Samsung NeoQLEd QA55QN85AAKLXL backlight failure
  • Vdaimo
    • May 2026
    • India
    I’m not an experienced TV technician, but I do some basic electronics repair as a hobby. I’m a mechanical engineer by profession and have experience with soldering PCBs and working with ESP32 and STM32 embedded systems.
    I have a 4-year-old Samsung QA55QN85AAKLXL Neo QLED TV. Recently, the backlight stopped working completely. The TV still boots normally — I can tell the LCD panel is working and the TV functions otherwise seem normal — but there is no backlight.
    Here’s what I’ve checked so far:
    • Power supply board outputs around 64–65V to the LED controller PCB
    • LED controller PCB also shows around 64–65V on the test pads
    • No visibly burnt components
    • No swollen/puffed capacitors
    At this point I’m not sure how to proceed with the diagnosis. Could the issue still be failed LEDs/backlight strips even though voltage is present? What should I check next?
    Any guidance would be appreciated. Thanks!
  • EazyBone
    • Jun 2023
    • 1435
    • United states
    • Anything I can do with my hands
    Pictures of the led driver also. Get a close up of it to see any test points
    Some Samsung's have bad led drivers. It's not out of the question that a zone of leds went bad either. Mini led hard to test LEDs without taking the thing apart (that I know of)
    • Vdaimo
      • May 2026
      • India
      Thanks for replying.
      I tried disconnecting led ribbon cables of each zone one at a time. Still doesn't work.
      • Vdaimo
        • May 2026
        • India
        • EazyBone
          • Jun 2023
          • 1435
          • United states
          Disconnecting each ribbon won't diagnose it for you.
          Somehow need to test the leds
          • Gjackson
            Samsung UE75TU7090 backlight or PSU fault?
            by Gjackson
            I have a Samsung UE75TU7090 with PSU board BN44-01056A (L75S6N_THS) with a backlight fault. With both backlight connectors unplugged the TV boots normally with a stable 12V rail. With the backlight connected the TV fails to start, Channel 1 (rated 115V) folds back to around 20V, Channel 2 (rated 70V) drops to 0V, and the 12V rail collapses to 3.1V. With the backlight disconnected and powered on, Channel 2 ramps up to around 230V open circuit while Channel 1 sits at 0V.
            Since the TV boots fine with the backlight unplugged I'm leaning towards a shorted LED strip causing...
            05-31-2026, 03:15 PM
          • Boardview and Schematic Bot
            09-07-2024, 05:50 AM
          • kevin_allein
            Samsung GU65TU8079U backlight problem
            by kevin_allein
            Hi, I have a Samsung GU65TU8079U, where the backlight is not working. I started with the typical Samsung test to disconnect the mainboard, still no backlight comes up.
            Next I took out the PSU and took it to the bench. 13 V are there and also ~280 V on the LED connector (with nothing connected).
            Now I am struggling with the connector pinout. On the component side of the PCB I find this label:
            Also on the backside there is an identical pinout.
            However that pinout does not make any sense looking at the traces. Pin 1 is the positive...
            05-11-2026, 11:46 AM
          • hartleyhare5
            Samsung QE65Q9FN — BN44-00944A (65A board) MOSFET failure (relay clicking on one connect) — advice before power-up
            by hartleyhare5
            Post body:
            I'm working on my Samsung QE65Q9FN (65" Q9FN QLED, European model) with relay clicking and no picture. The power supply board in the display itself is the BN44-00944A, known on the board itself as the 65A board (silk-screened designation). There is also a second board, the 65B, which looks identical but is only partly populated for the LED power.
            Symptom: Continuous relay clicking on the one connect — TV will not start up, no picture. However the standby LED is on constantly — so the standby supply rail appears to be alive and the...
            03-26-2026, 03:47 AM
          • sansanpartida
            Samsung QE82Q70RAT no backlight
            by sansanpartida
            Hi everyone!
            Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
            My issue: No backlight.
            Model: QE82Q70RAT
            Type No: QE82Q70RAT
            The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
            So hopefully, I can fix this cheaper.
            05-22-2024, 06:56 AM
