LG 65UH625V - No picture, no sound, backlight works - 12V missing at T-Con connector
  • AureliusF
    • Jun 2026
    • Deutschland
    I recently picked up a faulty LG 65UH625V and have been trying to diagnose it. Here are the symptoms and what I have found so far:
    Symptoms:
    Backlight turns on normally
    PC recognizes the TV via HDMI as an output device
    What I tried:
    My first suspicion was the T-Con board. When I disconnected one of the panel flat cables from the T-Con, half the screen showed white and the other half black - which seemed like a classic T-Con contact issue. I attempted the tape trick but it did not seem to work. I have a replacement T-Con on order but it has not arrived yet.
    The problem I caused:
    While measuring voltages on the T-Con board I accidentally touched something with the red multimeter probe. The backlight flickered off for a few seconds, came back on, and there was a faint burning smell. Since that moment the half-white screen symptom is gone and the voltage at the T-Con power connector dropped from 12V to around 1V.
    My measurements so far:
    Power supply output at P2501: 12-13V ✅
    Voltage at T-Con power connector (P7100): ~1V ❌
    Continuity between P2501 12V pin and P7100: no continuity ❌
    T-Con fully disconnected, same result: still no 12V at P7100
    The power supply seems fine. The problem appears to be on the mainboard (EAX66882503) between the power input and the T-Con connector. I suspect I damaged something when I accidentally shorted a pin.
    Does anyone have a schematic or know which components sit on the 12V path to the T-Con connector on this board?
    Thanks in advance!
    Back Again?
    • 32702
    LG don't tend to publish schematics for their main boards any more. Most likely there is a high side P-channel MOSFET or similar switching the power to the T-con, which has been burned, or something like a fuse or ferrite bead has been damaged. We can try to trace it but, realistically, it could be very hard to find.
    For service manual, bios, schematic, boardview (board view), datasheet, cad - use our search.
    Subscribe to support us. It only takes 1 minute: https://www.badcaps.net/settings/subscriptions
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4785
      • Italy - Milan
      It is very simple to find the component , it is on the main board near the wide connector for the tcon, it's a mosfet in 8 or six pins usually. it's a static switch that turns on at a certain time after set turn on
      • iglitare
        Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
        by iglitare
        i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
        Backlight seems to work, Sound (Setup menu after reset) works.
        If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
        Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
        With my small knowledge i would think at least the cables are good.
        Can this happen because of a bad tcon board?
        Or is it always a bad/shorted...
        09-04-2025, 07:13 AM
      • maneatingmonkey
        Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
        by maneatingmonkey
        I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
        There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
        03-27-2024, 07:17 AM
      • TR103
        by TR103
        - it keeps rebooting
        01-22-2025, 04:12 PM
      • Ierwin
        by Ierwin
        05-13-2025, 03:31 PM
      • jchang
        Samsung UN70NU6900F no picture and no sound
        by jchang
        Hi all
        I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
        Symptom:
        No picture no sound.
        When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
        No sound at all.
        What I tried:
        1. I tried unplugging the left or right ribbon...
        01-09-2023, 06:28 PM
