TV Antenna setup
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: TV Antenna setup
    well its got line of sight which will be nice when its de-treed. like i said the picture is perfect and if it wasnt i was gonna go on the roof. personally i dont like it up there cos its really slanted not like the older 70s apartments where you could hold a party up there.
    imho i like all my stuff really accessible. here it has 2m cable to the tv
    • Hondaman
      Single-channel antenna?
      by Hondaman
      Recently I switched from my Gray-Hoverman to the Antennas Direct ClearStream 4 MAX. Seems to work about as well as the old G-H in my attic (one-story ranch home), but the Antennas Direct unit can be mounted outside on my chimney if desired.
      I should mention that I was also using a 29-inch "T" shaped antenna for RF channel 11. I know you're not supposed to use TWO antennas unless they have the same length coaxial cable going into your combiner (and even then there might be problems). So I made sure the cables were equal length.
      Years ago I made a "T"...
      11-18-2024, 01:14 AM
    • Chaks
      Ground Plane For 5dBi ISM Band 865-870Mhz Embedded Ceramic Antenna
      by Chaks
      TAOGLAS ANTENNA MODEL: ISPC.86A.09.0092E
      The specs says ...
      High antenna efficiency 868MHz ISM Band
      5dBi Peak (when placed on 30cm x30cm ground plane) - Broadside to Zenith Radiation Pattern
      The antenna is 50x50 mm square and How do I fix it on the Ground Plane of 300 x 300 mm (aluminium sheet 3mm thick).
      1. Should I Fix it with a glue.
      2. Should I fix it with a double side adhesive tape
      3. Should I fix it with Screws (the screw head may just clamp the antenna to the aluminium...
      12-09-2024, 11:06 AM
    • howardc64
      Samsung UN55JU650DF network/streaming problem
      by howardc64
      Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
      This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
      07-09-2025, 12:44 PM
    • Hondaman
      Gray-Hoverman antenna
      by Hondaman
      Hello all,
      Recently I'm upgrading my Gray-Hoverman antenna. Original design. I cannot use a "double-stacked" antenna because of attic space. I do not wish to mount anything to my chimney.
      I am using a separate antenna for WHAS Channel 11 (they are using RF Channel 11, 198-205 MHz). I replaced my 29-inch "T" antenna made out of #12 or #10 wire. I made a 58-inch "T" antenna out of 0.25-inch copper tubing. Hooked it up with a matching transformer to the 75-ohm coax going to my TV. I held the "T" antenna up against my ceiling, less...
      10-16-2021, 05:28 PM
    • SolomonMan
      Antenna...
      by SolomonMan
      All,
      I recently moved to a very rural area. I am about 25 miles from the nearest urban settings (2 separate College Towns). 45-50 miles from a Urban City (Toledo Ohio)
      There was a Omni-directional Wineguard Antenna (amplified) that was mounted on the house originally. Came with the house. Center of the top of Roof a few feet from Chimney on a 4 foot pole. The 75 ohm line went from the roof down 2-3 stories to the small Wineguard amplifier and then it split to the living room and master bedroom. Currently a Very simple setup.
      Since we moved in, 8 years ago,...
      10-05-2023, 02:37 PM
