LN32D450G1DXZA white screen slowly appears after turning on
  • jstiene
    • Feb 2013
    • 148
    Hi.
    I just picked up a Samsung LN32D450G1DXZA. When I turn it on, the screen is initially blank and slowly comes on and turns white with random lines,etc. It takes a couple minutes to turn all white, or at least close to all white. I have yet to produce sound out of it.
    Has anyone encountered this before? I have not run across this before.
    Re: LN32D450G1DXZA white screen slowly appears after turning on
    A good chance that the LCD panel is defective on this one, I'm afraid. What you're describing is exactly what many panels do when failed. Sorry.
    • harp
      White screen repairs
      by harp
      To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
      Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
      On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
      05-13-2024, 03:43 AM
    • EazyBone
      Sharp LC-65Q620U White Screen
      by EazyBone
      Another TV topic!!
      I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
      The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
      Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
      08-21-2024, 12:56 PM
    • hcinne
      Dell G15 ryzen edition black screen 2 amber 1 white
      by hcinne
      I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
      07-23-2024, 07:56 AM
    • Chrissygizmo
      Panasonic TX-48CX350B backlights but white screen , blank screen
      by Chrissygizmo
      Hi all, I’ve got a problem I hope someone can help me fixi.
      I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
      01-11-2025, 03:18 PM
    • odi
      Sharp E50E41NKFMBXNNX white screen
      by odi
      I'm trying to fix this TV that I got from a friend. It displays a white screen only. What is weird though is that when I first turned it on it appeared to work for a few minutes but then got the white screen and I haven't got the picture back even for a second after that initial time. If I plug in an HDMI device, the audio is played through the TV speakers, and the power button turns the TV on and off.
      I've tested the caps on the power supply with an ESR meter while in circuit they seemed within spec.
      Tried wiggling the LVDS while on and no change to the white screen. Have removed...
      01-31-2022, 03:29 PM
