Sky Glass Gen 2 No Sound Issue
  • jasonr2000
    Advance Tech
    • Nov 2013
    • 222
    • Computers, Cars,
    Hi guys I purchased a second hand sky glass tv last week.
    it had no sound so I ordered a tested mainboard from eBay and there is still no sound output.
    any ideas what I can check next ?
    thanks
    jason
    Samsung UE46D6530
    Samsung BD-F7500
    Samsung HT-ES6200
    Back Again?
    • 32648
    The obvious one is settings on the TV - it might be set up to output audio via optical audio or eARC only. I can disable the sound on my TV by doing that, and with optical out there's no way for the TV to detect the audio isn't working since it's unidirectional data.
    I don't know how configuration settings are stored on this model but I'd expect that is on the main board but perhaps it persists settings in some other way.
    If the sound output is set to internal:
    - Check the speaker resistance. Should be around 6-8 ohms each. Check the speakers with power off and disconnected from the main board.
    - Check for damage on the speaker wires. Check for shorts from either positive or negative to the chassis ground.
    - Visibly inspect the speakers to make sure they aren't blown somehow (no idea how that could happen... but just in case.)
    For service manual, bios, schematic, boardview (board view), datasheet, cad - use our search.
    Subscribe to support us. It only takes 1 minute: https://www.badcaps.net/settings/subscriptions
    • jasonr2000
      Advance Tech
      • Nov 2013
      • 222
      • Computers, Cars,
      Hi tom66
      thanks for the reply I have checked the speakers and I get sound through them if I power them from my amp at low volume I also tested them with a volt meter and they test good.
      any other ideas ?
      could it be a missing power rail from the power supply ?
      thanks
      jason
      Samsung UE46D6530
      Samsung BD-F7500
      Samsung HT-ES6200
        • 31774
        does it have a headphone socket?
        whatis the power amp part number?
        if it'd class-D (D = distortion ) then it could be dead
          Back Again?
          • 32648
          Let's start with a clear picture of the power supply board, including photos of each of the labels on the power supply connectors. Maybe there is a problem with the amplifier power supply. On some power supplies this is indeed a dedicated output, although it varies from TV to TV.
          • jasonr2000
            Advance Tech
            • Nov 2013
            • 222
            • Computers, Cars,
            it don't have an headphone socket sorry.
            Samsung UE46D6530
            Samsung BD-F7500
            Samsung HT-ES6200
            • jasonr2000
              Advance Tech
              • Nov 2013
              • 222
              • Computers, Cars,
              sure pictures to follow sorry for the delay...
ID:	3875950 Click image for larger version
ID:	3875951 Click image for larger version
              Samsung UE46D6530
              Samsung BD-F7500
              Samsung HT-ES6200
                • 31774
                does this tv really have 6 speakers!?
                  Back Again?
                  • 32648
                  Can you read the part numbers of these ICs, if you don't know how to do that, take a really clear picture of the ICs that shows the part number
                  Click image for larger version  Name:	image.png Views:	0 Size:	1.86 MB ID:	3876142
                  Can you also take a picture of the whole back of the TV so we can see where cables go and the general arrangement of boards
                  Also, please confirm the model number of the TV.
