please help me identify this, its driving me nuts!! and possibly where i can buy one? thanks! c5089 is what it says on the board
need help in Identifying this capacitor on a y board from a samsung
Re: need help in Identifying this capacitor on a y board from a samsung
Model number? Board P/N BN44-XXXXX?
It is capacitor for snubber more likely.Last edited by budm; 11-25-2014, 06:38 PM.Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
LJ92‑01797a is the number on the y board for the samsung pn43d450a2dxza I'm not home right now, I'll reply back with more full details but thank you for the fast reply!!!one mansis another ones treasure
Please can you re post your pictures using manage attachments like you did in first postPlease upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740Comment
Odd you managed it in post one?
https://www.badcaps.net/forum/showthread.php?t=1868
Just start a reply using quick reply and at the bottom it says go advanced
scroll down there and add your pictures in manage attachments
Youalso need a little text in the test boxPlease upload pictures using attachment function when ask for help on the repair
Great - now they will still be there when they drop off the off site.
https://allscreen.wordpress.com/2013...ura-deslavada/Please upload pictures using attachment function when ask for help on the repair
Maybe one of these if budm will confirm
http://www.digikey.lu/product-search...=0&pageSize=25Please upload pictures using attachment function when ask for help on the repair
I cannot find the SCH for this PCBA LJ92-01797A yet to find the value of the cap.Never stop learning
It is a Y-main board from a plasma so it will not be available unfortunately, samsung hasn't published any Y-main/X-main schematics.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Check the neighbouring transistors are not damaged as well.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Is no one happy with the spanish link?
Samsung Plasma PL43D450A2D con imagen obscura, negativa, manchada en algunas áreas. se cambio la tarjeta Y- main: LJ41-09479A, revisando previamente la tarjeta X-main (LJ41-09478A) que no tenga ningún corto. (de ser así se dañaría nuevamente la Y-main). En la revisión no se localizan componentes grandes en corto como fets o transistores, tampoco calentamientos excesivos, únicamente en la tarjeta Y-main se ve un condensador C5089 reventado, (estrellado) (102KS630V) (1000pf), como único síntoma visible, Sin hacer ningún chequeo de señales o revisión más detallada, se cambia la tarjeta, Y-main. Luego de 72 horas de prueba, se entrega correctamente
Samsung Plasma PL43D450A2D with dark image, negative, stained in some areas. Y- main card will change: LJ41-09479A previously reviewing the X-main card (LJ41-09478A) that has no short. (if so will damage again the Y-main). In reviewing major components are not located in short fets or transistors, nor excessive heating only card Y-main is a capacitor C5089 busted, (starry) (102KS630V) (1000pF), as the only visible symptom, Without check any signals or more detailed review, the card-main Y is changed. After 72 hours of testing, is delivered correctly
And is the cap at digikey not suitable
Sorry see that link didnt work
http://www.digikey.com/product-searc...690-ND&x=0&y=0Last edited by selldoor; 11-26-2014, 01:56 PM.Please upload pictures using attachment function when ask for help on the repair
is there any other capacitor that may work such as http://www.ebay.com/itm/10pcs-1000pf...item2a475be21a
or
http://www.ebay.com/itm/001uf-001mfd...item418a2611e8
?one mansis another ones treasure
will the part that you sent over in the link, work for it as a replacement?one mansis another ones treasure
The one selldoor found will work:
http://www.digikey.com/product-searc...ds=399-7690-ND
I would go with 1000V rating for more morgin of safety:
http://www.digikey.com/product-detai...761-ND/3491275
Also as TOM had indicated, you need to check those semiconductors for damages.
Did the fuse also blow?Last edited by budm; 11-26-2014, 04:25 PM.Never stop learning
Thank you guys for helping me out big time id rather go through ebay as of right now so i wanted to know if this will work for me http://www.ebay.com/itm/10-Epcos-100...item48651cf2fa or is this a cheap capacitor?one mansis another ones treasure
disregard the last post, and I thank everyone again! ps all other fuses and caps are in contact and look healthy should be a simple fix. smh the things people throw away #onemanstrashisanothersmantreasure
Have a Happy Thanksgiving Bud!one mansis another ones treasure
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by ohrenI hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
The models launched in 2018 and 2019 respectively.... -
by C152HeavySamsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
Summary for TL-DR readers:
• Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
• Have obtained Samsung schematic & service documents - Can upload if helpful.
• Have read ALL applicable threads
• C1818 and CP820 replaced as low hanging fruit
• CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
• VCC pin (18) of PFC... -
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
- Loading...
