Proscan 42la45h power board model hlp-45a01 (hisense) so this one popped the thermal resistor and I have only ever replaced caps and such where should I start?
Proscan 42la 45h Power Supply help...
America-well we used to fix our own stuff, now we just buy new...Tags: None -
Re: Proscan 42la 45h Power Supply help...
Remove the old one and clean up the board - if it is actually charred you may need to
cut it away as it may be conductive. Take care not to damage any more traces check both sides of the board.
Check the component for any identification - if none measure the physical size and try and locate one.
When it is cleaned up we can suggest how to extend the traces and repair the hole.Please upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740 -
WI'll do I'll get back with post clean up pics.America-well we used to fix our own stuff, now we just buy new...Comment
Ok well one plan might be to take a piece of wire and make a loop in it - if the trace is strong solder the wire to the trace and around the loop.
Test for continuity from the loop to the leg of C803. Put new component in place with
one leg going through the loop and solder up.
You could also solder the good leg in place then solder one end of the wire to the trace,
wrap around the unsoldered leg and solder the other end to the trace then apply solder to the leg and wire wrap.
I suppose we need to consider why it burnt out - power surge? -did the fuse blow as well etcPlease upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740Comment
I'm going to the electronics shop now and I also wondered that because the fuse didn't blow...America-well we used to fix our own stuff, now we just buy new...Comment
That part is the current inrush limiter, can you read the resistance between the two legs, it should be around 5 Ohms or so, the body does not show the sign of damage, the burnt on the board (I have seen this before) is due to cold solder joints on the legs.Never stop learning
I would clean as much flux residue from where you have soldered the new part as you may find it could cause issues. I use ipa to clean the area myself.Last edited by vinceroger69; 11-16-2014, 07:18 AM.Comment
Assuming...7 Photos -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by JimBanvilleThe sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
Opened it up and discovered the power supply is making a faint clicking or ticking sound.
I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...-
by Gust zhangI have a 15 - inch Retina MacBook Pro from the mid - 2014 model. Here is the link: https://www.badcaps.net/forum/showth...light=820-3662 . The battery broke some time ago. After I removed the battery and plugged in the original power adapter, the MBP could boot up normally. However, when I checked with IntelPowerGadget, I found that the CPU speed was limited to 0.8 GHz, and it ran very slowly. Later, I found a solution on GitHub. There is an open - source project called cputune that can set the CPU running speed. So I can now run the MBP at full speed. But another problem...
- Loading...
