Is it possible to convert the Panasonic plasma TNPH0988 motherboard from a TX-P50VT50T to a TX-P65VT50T?
  • stecos
    • Nov 2022
    • 23
    • Italia
    Hello everyone, I'm back with a question about a type of TV I'm passionate about: Panasonic plasma TVs!
    I have a TX-P50VT50T that's in perfect working order and a TX-P65VT50T that's showing no signs of life.
    I'd like to "sacrifice" the 50-inch to bring the 65-inch to life.
    From my analysis, the non-functioning board on the 65-inch is the "A" mainboard, which is unobtainable.
    Therefore, I'd like to install the one from the 50-inch.
    What IC changes would I need to make? Has anyone already converted this TNPH0988 for different screen sizes?
    They could be IC9304, IC8900, IC8901, or others... I've found conflicting opinions online.
    I thank in advance anyone who wants to help me with this undertaking!
    Back Again?
    • 32637
    The most likely part to swap would be around the PDP panel controller, which can be identified as the components connecting to the ribbon cables that route to the 'C' boards.
    It is likely that if you do not swap correctly things will not work well, which may include damage to the sustain boards (SC/SN/SS) this is because the modules will be driven like they are driving 50" panel so resonance etc. will be wrong.
    How did you conclude the fault is the "A" board?
    For service manual, bios, schematic, boardview (board view), datasheet, cad - use our search.
    Subscribe to support us. It only takes 1 minute: https://www.badcaps.net/settings/subscriptions
    • stecos
      • Nov 2022
      • 23
      • Italia
      This "A" board typically has a defect in the progressive unsoldering of the IC8000 (2WS0250E), the TV's main processor. You can see the reballing procedure in this video.
      https://www.youtube.com/watch?v=FbC9BP5plZg&t=346s
      The defect initially manifests itself with a random shutdown, the TV stalling on the initial "SMART VIERA" logo, and finally it won't turn on at all...
      The reballing procedure is expensive and that's why I wanted to use the working "A" board from the 50 inch
      • stecos
        • Nov 2022
        • 23
        • Italia
        The 65-inch started to exhibit the flaw with this sequence I described.
        I obviously checked the power supplies and they're fine.
          Back Again?
          • 32637
          Ok, post a picture of your A-board and I can try to locate the chip. I believe it's called the PEAKS EEPROM.
          • stecos
            • Nov 2022
            • 23
            • Italia
            Now I have not a picture of the board A without heatsibk at high resolution in the computer, I can make it if you want...
              Back Again?
              • 32637
              Your third picture would be my most likely guess for PEAKS EEPROM device, technically it looks like SPI flash. The PEAKS is the plasma processor, converting the video signal from the main processor into drive signals for the C boards (video data) and the panel. The NAND chip is in the 2nd and 4th pictures and most likely contains the application firmware for the "Smart" TV features.
              • stecos
                • Nov 2022
                • 23
                • Italia
                so you think it's enough to replace the PEAKS EEPROM (IC8304)?
                • lotas
                  • Jan 2016
                  • 5346
                  • Russia
                  If IC8304 is SPI Flash, then it cannot be PEAKS EEPROM.
                    Back Again?
                    • 32637
                    Good point, worth looking for that IC then, maybe on bottom of board or might be in a smaller package like MSOP8.
                    • lotas
                      • Jan 2016
                      • 5346
                      • Russia
                      The markings are not visible, but it looks like Eeprom, since pins 1-4 are located on the ground and are located close to the SoC.
                      Well, the SPI flash should also be transferred, since it belongs to the panel, and it’s even better to save the contents, dumps on the eeprom programmer and SPI flash before installation.
                      • stecos
                        • Nov 2022
                        • 23
                        • Italia
                        This evening (I write from Italy) upload a high definition picture, the IC It seems to be IC8902.
                        • stecos
                          • Nov 2022
                          • 23
                          • Italia
                          Upload some picture, also IC8000, the component that should be resoldered (or replaced)
                          • lotas
                            • Jan 2016
                            • 5346
                            • Russia
                            IC8902 (24C64) is the EEPROM, which is what I assumed, replace it and SPI Flash IC8304 too.
                            • lotas
                              • Jan 2016
                              • 5346
                              • Russia
                              If you are replacing the IC8000 with a new one, you will have to look for a NAND Flash programmed with the original service firmware, since the NAND firmware is tied to the native processor (keys).
                              "When Main IC (IC8000) is replaced, NAND Flash (IC8900) should be also replaced with new one the same time.
                              When NAND Flash (IC8900) is replaced, Main IC (IC8000) is not necessary to be replaced the same time.
                              After the replacement of IC, SELF CHECK should be done to generate the final KEY data.
                              How to SELF CHECK: While pressing [VOLUME ( - )] button on the main unit, press [MENU] button on the remote control for more than 3 seconds.
                              TV will be forced to the factory shipment setting after this SELF CHECK."
                              • Tesla
                                • Jul 2011
                                • 152
                                Just wanted to drop in and say that I like them also.
                                I have a 46-inch 1080p Panasonic TH-46pz850u (Gen-11) that we use in our main home-theater when the Projector is not on (so many hours a day). Still works perfectly.
                                I also have a 50-inch 1080p Panasonic TC-P50G20 in the shed that will no longer turn-on (my brother's old one). I always thought I would fix it one day, but never seem to have time to crack-it-open.
                                Good luck with your repairs.
                                • stecos
                                  • Nov 2022
                                  • 23
                                  • Italia
                                  Ok, but what is this "KEY"?
                                  • stecos
                                    • Nov 2022
                                    • 23
                                    • Italia
                                    The TX-P65VT50T service manual mentions different ICs, however...
                                      Back Again?
                                      • 32637
                                      Do these TVs still support Netflix being 13 years old?
                                      • lotas
                                        • Jan 2016
                                        • 5346
                                        • Russia
                                        Each processor (SoC) has an individual ID number, and this number is used to generate its own KEY and write it to the EEPROM, NAND, or eMMC memory. This means that the device is linked to the native processor, and with someone else's dumps, the TV becomes crippled (not all functions will work where there are certificates).
                                        • dom.true
                                          IC2960 for A Board - Panasonic TH-P42X10Z Plasma Television
                                          by dom.true
                                          Hi Folks,
                                          I have a Panasonic TH-P42X10Z Plasma Television (2009-era; New Zealand model).
                                          This set has proven to be extremely reliable throughout its +16-year lifespan. However, late last year, when going to use the TV, I noticed a 9-blink red LED error code on the front of the set after the television failed to turn on. A quick Google search revealed that this indicates a problem with the set’s main A-board.
                                          After opening up the set and giving the board a thorough test with my digital multimeter, I found that one of the integrated circuits on the board...
                                          01-17-2026, 05:01 PM
                                        • jm1234
                                          Panasonic plasma TX-P42ST50 - 6 blinks
                                          by jm1234
                                          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                          I checked that board for any obvious faults...
                                          05-22-2024, 06:59 AM
                                        • stecos
                                          Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                                          by stecos
                                          Hi everyone!
                                          I happened several times, in the search for help from the web, to consult this very interesting forum.
                                          So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                                          Having said that I come to the gist of my post on the forum as the title suggests.
                                          For my passion for technology I'm now collecting several...
                                          11-28-2022, 11:39 AM
                                        • Sus256
                                          HISENSE 65E7KQ PRO - no boot
                                          by Sus256
                                          Hi all!
                                          HISENSE 65E7KQ PRO
                                          RSAG7.820.13512 - chassis
                                          MT9618BAATAB - cpu
                                          RSAG7.820.12059 - power
                                          HD650Y3U77 - panel
                                          KLM8G1GETF - emmc
                                          Replaced emmc.
                                          Terminal log
                                          UART
                                          AC_ON
                                          E-B
                                          FDE enabled
                                          06-01-2025, 02:11 AM
                                        • cloo
                                          Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                          by cloo
                                          I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                          It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                          So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                          After doing a factory reset this problem was gone and the picture was back to...
                                          01-06-2025, 06:02 AM
