Try our *UPDATED* boardview, bios, & schematic search. Over 2.3 million files for download!
does anyone has access to this firmware ?
    No photos found.
  • weisian
    VSX-1021 - Update Error 1, DSP replaced, potentially need working firmware dump
    by weisian
    I have a VSX-1021 that dropped the UE22 error on me and is no longer was working. I've then done the following:
    1. Tried updating the firmware with a firmware I found online but it hangs at 20% and ultimately shows "Update Error 1". I didn't check prior to attempting the firmware upgrade but the firmware after shows "***" for the DSP numbers. This was before I looked online that pushing an update through with a bad DSP chip could corrupt the firmware.
    2. Tried reflowing the original DSP chip (D810K013BZKB4000) but firmware version remains "***"...
    03-12-2026, 05:54 AM
  • Bruggefan
    MD71-HB0 Firmware bricked of X557-AT2 NICs
    by Bruggefan
    Hi all
    I'm having troubles with an Gigabyte MD71-HB0 rev 1.1.
    I've read on different forums that many people had issues just like I had, but for some reason, mine got worse.
    What happened:
    - Did BMC firmware update in 2020
    - Doing this, my MAC adresses were cleared from my nics
    - Added MAC adresses with an eeupdate tool
    Things worked fine for years, however about a year ago I performed a BMC and BIOS upgrade again.
    Since then, both my 10Gbit and my 1Gbit NICs stopped working.
    The amber led on the NICs is solid on, no matter...
    12-18-2025, 03:12 AM
  • jrbrassow
    Need Public Firmware: TPV/Philips 86-inch Commercial Display (Mainboard 715GD081-M0F) - Stuck in Corporate Mode
    by jrbrassow
    Hello all,
    I am attempting to convert an 86-inch commercial display, manufactured by TPV, back into a standard, fully functional TV/monitor. The display is currently running corporate/embedded firmware that prevents standard operation.
    The primary goal is to find the original or a compatible "public" (non-corporate) firmware file to flash the mainboard and restore normal HDMI input functionality. 1. Display Identification & Hardware Details
    • Suspected Origin: TPV / Philips Professional Q-Line or P-Line series.
    • Panel HWID (from Windows): MONITOR\MGF86
    12-11-2025, 01:57 PM
  • zklgfs
    Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
    by zklgfs
    I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
    08-11-2025, 02:14 PM
  • TheUser
    Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
    by TheUser
    Hello to everyone ,
    This is my first post here, and i would like to share with you a small story in case you can help me.
    Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
    All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
    I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
    02-10-2024, 02:07 PM
