Sony KD-43XG8196 and KD-49XG8196 can the same motherboards be used as they use the same TCON pcb and main boards?
  • cheeky2
    • Dec 2012
    • 361
    • uk
    I have a Sony KD-49XG8196 that I am hoping a Sony KD-43XG8196 main board will resolve my issues with the TV. The TV's both use the same TCON pcb board a 6870C-0761A and use the same main board model (1-982-626-41). Now will I have to modify the eeprom on the TCON board for the Sony 49inch screen TV to work with the TV as it thinks its a 43inch screen and may not communicate properly with the TCON?
    If I do what bits will I have to change in the eeprom? I am guessing the model number of the TCON board?
    Thanks in advance for any help in my quest to get this TV operational again.
  • zomi
    • Nov 2011
    • 547
    • uk
    do the tcns have the same sony part number..?
    • cheeky2
      • Dec 2012
      • 361
      • uk
      One has the part 6871L-5942A for the 43inch set and the 49inch set has 6871L-6043B. I have looked at the pcb's and no noticeable difference to them both. It may just be worth getting anther 43inch tcon board and trying it as they are cheap.
      • tiki66
        • Jul 2016
        • 80
        • Croatia
        Yes it will work, those two main boards have same Sony part number. You will eventually have to flash new sw:
        https://www.sony.co.uk/electronics/s...tware/00282916
          Back Again?
          • 32839
          In most cases this will work but there can be some issues e.g. speakers might sound odd if they are tuned for a larger/smaller chassis. Sometimes calibration won't be accurate. But many people may not notice.
          For service manual, bios, schematic, boardview (board view), datasheet, cad - use our search.
          Subscribe to support us. It only takes 1 minute: https://www.badcaps.net/settings/subscriptions
          • cheeky2
            • Dec 2012
            • 361
            • uk
            I should have the boards tomorrow so I will keep you advised on the progress. Thanks for the input
            • cheeky2
              • Dec 2012
              • 361
              • uk
              Good news the TV is all up and running. The 43inch TCON board had to be used to get the TV to display anything (no backlights when using 49inch or any image from the board)!
              So clearly the Tcon communicates with the main board. So I would imagine that it is looking for the 43inch information from the TCON board rather than the 49inch information.
              I could reprogram the U8 and U9 ic's which contain the relevant information onto the 49inch Tcon however for less than £10 it's not worth doing it. I will see if there any issues with the picture over this week to see if I change just one of them over that communicates with the main board.
              • cheeky2
                • Dec 2012
                • 361
                • uk
                Actually its not U8 ic but the flash ic U9. So I am probably going to reprogram it from the 43inch TCON board onto the 49inch board. It's a MXIC 25L8006e which carries the data for the screen etc.
                • Boardview and Schematic Bot
                  Nintendo SWITCH GamePad HAC-JCL-MAIN-01 PWB_BAT-01 JCL-M-11 PWB_MAIN-01 HAC-JCR-MAIN-01 Schematic & Boardview
                  PWB-BAT-01 PCB layer.pcb
                  JCL-M-11 PCB layer.pcb
                  HAC-JCL-MAIN-01 PCB layer.pcb
                  PWB-MAIN-01 PCB layer.pcb
                  HAC-JCR-MAIN-01 PCB layer.pcb
                  HAC-JCL-MAIN-01 image.pdf
                  PWB_BAT-01 image.pdf
                  JCL-M-11 image.pdf
                  HAC-JCR-MAIN-01 image.pdf
                  PWB-MAIN-01 image.pdf...
                  10-09-2026, 02:10 AM
                • advant
                  by advant
                  02-03-2020, 12:25 AM
                • Daren87
                  Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                  by Daren87
                  I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                  08-13-2023, 03:25 PM
                • iglitare
                  Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
                  by iglitare
                  i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
                  Backlight seems to work, Sound (Setup menu after reset) works.
                  If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
                  Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
                  With my small knowledge i would think at least the cables are good.
                  Can this happen because of a bad tcon board?
                  Or is it always a bad/shorted...
                  09-04-2025, 07:13 AM
                • TomSal
                  Looking for a working main board for Sony KD-65ZD9.
                  by TomSal
                  Part numbers: 1-980-838-11 / 173612711 / A2094441A / A2094442A /
                  BM2 / BM2_EU_CI_I
                  Donor TV with broken panel is also OK. Located in Estonia, EU.
                  Any leads appreciated.
                  06-01-2026, 01:47 AM
