Philips 58PUS7555/12 backlight only
  • domix
    • Jan 2014
    • 198
    • Slovenia
    Yes i have all, only i dont have thermal camera
    • lotas
      • Jan 2016
      • 5398
      • Russia
      There are usually 2-3 protective diode assemblies at the ends of the buffer strips, and these are where breakdowns occur. You can take a photo of these strips.
      • domix
        • Jan 2014
        • 198
        • Slovenia
        I found one cat phone with flir camera
        • lotas
          • Jan 2016
          • 5398
          • Russia
          This CHOT panel doesn't have them. The circuitry is different, so check the passive components (capacitors, MOSFETs, etc.) on these buses. If there's no short on them, the problem is with the panel itself.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4831
            • Italy - Milan
            Manufactures recommends not to supply any current to the supply lines of panel before the vcc is turned on, this will bring to a non recoverable damage (i did it in early days and ruined some traces on a tab) , i have already explained how short can be searched, or with a 100/1000th ohm meter, this is the basis from what i read, every tcon has a different precise timing where the supply lines appears. After this,.48ohm do not resemble a short.. a short is usually less than 1 ohm. Bye.
              Back Again?
              • 32775
              48 ohms could be a failure on the panel ICs or it could be a failure on the board. Ceramic caps can and do fail "leaky".
              Without being able to detach the panel there is a risk of damaging it but I would still try since there is not much to lose if the TV is already broken.
              I would apply 2-3V at current limit 500mA across the VAA supply and see what gets warm, you can carefully use freezer spray or isopropyl alcohol to help, as they will evaporate if the components get hot. Thermal camera makes it even easier.
              For service manual, bios, schematic, boardview (board view), datasheet, cad - use our search.
              Subscribe to support us. It only takes 1 minute: https://www.badcaps.net/settings/subscriptions
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4831
                • Italy - Milan
                #27
                I noticed only now the last page posts.. well, this chot is the new fashion of poop tv sets where half tcon circ. is on the tcon board or main b. and half is on the strip boards, this from the pitctures appears has two twin chips for the gamma control, i know gamma control uses VAA to generate gamma levels, my bet is that some discrete or the chip themselves for the gamma circuits are at fault, so check every discrete first, those 0 ohms etc...
                • domix
                  • Jan 2014
                  • 198
                  • Slovenia
                  #28
                  How to do that?
                  Which one is this chips
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4831
                    • Italy - Milan
                    #29
                    3rd photo
                      Back Again?
                      • 32775
                      Originally posted by domix
                      How to do that?
                      Solder wire to VAA test point which is your positive and a wire to the ground on the T-con board which is black.
                      Power to the TV should be OFF, disconnect T-con from everything except the panel ribbon with the 48 ohms short.
                      Connect power supply (ensure polarity is correct) set voltage very low max 1V, set current limit to 500mA, increase voltage and start looking for warm spots. If nothing happens ramp up to about 3-4V, max 1A. You should be able to find the short at that point.
                      • domix
                        • Jan 2014
                        • 198
                        • Slovenia
                        #31
                        I solder a wire and connect 1v 500ma to tcon. I get one spot hot on lcd stripe on 512 resistor.
                        all with 0ohm has on multimeter 0ohm.
                        and all smd with 512 writen on it has 2,55kohm
                          Back Again?
                          • 32775
                          Could be the chip next to it, are you sure thermal and visible are lined up as those FLIR cameras require you to adjust the alignment for each viewing distance usually.
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4831
                            • Italy - Milan
                            #33
                            The finger! The finger! I will never manage to understand how can be so convenient to buy a FLiR for such a rubbish electronic sets..
                            • domix
                              • Jan 2014
                              • 198
                              • Slovenia
                              #34
                              I think it was aligned yes.
                              I didnt buy flir camera, i found old CAT phone wit flir camera in garage.
                                Back Again?
                                • 32775
                                Well I suggest double checking with freezer spray or alcohol.
                                • Diah
                                  • Feb 2013
                                  • 6734
                                  safe the forum from rubbish test suggestion ... sorry guys ... read my post #15
                                  • domix
                                    • Jan 2014
                                    • 198
                                    • Slovenia
                                    #37
                                    Okay, I'm going to drop the project,, I believe it's true.
                                    • Random Bloke
                                      • Sep 2026
                                      Look at C111, its cracked.
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4831
                                        • Italy - Milan
                                        #39
                                        Yes, it seems so... try replace it with a 20uF 50v, if you have only 10uF try it
                                        • notallbad
                                          • Oct 2012
                                          • 1206
                                          • Save the techie from asking silly questions giving them more time to solve isuues
                                          #40
                                          maybe try isolating one pin at a time on the tcon ribbons to panel until image appears then inspect image to determine if the picture quality remains acceptable.
                                          • bohaboha
                                            PHILIPS 58PUS7555/12 Backlight Sound ON Only Halv Screen
                                            by bohaboha
                                            when i power on the TV is black ,Do I remove the right or the left ribbon I get respectively the right or the left half screen working
                                            Do I disconnect the plug from the power supply, no backlight
                                            Thought the backlight would light up when you remove the plug from the power supply but no
                                            What could be wrong if both halves work separately?​...
                                            03-07-2025, 09:45 AM
                                          • Boardview and Schematic Bot
                                            LCD LED TV Service Menu Codes
                                            TCL LED TV Service Menu Code
                                            LG LED TV Service Menu Code
                                            10-31-2024, 03:58 AM
                                          • alltvrepairs
                                            Jvc Lt-65VU3000 reduce backlight from service menu
                                            by alltvrepairs
                                            I have just replaced led set of this vestel tv due to age.
                                            I would like to reduce backlight from service mode. I have tried menu 4725 but in the menu i can't change anything.
                                            Any help pls? I don't want to change from electronics inverter feedback resistor ideally.
                                            Thanks again....
                                            09-20-2025, 05:03 AM
                                          • ohren
                                            Trying to control Philips backlight manually with PWM — brightness increases with frequency...?
                                            by ohren
                                            I raised the question of whether PWM on the power board "dim" pin would be a reasonable assumption for controlling the backlight of a Philips TV (55put6101/12): https://www.badcaps.net/forum/troubl...d-tv-backlight. I didn't receive any insights there so I went ahead and tried it.
                                            The setup is basically:
                                            Rpi3 hardware PWM → 220 Ohm → NPN transistor → dim pin
                                            Transistor is switching the 3.5 V supply on the power board....
                                            12-05-2024, 11:10 AM
                                          • chestercc
                                            Philips TV Backlight Repair
                                            by chestercc
                                            So i'm trying to replace the LED's in a Philips TV. It's 42" with a 715g7262-p01-000-0010 backlight driver board based around an O2 Micro OZ9902CGN.
                                            My issue is when I replace all the LED's on one board with the new 3V 300ma ones they immediately burn out when the set is powered again. I previously tried the same thing with 6V LED's and the backlight flickered for a bit but wouldn't start.
                                            The original LED's which I removed which are still working start to melt and burn when given more than 3V on DCPS so I know they shouldn't be higher voltage ones.
                                            11-18-2022, 01:15 PM
