LG LG50PS20 has 3" of vertical lines on the right side of the screen. The problem is intermittent. Not familiar with plasma. Sounds like a bad solder joint but not sure where to start.
LG LG50PG20 has 3" of vertical black lines
Tags: None
Re: LG LG50PG20 has 3" of vertical black lines
Could be loose connection on C-board (address buffers)Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
I have to make a correction, the model is a LG50PG20. Can I change that in the original thread?Comment
by FirentiosiThanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
The issues are as follows: the...2 Photos -
by Stanley1843Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
by Ancient1Hi
Asking for a friend.
I'm used to black vertical line in otherwise good image - probable solution is a rubber to push and tighten the COFs bonding.
but here its the opposite !
TV has new T-con = same issue
A missing panel voltage would have global effect
So , what should one do ? how can I find where the fault is ?
Thanks !... -
Can experts please share their opinion on this issue where i have a black spot and vertical lines all over the screen.
Is this fixable or needs a new panel?... -
by FalkiHello there, ive recently found an older 55inch Samsung SmartTV.
A similar issue has been posted as well but also with no actual response ...6 Photos - Loading...
