Rca 42pa30rq troubles
  • umf1203
    • Nov 2014
    • 28
    I'm trying to troubleshoot this RCA 42PA30RQ. It clicks on then clicks off right away. I did the disconnect test and have narrowed it down to the T-Conn board (I think) When the T-Conn board is disconnected from Power Board it only clicks on. When connected on then off. Tried disconnecting all the other connections to the T-Conn but still click on click off...Bad T-Conn? Or? None of the other boards affect it connected or not.
    Serial Number: 1357-42PA30R-A112332 MFG DATE: NOV 2011
    Re: Rca 42pa30rq troubles
    Most likely, Y-main/X-main/Y-buffer fault.
    The controller / T-con will send the on/off signals, but just because these go away with it disconnected, does not mean it is bad.
    Do you have a digital multimeter available?
    • umf1203
      • Nov 2014
      • 28
      Sure do and know how to use it too...What should I check?
      • umf1203
        • Nov 2014
        • 28
        Got my meter and my magnifying glasses ready...What's my next step?
        • umf1203
          • Nov 2014
          • 28
          After replacing the ymain, xmain and y buffer it works like new...nice tv. It also has the tuner that will get the hd cable channels we have here on channels 1005-1011 without a cable box.
          • survivalbloke
            Acer Predator Helios 300 - will not power up if battery is CONNECTED
            by survivalbloke
            This was a no power initially. Thanks to your help, I discovered it was the first mosfet, so I replaced. Now, the device will power up only if the battery is NOT connected. As soon as I connect the battery, it shuts off. If I connected the battery while the device is off, it simply will not respond to the power button. I replaced the battery, and while I suppose the new battery could be faulty, I'm assuming it is not. I'm having the same behavior with the new battery. I measure .2v at the charging coil. Manually applying power to the + and - at the battery header, there is no charging happening....
            06-25-2025, 12:20 PM
          • beogeek
            820-2915-A Wont power on with battery connected
            by beogeek
            Ok so this doing my head in and hopefully someone more knowledgeable will be able to assist.
            I've got a MacBook Pro 820-2915-A it will power on without the battery connected, but when the battery is connected it will do a 2,3-second fan spin when pressing the power button and then nothing.
            After measuring and probing around I found that R7051 was bad, reading high instead of 2.2Ω so I replaced it. Still the same issue, I have the green light on the charger but it won't power on or charge the battery.
            So to cut the long story short I've replaced U7000,...
            02-26-2022, 01:29 AM
          • muhuruu
            PS5 too many USB devices connected
            by muhuruu
            Hello. I have a problem with a PS5 console that I bought to learn electronics repair. The auction description indicated that the console had been dropped. The HDMI port and USB ports were damaged. The HDMI port was replaced by the previous owner, and after his repair, the console worked for 2 days and then became dead. After receiving the console, I replaced all the USB ports. After replacing them, the console started to turn on. On the logo screen, it displays "too many USB devices connected". My further attempts to fix the error involved replacing the Southbridge, 4 TPS2001D chips,...
            05-19-2025, 07:14 AM
          • GRANDGG
            LG 42lw4500 flashing red light , wight light , 2 clicks
            by GRANDGG
            Hi i have an issue with LG 42lw4500 wich after pressing the power button flashes red then goes solid white light 2 clicks and nothing , the weird thing is SOMETIMES if i leave the tv plugged in it would come on and fuction normally (i should mention that vertical rectangle going from the bottom to the top of the screen have some red dot artafacts it only appear in somthing like the tv input menu and any input i give like vga , but not in the system menu , i thought i should mention this , i cannot confirme if the tv had this issue when it was up and running in its previous owner . ) when checking...
            05-09-2025, 12:27 PM
          • versionlab
            Weird problem, laptop stays on when connected to another pc
            by versionlab
            Hi, I want to ask for advice about an interesting issue I've been having with a sony vaio laptop.
            Client came and said that "a desklamp touched the back of the lid while laptop was operating normally and it caused the office's circuit breaker to trip. Laptop had never turned on since".
            After taking the laptop apart (checked dc adapter everythin ok), I found a faulty MOSFET on the motherboard which I replaced. Laptop managed to turn on. However, while booting it shut down. Nothing else seemed faulty and thermals were ok. Shutting down was coming at random...
            10-26-2022, 03:43 AM
