Sharp Aquos LED wired display issue
+ More Options
Posts
  • Audioplus
    • Feb 2012
    • 157
    Weird display issue, looks like optical fibers, instead of pixels. Has anyone seen this? I will have to add pics from PC
  • Audioplus
    • Feb 2012
    • 157
    Re: Sharp Aquos LED wired display issue
    The last picture exhibits the best issue. It looks like fiber strands laid in on glass bonding. Not a pixel issue, and they are white, the rainbow effect is probably moire pattern or camera issue.
    Any ideas?
      Uneven backlight film layers or contamination on those layers.
      • Audioplus
        • Feb 2012
        • 157
        Tom, you confirm a tab bond issue?
        Thank you!
          No, it's not got the typical symptoms of such a fault.
          • electronicsurplus
            • 210
            Does the image change if you apply pressure to the affected area? If so then there may be moisture between the Back-light diffusion layers, there are several which diffuse the light to obtain an even light area. (Much like taillighst on an automobile where a single bulb is used in the center and it appears that the entire light is lit)
            If the image does not change then I would consider re-flowing the Main IC's on the Main Board and, also on the T-Con since, this would also cause similar symptoms
            But, start with applying gentle pressure to the area and see if there is any change at all
            Aimee
            This Forum absolutely the best and, the most helpful forum I have ever found anywhere. thanks to all the fantastic members here
            Help keep these from the landfills
            • CapLeaker
              Leaking Member
              • 8061
              looks like water between the backlight diffusers to me too.
