          Here are some examples :
          (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
          switching supply area).
          (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
          than 6.3 V.)
          1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
          I replaced capacitors with aluminum-polymer.
          3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
          03-21-2025, 02:46 PM
        • robante15
          Acer Aspire 4520 won't turn on after reboot
          by robante15
          Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
          It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
          The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
          If I remove the...
          04-06-2024, 06:50 PM
        • masoksian
          Dell latitude e7470 not turn on .power buton on off and Run Power problem
          by masoksian
          I am dealing with the problem of turning on and off my Dell e7470 notebook.
          The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
          The system does not turn on, there is no post.
          I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
          The problem continues in the same way.
          I tried to turn on the Fn key, nothing came to the screen....
          02-15-2025, 12:08 PM
