LG 52LG5010 ac detect sorted but still problematic
  • satinser
    • Oct 2012
    • 214
    Continual cycling off and on. All voltages from power supply ok but PWR-ON voltage fluctuating between 3.3volts and Zero resulting in PSU ( EAY4175270) switching off and on.
    After reading Tom66 excellent posts regarding this issue the AC Detect optocoupler was disabled (pc100). This corrected the non start issue. However I have another problem which may or may not be a consequence of this action. I have noticed a pinking noise from the PSU that appears to be related to the backlight level.
    This noise is present all the time but not discernible on low backlight with back cover on. When Dynamic picture setting with 100% backlight it becomes more noticeable even with back cover on. However I cant be sure that this isn't a totally different issue because the TV came in as a non starter. Any thoughts on this would be appreciated.
    Re: LG 52LG5010 ac detect sorted but still problematic
    "Pinking noise" ?
    Please describe further. Never head of this before.
    • satinser
      • Oct 2012
      • 214
      Its difficult to describe but think its associated to backlights. Tried disconnecting the both inverters used in this model. The backlight obviously dont then work but the noise is then no longer apparent. I likened it to pinking because it sound some thing like a car engine out of tune when the old carburetor was present before electronic ignition.
        I really have no idea what you mean, I have never worked on a car aside from helping with jump starting my dad's car.
        • satinser
          • Oct 2012
          • 214
          Its difficult I know Ive never heard anything quite like it before you could liken it to a metalic chirping like noise. Only when backlight is set to a high level.
            On some power supplies that -can- be normal.
            You'd really have to scope the output to be sure...
            • cliff_hootarski
              • Jul 2006
              • 411
              Are you trying to say "pinging"?
              • satinser
                • Oct 2012
                • 214
                • satinser
                  • Oct 2012
                  • 214
                  Its too obvious to be normal. I dont think its anything to do with the ac detect repair issue as just spoken to owner of TV and he said that he had noticed it before and by turning the backlight level down found that it had stopped.
                  Still like to know whats causing though.
                    Well, do you have access to an o'scope?
                    • satinser
                      • Oct 2012
                      • 214
                      Afraid not. Now found that applying a bit of pressure to the heat sink that's got the bridge rectifier attached too it stops the noise. Will in all probability find that there's a dry joint somewhere around that area that's the cause of the issue.
                      • satinser
                        • Oct 2012
                        • 214
                        Checked for dry joints but afraid none found. The metallic chirping increasing if back light turned higher. Tried disconnecting both master and slave inverter and in sound only mode the chirping stops. So wondering whether its a fault in the back light that's causing the chirp in the PSU and not the PSU itself. Applying slight downward pressure to the Bridge Rectifier heat sink definitely decreases the chirping sound. Is there a possibility that the bridge rectifier itself could be causing this noise with some type of internal short?
                        • ron77
                          • Dec 2012
                          • 63
                          • united kingdom
                          Recently repaired one of these TV's. The fault was relay clicking on and off continuously. With back on relay clicks. Take back off, set worked perfectly if room lit. Ordinary daylight enough to keep tv running. Take back off at night, in dark room, tv would keep on clicking. Putting insulation tape over zd102 kept relay clicking. Replacing zd102 16v zener cleared fault. Also replaced zd503 because it read 15v, instead of 16v. Zd102 did not read faulty, and replaced with same type, In5246b. The tv on test all this week and is working fine.
                          • satinser
                            • Oct 2012
                            • 214
                            Just like to point out that I have today repaired an LG power board with AC detect fault again by bridging pins 3 and 4 of optocouplers ic101 and ic102.
                            Power supply used on LG 50PG3000
                            EAX38865401/7 EAY39190301.
                            Fault was not continual clicking but switch on and straight off to standby with red standby illumination tuning to blue and returning to red after a few seconds.
                            Adding this information in case it helps referring to this thread in the future.
                              • 12181
                              • U.S.
                              If I understood it right, the optos are faulty? Wonder if there's any downside to fixing it like that? would the optos wear out faster maybe?
                              • R_J
                                • 9535
                                The fault is in the circuit that drives the optocouplers, Whatever the fault is, this is just bypassing the fault detection circuit.
                                IC101 is part of pfc circuit, There could be a problem with the pfc circuit thats causing the other problems, The pfc voltage is likely too low, when the tv (backlights) demand more current, the power supply can't supply it, causing the noise you here. What is the voltage across the main filter? I suspect the pfc circuit is not even running and the rest of the power supply is operating from the 340v dc
                                Pink noise is similar to white noise
                                  • 12181
                                  • U.S.
                                  Ok I see, thanks.
                                  • tony359
                                    by tony359
                                    11-28-2023, 05:18 AM
                                  • MegaZAC
                                    Onkyo TX-SR805 noise in one channel
                                    by MegaZAC
                                    Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                                    Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                                    There's some logic behind it. As soon as I select an input I get only left...
                                    04-23-2025, 10:09 PM
                                  • courtcircuit
                                    Philips HTS8000 home cinema noise problem
                                    by courtcircuit
                                    Hello
                                    I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
                                    Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
                                    Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
                                    I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
                                    Removed each of tyhe boards
                                    02-08-2025, 08:22 AM
                                  • karatzdi
                                    Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                                    by karatzdi
                                    I know some might say... just buy another one. Sell it as parts..!
                                    So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                                    Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                                    Spent some time downloading the Service...
                                    06-11-2024, 08:38 AM
                                  • soopacrucial
                                    by soopacrucial
                                    Hi folks,
                                    10-29-2024, 02:40 PM
