A reball/reflow is not what I wanted to hear. There are 4 larger ICs and about 5 memory ICs. So I would have to do them all. I don't have the tools/skills for a reball. I might be able to do a reflow, I do have a pre-heating station and a hot air station. And what would be the correct way? Preheat around 140-150 degrees and hot air 400 degrees like 2 minutes till the chip is able to move?
Samsung 8K TV (2018) model QE65Q900RAL, boot loop
This topic has been answered.
I tell you what is my advice, what i think is that to use a very good expensive flux for non lead alloys, i have some product codes, i can tell you when at home, Brands Chipquik and Amtech, after i think to heat only by the bottom, this because i think the flux have to boil and have not to be pushed away by the air flow, the flux must by applied generously around all chips, then pushed a bit under with hot air blower that makes it fluid, then keep to heat by the bottom and wait for the flux until it still makes boubbles, the boiling extracts oxide from soldering, you can even add a bit o flux during this, when heat rises you must check with IR thermometer that it reaches (??) maybe around 230 C, then you check the "move" by gently touching each chip, so you can stabilize the temp, when the boiling tends to end (no more boubbles or less) you can lower the temp slowly--
-- THE REAL PROBLEM is HOW to clean flux -- i am serarching a method but i don't know how, maybe commercial flux removers..
IF you succeed and TV work and you removed totally the flux near and under the chips, you test for some days the set, if all OK, seal every chip with hot glue, this is fundamental.Last edited by Davi.p; 05-19-2026, 02:47 AM.Comment
After this reballing advice, you'll have to look for a new motherboard. This requires professional reballing equipment. You'll need to completely remove the chip, remove the old solder, tin the blackened areas on the SoC and the motherboard footprint, apply new lead balls, and resolder.Comment
You advise reballing, followed by replacing the MB. You are correct in concluding that I am not capable of doing a reball myself. However, before writing off the MB entirely, what would be wrong with attempting a reflow? At this point, there is not much left to lose.After this reballing advice, you'll have to look for a new motherboard. This requires professional reballing equipment. You'll need to completely remove the chip, remove the old solder, tin the blackened areas on the SoC and the motherboard footprint, apply new lead balls, and resolder.
So far, I have not been able to find a replacement MB in Europe at a reasonable price. If the reflow attempt fails, I will probably try to sell both OCB and cable and write off the panel, although it would genuinely pain me to see such an impressive 8K panel go to waste.Comment
Find a professional in your city who can do this, a specialized service center that has a professional BGA soldering station
If you start heating and reflowing instead of reballing, the PCB may warp from the heat and then you won't be able to seat the chip evenly.Last edited by lotas; 05-19-2026, 06:46 AM.Comment
How many chips are? 10? you are lucky if you find someone that do 50Eu/chip, plus shippings/costs.. maybe 600eu?
PS: i counted, 12 chips.
PPS: Remember which end does the majority of Samsung today: pad panel after few years... and the probablity of this is 8K = twice than 4K = twice than 2K (FHD)Last edited by Davi.p; 05-19-2026, 08:22 AM.Comment
I understand now, thanks for the advice: so a reflow might work, but it might also ruin the chance to reball it later. However, labor in the Netherlands is so expensive that having it reballed costs more than a new MB, and there are few repair shops here as well.Comment
Amazing, I fixed it, at least for now! I tried to reflow the two ICs that are actively cooled with the fan (those are the largest ones). That did not make a difference. Then I tried a second reflow, this time the memory chips around those two ICs. That didn't work also, but I noticed that this time the BL was on and the fan started running. Only no picture. So there was change. So I did a final attempt: I gave the memory chips another heat/flux-treatment, and this time the tv immediately started. I will keep it running for a while to see how long it lasts. Now I need to find 8k content :-)
Diah I did check all the LED-cables, all can send a error signal, but none did. I measured them all on both boards.1 PhotoComment
The picture is more blue than it is in real life, although there might be a bit wear of the LEDS. I took a picture of the screen when it was white, in real that looks OK. I attached a picture of one of my previous projects that did had worn leds, that looked quite different. Both are taken with the same iPhone.2 PhotosComment
by janos6662000Hello everyone,
I'm working on a Samsung Sound Tower MX-T70 (1500W Party Audio) that came to me completely dead, showing no signs of life. Since I couldn't find any schematics or service manuals, I did some deep diagnostics and measurements.
Here is a summary of what I have checked and done so far:- Power Supply: The standby voltage is present and stable at 12.3V–12.5V. The 3.3V rail is also active.
- Power Button: The power key pin receives 3.3V and successfully drops to ~0.3V when pressed, so the signal reaches the board.
- PSU Forced Start: I identified the Power-On
by NolesFanHello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...2 Photos
by highpulseHEY GUYS , I got here this unit that was with a broken tuner (literally riped of and only the case of the tunner was soldered on the board , I'm almost sure i could swap thru sources , but after i replaced the tuner the TV turn on with samsung logo and then it display the icon of media (foto on attachment ) so i tought could be a bad tuner so i removed the tuner and without the tuner it does exactly samething , i can't do anything , command or the TV button doesnt respond to nothing.
the board is a BA41-01958B
anyone here was firmware for this model ?? i apreciate if someone can send...07-17-2026, 09:52 AM -
My Samsung TV had a black patch on the left side of the screen for a while. One night it shut off and then became stuck in a boot loop. I initially believed the back-light was the issue and replaced the LEDs but it still boot loops. I've since replaced the main board and the issue persists.
With the main board unplugged, it powers on and the back-light comes on. I've tried the tape method but I gave up as I don't know what pins I need to cover.
I suspect the panel itself it broken but have no multi-meter to test. Is it worth investing in one to test?... -
by GorrillasnotI haven't messed with repairing TVs in a really long time so I feel as if I am almost a total noob again.
Anyway I was given this TV for free and figured I'd give it a go trying to repair it.
The original problem was when plugged in there was no standby light and I could hear a relay clicking over and over.
I unplugged the cable that runs between the PSU and main board plugged the TV back in and the backlights came on. Checked the voltages on the PSU and they all were steady and within spec, so I figured the problem was likely somewhere on the main board.
After doing a...1 Photo - Loading...
