T1 lg ysus
  • abdekader
    • Jul 2014
    • 73
    • Turkey
    T1 lg ysus
    I have T1 LG YSUS (eax61319402) tow transistor Q24,Q22 blown (short)
    I changed this Transistor the same Transistor (30j124) but reshort the same problem
    what's the solution to this problem
    what's the common problems in these YSUS
    Electronic Engineer from Syria,Aleppo
  • tw2005
    • Oct 2011
    • 6458
    Re: T1 lg ysus
    Don't know, don't read much about these especially component repair of the ysus.
    maybe a bad buffer took out the ysus or maybe the zsus can damage it but rarely I'd expect replacing a couple of IGBTs and expect it to work. FET driver ICs are most likely damaged and who knows what else (check the underside SMD stuff too)
    Download this guide and check the ybuffers, ysus and zsus
    I guess by T1 you mean a PDP50T100000 panel ,Possibly LG 50PJ350 etc.
    • abdekader
      • Jul 2014
      • 73
      • Turkey
      Re: T1 lg ysus
      I replaced the Ysus Ok the TV working So, the problem in YSUS but I want help to repair it
      • Recycleinformatique
        • Oct 2015
        Re: T1 lg ysus
        Did you have the answer on how to repair YSUS
        • tw2005
          • Oct 2011
          • 6458
          Re: T1 lg ysus
          always check the Zsus too, i killed my Zsus and repair popped again, nearlymade same mistake then realised the Ysus is connected to Zsus. ysus also shorted. One board took the other out
          • Keshenatech1
            • Apr 2018
            • 149
            Re: T1 lg ysus
            Just curious if you ever figured out the problem in the original Y-sus board and got it working? I have a similar issue with 6 outputs shorted in mine, Q02, 04,11, 22, 24, 26, and 28. Replaced them and it blew out again, only Q24-28. Trying to figure out if the problem is on that board or something else in the set.
            • zwarder
              eax61319402 50PJ350 YSUS
              by zwarder
              Hi
              Had shorted YSUS
              Q24 RPJ63F3
              C726 cap
              Q11 K3667
              R528 & R529 2.2 ohm
              replaced all of these but still trips psu VS & VA are a bit low when ysus disconnected. IC301 does look a bit burnt however
              ZSUS is also good as far as I can tell
              Anyone could help me out on this one
              10-23-2023, 08:11 AM
            • legg
              LG 42PC3 buffer output doesn't follow YSUS
              by legg
              LG42PC3D -UD originally with green lamp but no display or audio.
              Owner says was working, then went 'pop'.
              All 5V caps bulging. replaced.
              All PSU output voltages within spec but -Vy is low on YSUS.
              One of three parallel fets between SUS_OUT and SUS_DN is zenering,
              eventually shorts DG. Replaced all 3 - -Vy now OK.
              Y scan buffer test point does not follow YSUS output below -50V
              Note: This unit seems to expect YSUS output to park at -Vy in between
              drive signal pattern periods. A replacement drive signal board confirms this....
              11-18-2021, 11:49 AM
            • magneh
              Behringer Eurolive B205D repair - help identifying transistor
              by magneh
              Hello
              Got this speaker from a friend , defective. Power led comes on and off , in a loop.
              Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
              After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
              I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
              Still, I need to replace this transistor....
              06-18-2025, 02:34 AM
            • elsomer
              help to identify transistor msi ms-15ck1
              by elsomer
              hi people, i need some help to identify a transistor(q14) that is missing on the board, so the gpu has no voltage i think that q14 activate the phases for gpu, but i dont have schematic or boardview, but i think its the same transistor than q15 and q16, thanks...
              02-17-2025, 05:30 PM
            • rddube
              Help with blowing transistor NAD T752 receiver
              by rddube
              I guess I need help from the masters to try and find what is frying a 2SC5669 transistor on the left channel of this front center Amp for a NAD T752.
              Was working perfectly and all of a sudden I heard a pop, and then a glow from the amp. Not only did the 2SC5669 burn a leg, but R520 which is a 220 ohm resistor partially burned - it now measures 110 ohms.
              I bought this amp second hand fairly cheap as it was not working, it went into protection mode. I finally traced it down to the same transistor Q510, the one that just popped. It was shorted...
              09-01-2022, 05:19 AM
