Samsung UE40EH6030WXXC Firmware
  • pitzone
    • Mar 2020
    • 13
    • pt
    Hello, does anyone have the firmware for a Samsung UE40EH6030WXXC (BN91-05875Y) that could send?
    Thanks.
  • pitzone
    • Mar 2020
    • 13
    • pt
    sorry mistake on model, is Samsung UE40EH6030WXXC (BN94-05875Y)
    • lubos55
      • May 2017
      • 16
      • Slovakia
      Hi, it is normally on samsung.com web site at support section ,or try attached file.
      • pitzone
        • Mar 2020
        • 13
        • pt
        hi, thanks i already see dowload in oficial page, but e read this update only works by usb/menu,my problem tv turn on and show samsung logo 5 seconds and reboot continous in loop, i cant acess the menu. e need a firmware to write with programmer ex. rt809h.
        or if any soluction to read from usb and update without tv turn on.
        thanks
        • Boardview and Schematic Bot
          09-07-2024, 05:50 AM
        • weisian
          VSX-1021 - Update Error 1, DSP replaced, potentially need working firmware dump
          by weisian
          I have a VSX-1021 that dropped the UE22 error on me and is no longer was working. I've then done the following:
          1. Tried updating the firmware with a firmware I found online but it hangs at 20% and ultimately shows "Update Error 1". I didn't check prior to attempting the firmware upgrade but the firmware after shows "***" for the DSP numbers. This was before I looked online that pushing an update through with a bad DSP chip could corrupt the firmware.
          2. Tried reflowing the original DSP chip (D810K013BZKB4000) but firmware version remains "***"...
          03-12-2026, 05:54 AM
        • Robby-Gr
          TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
          by Robby-Gr
          I’m trying to recover a Samsung UE55HU8500L (curved UHD, 4K model from 2014) after replacing the panel. The new panel is a 55A1UU8EH, which produces excellent image quality — very close to the original.
          However, since the swap, the TV enters a boot loop (Samsung logo → restart) unless I enter the service menu and perform a reset.
          The service mode had been previously modified — possibly by a technician or during the panel swap — and I suspect some key settings are mismatched for the European (Greece) market.
          Additional issues:...
          09-27-2025, 12:02 AM
        • theaaronone
          Samsung Odyssey Neo G9 (LS57CG952NNXZA) BN41-03169A @ Winbond W25Q128.V -- Need Firmware Dump from working unit
          by theaaronone
          I have had this beast in pieces for days going through everything bit by bit - I finally got a chip to read off the main board and it has a high blank / ff count, so I'm wondering if anyone out there has this monitor in working condition that could provide a working firmware?
          • Board number: BN41-03169A
          • Monitor: Samsung Neo G9 57" LS57CG952NNXZA
          • Symptom: No power, FPGA DONE/ALIVE at 0V
          • Flash chip: Winbond W25Q128.V
          • I've got a dump showing 74% erased/0xFF
          • Requesting a good firmware dump from anyone with a working unit
          Thank you!!...
          04-23-2026, 08:37 PM
        • GeckoGreen
          Samsung service bulletin: need firmware file for PN63C550 TV
          by GeckoGreen
          I'm hoping someone with access to the Samsung GSPN can help me. I need someone with access to download a firmware file for my PN63C550 TV, as it will fix a problem per the Samsung service bulletin.
          You can reference Samsung bulletin #:ASC20130528001 and I need the [2D63]LOGIC.bin file please.
          The full service bulletin is linked here: https://www.avsforum.com/attachments...3-pdf.1080602/
          Will you please help me get the [2D63]LOGIC.bin file for my TV?
          05-17-2025, 02:47 PM
