Samsung UE75TU7090 backlight or PSU fault?
  • Gjackson
    • Aug 2021
    • 144
    • Malta
    I have a Samsung UE75TU7090 with PSU board BN44-01056A (L75S6N_THS) with a backlight fault. With both backlight connectors unplugged the TV boots normally with a stable 12V rail. With the backlight connected the TV fails to start, Channel 1 (rated 115V) folds back to around 20V, Channel 2 (rated 70V) drops to 0V, and the 12V rail collapses to 3.1V. With the backlight disconnected and powered on, Channel 2 ramps up to around 230V open circuit while Channel 1 sits at 0V.
    Since the TV boots fine with the backlight unplugged I'm leaning towards a shorted LED strip causing OCP which brings everything else down with it. Is it safe to assume the fault is in the LED strips and proceed to open the panel, or does Channel 1 reading 0V open circuit suggest a PSU fault that needs investigating first? I'd like to avoid removing the LCD on this behemoth of a TV if I can...
    I found no indication of shorted FETs or diodes.
    Thanks!
    Back Again?
    • 32756
    I suspect shorted LED strip too; if you have a power supply capable of higher voltage (115V DC+) you can try to test the LEDs. Does channel 2 voltage go up and then back down again?
    For service manual, bios, schematic, boardview (board view), datasheet, cad - use our search.
    Subscribe to support us. It only takes 1 minute: https://www.badcaps.net/settings/subscriptions
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4809
      • Italy - Milan
      Hi, i some times suggest a test, but i always meet lazy or uncapable people that don't do that, in years and years no one did it, i never did it, because i no more repair tv sets, i don't know if it works, anyway requirement: few cm of thin cable and a spare working 3v led bar or even some 1n4007 diodes... let me know in which shore you stay, bye..
      • lotas
        • Jan 2016
        • 5394
        • Russia
        There was a breakdown of the mask (substrate) on the radiator (aluminum base) of the LED strip, and the strip itself comes into contact with the TV case, and because of this, a short circuit occurs to the case and the power supply goes into protection.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4809
          • Italy - Milan
          The test is not possible with the connector i see now, no cables, in any case you need to open the leds tray
          • Repairtechlcd
            • Nov 2013
            • 17
            • Malta
            You may have one of ther led strips shorting to chassis. Get a led tester and put the negative lead to the metal chassis and probe with the possitive lead the backlight connector. See if you get any readings which of cource would indicate a fault.
            • howardc64
              Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
              by howardc64
              • Prior owner tried a replacement main board. No difference.
              • Samsung 2x red blinking standby LED = panel fault
              • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
              • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
              • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
              07-19-2025, 10:54 PM
            • Boardview and Schematic Bot
              09-07-2024, 05:50 AM
            • C152Heavy
              Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
              by C152Heavy
              Summary for TL-DR readers:
              • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
              • Have obtained Samsung schematic & service documents - Can upload if helpful.
              • Have read ALL applicable threads
              • C1818 and CP820 replaced as low hanging fruit
              • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
              • VCC pin (18) of PFC...
              01-11-2023, 02:53 PM
            • kevin_allein
              Samsung GU65TU8079U backlight problem
              by kevin_allein
              Hi, I have a Samsung GU65TU8079U, where the backlight is not working. I started with the typical Samsung test to disconnect the mainboard, still no backlight comes up.
              Next I took out the PSU and took it to the bench. 13 V are there and also ~280 V on the LED connector (with nothing connected).
              Now I am struggling with the connector pinout. On the component side of the PCB I find this label:
              Also on the backside there is an identical pinout.
              However that pinout does not make any sense looking at the traces. Pin 1 is the positive...
              05-11-2026, 11:46 AM
            • Vdaimo
              Samsung NeoQLEd QA55QN85AAKLXL backlight failure
              by Vdaimo
              I’m not an experienced TV technician, but I do some basic electronics repair as a hobby. I’m a mechanical engineer by profession and have experience with soldering PCBs and working with ESP32 and STM32 embedded systems.
              I have a 4-year-old Samsung QA55QN85AAKLXL Neo QLED TV. Recently, the backlight stopped working completely. The TV still boots normally — I can tell the LCD panel is working and the TV functions otherwise seem normal — but there is no backlight.
              Here’s what I’ve checked so far:
              • Power supply board outputs around 64–65V to the
              05-06-2026, 03:07 PM
