Sony KD-55X8000C - No picture, shows Sony Logo but blue screen after
  • jbaranas
    • Jun 2026
    • 7
    Hello Everyone!
    i am having trouble with my TV, my friend gave it to me and he told me he got it from somewhere so that is why I did not know the history of it.
    When turning on, it shows Sony Logo, then solid blue screen after. Then nothing just stay that way.
    I bought Main Board from ebay then T-Con from Aliexpress. Replaced Main board, the TV improved it is like booting up to dashboard, then I put on my chromecast and I try to play youtube videos with it but no picture. I then try remove LDVS from old t-con, then it asks for update showing green and orange LED lights, I reconnect old T-con again then I updated it using firmware I found online. After updating successfully, it only shows Logo then Blue screen again. I replaced T-con from aliexpress then same I updated it, then still blue screen. I tried Hard Reset using Power+Vol down, I do not see any pictures but I can definitely hear sounds like a playstation sounds or something maybe Setup sound(same sound when waiting for an update). I do not have remote controller so I could not verify if it is on the setup.
    i know T-con is probably the issue, but can you guys help me what other issues can you think of?
    thank you!
    Back Again?
    • 32699
    I think it's unlikely that if you get the Sony screen that it is a T-con fault. Does the TV switch abruptly between the logo and the blue screen or is there a delay?
    For service manual, bios, schematic, boardview (board view), datasheet, cad - use our search.
    Subscribe to support us. It only takes 1 minute: https://www.badcaps.net/settings/subscriptions
    • jbaranas
      • Jun 2026
      • 7
      Yes, abruptly after logo then blue screen, then I tried universal remote, I confirmed that I can control the setup for first time. I can hear sound moving when clicking up or down button.
        Back Again?
        • 32699
        I suspect this is not a T-con fault but an issue with the main board then. It sounds like the 'smart' application isn't starting correctly for whatever reason, possibly corrupted firmware. If there's a way to load firmware onto the TV using USB, that can be done "blind", I'd recommend trying that first.
        • jbaranas
          • Jun 2026
          • 7
          thanks tom66,
          I am not sure if the firmware is corrupted but when I load it while changing main board or t-con, it successfully installed.
          what currently happening is when I open my tv, it shows Sony Logo, then abruptly blue screen, darker blue then blue screen. Then it sounds like a playstation sound(probably the setup page, i can hear sound while using arrow buttons).
          then one time around yesterday, I had some kind of a problem, diagnostic test patterns showing different colors and lines, then found out it was the LDVS not connected properly.
          I do not know if the test patterns means the T-con is working properly, because it sends test patterns through the display panel when it does not receive proper data from the main board. But after replacing LDVS, now it just shows blue screen, darker blue, then blue screen.
          i hope its just the firmware which is corrupted. And also, the seller notes that the main board is from brand new TV broken screen while transporting. And I think so too, i checked and its very clean.
          thank you!
          • NXTPRO
            Sony Bravia KD-55X8000G stuck at Sony Logo
            by NXTPRO
            My Sony KD-55X8000G TV is stuck on the Sony logo. I tried disconnecting LVDS and turning it on again, but the TV only showed a white LED (not blinking) and nothing else. Then, I reconnected LVDS, and it still only showed a white LED with the Sony logo. It seems it's not entering update mode. When I used a USB drive and named the firmware file upgrade_loader.pkg, the TV displayed "Updating..."(Sample image attached) but after about a quarter of the process, it restarted and got stuck on the Sony logo.
            Board: 1-982-454-51
            04-03-2026, 07:28 PM
          • mauda
            Sony TV model KD-65XE7005 - only Sony logo for 3 seconds
            by mauda
            I'm currently working on repairing a malfunctioning Sony TV model KD-65XE7005 with the mainboard 1-981-926-21. I would appreciate your assistance with this issue.
            Upon powering on the TV, the Sony logo appears for approximately 3 seconds, after which the backlight remains lit, the screen remains black, and nothing else happens. The TV consumes around 55W initially and then drops to 35W. The indicator LED remains solid white. It doesn't respond to the remote control. When attempting to update the TV using a USB dongle, the dongle briefly flashes but nothing else happens.
            05-21-2023, 11:56 PM
          • Ihandyrepair
            4 red flash led 65X950G boot Sony and android logo but then black
            by Ihandyrepair
            HI guys
            I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
            here is the issue
            I have Sony and android logo. but then 4 led red flash lights front of the tv
            I have 3.3v ref. 12v reg then T con 12v when I press the power on button
            but then I get black screen and 4 red flash light at the front LED
            but I get 3 led flash on the LED driver board.
            I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
            so I tried...
            07-11-2024, 01:45 AM
          • taslan
            Surface 7 Pro wont boot, shows Logo and immediately turns off
            by taslan
            as stated in the title, my surface 7 pro wont boot anymore.
            When i press the power button it shows the square windows logo for a second and immediately turtns off again.
            I dont even have a chance to get into bios or boot from usb.
            While trying to find help online it was suggested to look for help/repair here on badcaps and it might be a ME Region corruption in bios.
            I dont know what that is exactly, but i never tinkered with the bios or windows in terms of hacking/patching etc.
            Bought it directly from microsoft and used it now and then and only...
            01-16-2025, 01:25 AM
          • Checkedlemon788
            ROG Ally Z1 (RC71L) Refuses to start up. stuck at first ROG logo, never shows startup animation.
            by Checkedlemon788
            I Have a ROG Ally Z1 (RC71L) That is stuck on the ROG logo. does anyone have a Clean Bios image i can flash to it? I don't know the bios chip or what it usually comes with? I've attached some images to hopefully give some clarification. if not, I'll just take it apart and upload the image of the chip.
            01-07-2026, 12:48 PM
