samsung le32a457 bad cap symtoms but look okay
  • selldoor
    Slow Learner
    • 7870
    Re: samsung le32a457 bad cap symtoms but look okay
    Did you remove ALL the yellow/brown glue.
    I cant see that you got an answer to why, which is, as it ages, and with heat the glue becomes corrosive and as it turns brown conductive rotting traces and shorting out
    components.
    EDIT
    Did you replace all the caps budm said - there is a group of 4 to the right of the Big yellow transformer, one of which is the startup cap.
    Check over all your soldering and can you post a clear picture of the bottom of the board.
    • steveo3002
      • Nov 2014
      • 23
      • england
      ive replaced the 7 bigger caps on the top half of the picture
      no i did not touch the glue as i didnt get an answer on how or why
      will post a pic later..
        This is what bad glue can do to the board.
        https://www.badcaps.net/forum/showthread.php?t=34692
        • steveo3002
          • Nov 2014
          • 23
          • england
          heres 2 pics
          looks a bit shabby to my untrained eyes , lots of residue etc?? its never been wet or mistreated owned sinse new
          sometimes trys and trys to come on , flicks on then trys again and eventualy comes on
          • selldoor
            Slow Learner
            • 7870
            How to remove the glue: with great care , not to damage traces or components. It is not easy people have their own favourite tool.
            Dental pick, awl, sharpened toothbrush handle (chisel tip or point)
            Sometimes the glue can be softened a little with IPA.
            Do a bit at a time so you dont loose concentration.
            • selldoor
              Slow Learner
              • 7870
              #26
              The Trys and Trys to come on could be the startup cap what values are the 4 small ones.
              it is often a 50v 68uf
              • steveo3002
                • Nov 2014
                • 23
                • england
                #27
                the 4 are
                all 105 deg
                470uf 25v
                680uf 25v (35v now fitted)
                680uf 35v
                3300 uf 10v
                would it also make the tv turn off
                edit - during the off and wont come on , the led can either be off or on
                  I am sure the small caps do not come with the kit.
                  • steveo3002
                    • Nov 2014
                    • 23
                    • england
                    #29
                    budm - what kit ?
                    i looked on ebay and most were 3 or 4 parts , sellers wouldnt say which ones , so i figured i would order all the big ones in the hopes it would replace the faulty one but no lol
                      My thought would be main board issues. If the power board voltages are ok, then it is probably the main board at fault.
                      • selldoor
                        Slow Learner
                        • 7870
                        #31
                        Originally posted by steveo3002
                        the 4 are
                        all 105 deg
                        470uf 25v
                        680uf 35v
                        3300 uf 10v
                        Probably not I have been looking at the back of the boards as it may be a
                        bad joint or crack in the solder. Best way is to go over it all with a magnifying glass. I felt one or two were a bit iffy but can you have a look at this one.
                        I recommend removing the old solder and applying fresh.
                        • steveo3002
                          • Nov 2014
                          • 23
                          • england
                          #32
                          i think thats one ive already reheated ..it did sizzle though is that normal?
                          i can go back and remove and replace the solder
                            If a solder joint is sizzling, your soldering iron is probably far too hot.
                            • steveo3002
                              • Nov 2014
                              • 23
                              • england
                              #34
                              just that one in the pic sizzled ..none of the others did
                              just a little antex 20w iron
                              • Caleb
                                Smokin IC's
                                • Feb 2013
                                • 645
                                My favorite method for removing glue is using the canned air upside down to super freeze it first then it chips off easily.
                                Liberating magic smoke one part at a time
                                • selldoor
                                  Slow Learner
                                  • 7870
                                  #36
                                  - not heard that one before - I like it
                                    I use an old toothbrush and IPA - most glues will be dissolved by the IPA.
                                      09-07-2024, 05:50 AM
                                      09-06-2024, 11:40 PM
                                      09-06-2024, 08:40 PM
                                      Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                                      This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      09-06-2024, 06:20 PM
