Samsung PN58A55081FXZA. Is it hopeless?
  • LameCooter
    • 35
    • US
    So I have been working on this TV for probably 6 months on my off time. Had to trace down a PS issue. Finally got it fixed and powered up and had some no picture areas. turn out the flex cable on the panel was loose. Reseated them, but still had 2 one or so pixel wide green bars but really wasn't very noticeable at all. This wasn't even a week ago. Then last night the area behind the green lines went black. Thought maybe I didn't seat the flex cable right. Pulled the back off, reseated the cable multiple times, and this is all I can get.
    Is it hopeless? Think I might get lucky and get a use panel somewhere? Appears to be part # BN96-05638C or replacement BN96-14645A.
    What exactly caused this?
    Man what a bummer. All that work for 5 days of use.
  • Shinju
    • Mar 2014
    • 1239
    Re: Samsung PN58A55081FXZA. Is it hopeless?
    With the panel off reseat the smaller copper colored ribbon cable on the buffer that is inline with the void area.
    Also a quick test take a toothpick and gently rub the afflicted area ribbon cable while the panel is on to see if the void area changes colors ect. Do this at the top lock connecter touching the toothpick to the ribbon cable.
    • LameCooter
      • 35
      • US
      Pushing the cable affected it a little bit but not much
      • mmartell
        • Oct 2013
        • 3189
        Did you clean the connectors/cables with alcohol yet before reseating ?
        • Shinju
          • Mar 2014
          • 1239
          Ok, so that means it's working, clean that ribbon and dabble some alcohol inside the ribbon connector.
          • LameCooter
            • 35
            • US
            I cleaned it earlier with alcohol didn't seem to matter.
            Also, I just noticed - right above the 2 cables that are giving me trouble, the metal bracket/frame is noticeably hotter than the rest of the top of the unit if that makes any sense.
            • Shinju
              • Mar 2014
              • 1239
              Maybe the buffer board is bad, the heat is Probaby the ICs in the ribbons working hard. Might be a failed panel too.
              • LameCooter
                • 35
                • US
                I swapped the buffer boards around with the lower one - no difference. I edited previous post with image.
                • freakaftr8
                  • Oct 2012
                  • 3743
                  You didn't happen to try to disconnect this cable connection with the tv on did you? That will kill a chip on film ic..
                  • mmartell
                    • Oct 2013
                    • 3189
                    Try directing cool air at that location and see if it changes the screen output. If you removed that heatsink perhaps it was not reinstalled properly.
                    • LameCooter
                      • 35
                      • US
                      @freakaftr8: No made sure tv was off
                      @mmartell OK I'll try that. I didnt remove heatsink. At least not on purpose. Where is it?
                      • mmartell
                        • Oct 2013
                        • 3189
                        The aluminum bar at the ends of your two red arrows in the picture is one long heatsink. It wicks away the heat from the cof's on the ribbons plugged into those bottom address buffers.
                        • LameCooter
                          • 35
                          • US
                          Yeah I never pulled that off.
                            09-07-2024, 05:50 AM
                            09-06-2024, 11:40 PM
                            09-06-2024, 08:40 PM
                            Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                            This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                            09-06-2024, 06:20 PM
