Ps50q96hd
  • sordids999
    • May 2013
    • 2157
    Ps50q96hd
    hello guys
    trying to work out whats wrong with this plasma front standby light just flashes but no picture
    VA 207 volts VS 60 volts on the psu
    tested the buffer boards for shorts but cant find anything wrong
    any more ideas
  • tw2005
    • Oct 2011
    • 6458
    Re: Ps50q96hd
    That'd be what i'd be looking foe especially upper buffer and also check ymain , 80n30w FETs usually short with a bad bufferunless there's a mainboard issue.
      Re: Ps50q96hd
      Check Vscan & Vset on Y-main.
      Any panel glow at all?
      Check LED on Y-main, can you see one lit up?
      Is LED on control board blinking?
      • sordids999
        • May 2013
        • 2157
        Re: Ps50q96hd
        Vscan is 094 cant find Vset ?
        no glow from the panel
        no LED is lit up on the Y-main
        LED control yes is blinking
        also i have a spare main board tried that but still the same
          Re: Ps50q96hd
          Vscan at 94V is bad, indicates possibly shorted Y-buffer. Does it change when Y-buffers are removed?
          • sordids999
            • May 2013
            • 2157
            Re: Ps50q96hd
            buffers removed gives me 0.00
              Re: Ps50q96hd
              Does that make the LED light on the Y-main?
              • sordids999
                • May 2013
                • 2157
                Re: Ps50q96hd
                no tom no LED light on the Y-main
                but im confused just tested the buffers again to be sure cant find any shorts ?
                  Re: Ps50q96hd
                  I'm not sure why the Vscan is going away when you pull the buffers. If you power-cycle the TV can you test it quickly on volt range, see if it spikes up then turns off maybe?
                  • sordids999
                    • May 2013
                    • 2157
                    Re: Ps50q96hd
                    0.34 volts with buffers removed i had my meter set at 600 volts turned it down to 20 volts and thats what i get now on V-Scan
                      Re: Ps50q96hd
                      Not really sure what to make of that but definitely something wrong with the Y-main. I second tw2005's suggestion to check for shorts on the transistors etc.
                      • sordids999
                        • May 2013
                        • 2157
                        Re: Ps50q96hd
                        ok ill check them
                        thanks
                        • sordids999
                          • May 2013
                          • 2157
                          Re: Ps50q96hd
                          tom question do you still think the buffers are no good before i test Y-main for shorts ?
                          • sordids999
                            • May 2013
                            • 2157
                            Re: Ps50q96hd
                            update :
                            upon inspecting the Y-sus further i noticed a blob of solder has blew off on one of the mosfets and the fuse on the Y-sus had blown so i re-soldered the connection and replaced the fuse and now the tv relays just clicks from the PSU and the tv keeps restarting,the fuse on the ysus is still fine ?
                            thanks
                              Re: Ps50q96hd
                              Suggest you check Vs on Y-main for shorts. Bet the 88N30W's are shorted...
                              • tw2005
                                • Oct 2011
                                • 6458
                                Re: Ps50q96hd
                                Originally posted by sordids999
                                update :
                                thanks
                                You may have more than one fault. PSU continually clicking may suggest the Vs / va ccts have now blown on the PSU.
                                if they have not blown, may be an idea to reflow the fets on the heat sinks on the PSU.
                                i've got one of these that has blown upper buffer, blown the ymain & has blown the the vs and Va lines on the PSU and continually clicks.
                                3 most common faults with that series are those 3 items. AFAIK the PSu repair is not just a case of replacing the FETs, there's a bunch of SMD transistors and diodes etc underneath that go too. Not sure but they do get dry/fractured joints on the FEts and i suspect that is when the PSU blows.
                                Maybe some pictures of the ymain blown solder issue would be handy as that sounds unusual.
                                • sordids999
                                  • May 2013
                                  • 2157
                                  Re: Ps50q96hd
                                  Tom:
                                  just tested these and im getting no reading just beeping from the multi meter
                                  http://www.ebay.co.uk/itm/4pcs-RJH30...item417a383662
                                  picture updated
                                  • sordids999
                                    • May 2013
                                    • 2157
                                    Re: Ps50q96hd
                                    @Tw0025 Q5101 middle pin had the blown solder when i inspected it
                                    • howardc64
                                      by howardc64
                                      07-24-2025, 05:17 PM
                                    • howardc64
                                      by howardc64
                                      Problem
                                      08-04-2024, 10:36 PM
                                    • Yanleb
                                      Schematic or datasheet for Plasma TV buffer chip
                                      by Yanleb
                                      I'm interested in understanding how a buffer board chip is working. I know there's about 90 outputs per chip to the plasma panel, but I'm more interested to know about the input pins. I guess that some of them are address pins, but I want to know more.
                                      So far I've found nothing at all. I haven't found any datasheet about the various buffer chips, and I haven't found any schematic for the buffer board using them (Y Buffer Board in Samsung's terminology).
                                      Any information will make me happy. It can be from any buffer chip or plasma TV manufacturer....
                                      05-18-2022, 01:36 PM
                                    • MisterAIL
                                      PS5 digital / No Power / No Beep / Good power supply
                                      by MisterAIL
                                      Brought a non functionnal PS5. Apparently only a bad PSU...
                                      No beep, nothing.
                                      After some tests i found this :
                                      - PSU is fine (12 volts stable)
                                      - 12 volts line is shorted
                                      - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                                      - By the way, nothing change. No signal, no power, no beep.
                                      Mesuring all rails with my workbench psu (12 volts input)
                                      - 0.00 amp drawing
                                      - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                                      03-12-2024, 03:24 PM
                                    • Mcfeetroy
                                      Fishing bite alarm drains battery
                                      by Mcfeetroy
                                      Good day to all. The bite alarm drains 9-volt Krona batteries. Current consumption when switched on is about 50 mA. I wiped the board from oxides, I will attach a photo (on the board there is a j3y transistor and a 7533 stabilizer, the microcircuit is erased = (the 3.3-volt stabilizer heats up weakly. I replaced it, nothing changed. I unsoldered the microcircuit, the consumption disappeared. The resistance on the pins of the unsoldered microcircuit from the point clockwise is more than 2 megaohms, the 11th leg is presumably ground. I warmed up the microcircuit, the consumption does not change....
                                      08-01-2025, 03:52 AM
