Hisense 50" 50A6KV VIDAA TV Washed Out White Screen Problem
  • tech9pc
    • Sep 2021
    • 53
    Hisense 50" 50A6KV VIDAA TV Washed Out White Screen Problem. 2025 Model only about 1yr old. Puzzling because everything works except whited out screen barely visible picture. Screen is not cracked. Any ideas / suggestions? Would this be a all in one mainboard problem or is the screen failed. When on can barely see the image on screen, connects to WiFi and everything. Took back off and mainboard looks clean and new, reseated cables. Tried resetting the system to factory and it is the latest update May 2026. I researched this model online and apparently in the last 12 months about 2 out of every 10 people that bought from Costco got a tv with same issue white screen or sometimes green screen lol. I'm not complaining was free but maybe someone has ran into this model and problem in last 12 months. Otherwise trash lol .. and most places want 100.00 for just for a mainboard lol. NOT!
  • Diah
    • Feb 2013
    • 6763
    how about to upload photos of yours panel buffer boards ??
    • frannyjunk
      Hisense 40H4F no backlight but turns off after splash screen
      by frannyjunk
      So I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
      TIA.
      09-24-2025, 10:59 AM
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • odie34
      TCL 55S451 Stuck on Logo Screen But Working Otherwise
      by odie34
      I have a TCL 55S451 that's stuck on the logo screen. I've done all of the traditional troubleshooting steps (power cycling, holding the reset button, etc.), but nothing has worked. I thought the main board was dead, but then I realized that even though it was only showing the logo screen, it appeared to be responding to remote buttons.
      So I pressed the reset button again and used the remote to put the TV into screen reader mode. I was then able to navigate through the setup menus (including successfully connecting to the internet) in order to update the firmware. I thought that that...
      04-25-2026, 03:40 PM
    • reformatt
      by reformatt
      07-31-2025, 08:37 PM
    • smic717394
      by smic717394
      07-25-2024, 10:16 AM
