Does anyone have an old meter they would like to sell to another boardie? :)
+ More Options
Posts
  • tucocaps
    • Apr 2013
    • 331
    • United Stated
    Not sure if I can ask here, but I thought I would try anyway.
    Been trying to learn from some of the great experts here, but have been very low on cash lately, and in need of some test equipment. In particular a good VOM and a soldering iron. So, if anyone has a great deal on something they might want to extend to a fellow forum member, please let me know! Thanks a bunch!
  • chth96
    by chth96
    03-09-2024, 10:03 PM
    12-31-2023, 06:04 AM
  • jorpec
    by jorpec
    Hi
    Thnaks
    01-23-2023, 10:37 AM
    Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
    12-14-2023, 07:45 PM
  • Stephan Mathers
    EDMI ATLAS MK10 Electronic Meter Discussion
    by Stephan Mathers
    Greetings, new guy here but always interested in the crazy universe of modding
    We just finished construction of around 25 vacation houses, all inside the same private area.
    Each house has 3phase power , and we bought an atlas MK10 meter for each house (25 meters total ! )
    The metering on a per-house basis is done privately. Its not done by a utility company. The utility company will only charge us for the total consumption of all 25 houses together.
    Id like to do a small modification on the firmware of our MK10 to make it easier identify each house's...
    05-20-2025, 09:09 AM
