Panasonic 46RV525U Screen issues
  • joeshannallie
    • Dec 2013
    • 103
    • usa
    Picked up this TV today and thought it may be a loose connection but that is not it. Can someone tell if it is the screen itsself that is bad?
  • joeshannallie
    • Dec 2013
    • 103
    • usa
    Re: Toshiba 46RV525U Screen issues
    Sorry I made a mistake, The TV is a Toshiba and not Panasonic.
    • joeshannallie
      • Dec 2013
      • 103
      • usa
      Re: Panasonic 46RV525U Screen issues
      Bump
      • freakaftr8
        • Oct 2012
        • 3743
        I've seen this before with Toshiba. Its a bad SMD connection on one of the surface mount components on the top boards behind the metal frame where the ribbon cables go into the panel. the problem would be associated on the left side board.
        • joeshannallie
          • Dec 2013
          • 103
          • usa
          Thank you for the reply. I will check on it this weekend. So will it just need to be resoldered?
          • freakaftr8
            • Oct 2012
            • 3743
            quite possibly first try lightly tapping on the components on that long board that spans half way across the top of the screen on that side and see if the picture comes back momentarily.
            be careful not to run it too long as you will overheat the driver ic's. just do it long enough to see if the picture straightens out
            • joeshannallie
              • Dec 2013
              • 103
              • usa
              I want to ask before I take it all back apart if there is a possibility that the problem might be the T Con board? What is the chance that it may be?
              • Sevenqi
                • Jul 2011
                • 292
                This is not t-con problem, and most probably not fixable, go for parts.
                • jkruns
                  M1 A2338 screen and touchbar issues after cleaning up liquid damage
                  by jkruns
                  This is my first post after browsing this wonderful treasure trove of knowledge for many, many evenings. I've decided to learn how to fix these things, properly.
                  My patient is an A2338 Macbook Pro M1 (late 2020).
                  It had some corrosion around JT710 and JT700 caused by liquid spill, as well as against the protective barrier around the USB-C chips UF000 and UF100. So I took the main board out and cleaned it with a toothbrush and alcohol, then with alcohol in an ultrasonic cleaner. Cleaned the touchbar flex connectors as well. The board looks...
                  04-22-2024, 06:45 AM
                • Ryan.man
                  by Ryan.man
                  02-04-2025, 12:23 PM
                • Chrissygizmo
                  Panasonic TX-48CX350B backlights but white screen , blank screen
                  by Chrissygizmo
                  Hi all, I’ve got a problem I hope someone can help me fixi.
                  I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
                  01-11-2025, 03:18 PM
                • Alicat
                  Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                  by Alicat
                  Stopped by this site trying to fix my parents Panasonic Plasma TV.
                  Model number is TH-50PZ85U
                  Power comes on and the red power light stays on solid.
                  Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                  I also hear a few clicks.
                  I also think my parents said there was a thunderstorm and the TV failed after that.
                  Section 6 in the service manual talks about power and no screen,...
                  10-30-2024, 10:09 AM
                • reformatt
                  by reformatt
                  07-31-2025, 08:37 PM
