TCL 55S451 Stuck on Logo Screen But Working Otherwise
  • odie34
    • May 2016
    • 56
    I have a TCL 55S451 that's stuck on the logo screen. I've done all of the traditional troubleshooting steps (power cycling, holding the reset button, etc.), but nothing has worked. I thought the main board was dead, but then I realized that even though it was only showing the logo screen, it appeared to be responding to remote buttons.
    So I pressed the reset button again and used the remote to put the TV into screen reader mode. I was then able to navigate through the setup menus (including successfully connecting to the internet) in order to update the firmware. I thought that that might resolve it, but unfortunately it didn't.
    A few other bits of information:
    • The logo screen begins to fade after a few seconds, and after a couple of minutes the screen is completely black. This doesn't appear to be a screen or backlight issue, as pressing the reset button instantly restores the logo screen.
    • Holding the reset button for 30 seconds is supposed to restart the setup, but in my case it simply leaves a blank screen. A simple press of the reset button will cause the logo screen to be displayed.
    • A visual inspection shows no indication of a problem. (No burns, bulging caps, etc.)
    • I'm a hobbyist whose handy with this stuff, but I have no real training so please be gentle.
    I don't see a separate TCon board in this TV, so I'm wondering if that functionality is combined on the main board. If so then perhaps there's still an issue on the main board even though it appears to be working otherwise. I was also wondering if a bad cable could be causing this. (I once had an issue with an external Roku box connected to a TV via a bad HDMI cable. In that case the menus were displayed properly, but the streaming content wasn't displayed at all.)
    Any thoughts on next steps? Your input would be much appreciated.
    Thanks!
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8721
    Pictures… pictures… pictures…
    • EazyBone
      • Jun 2023
      • 1434
      • United states
      • Anything I can do with my hands
      Try to see if disconnecting one ribbon cable to the screen at a time will change anything. Maybe it will stay on fully if you do that.
      • odie34
        • May 2016
        • 56
        Here's a picture of the boards:
Name:	Back of TV.jpg
        I can send close-ups (or remove them and send pics of the reverse side) if anyone needs to see more detail.
        FYI, Here's what the screen looks like when I first reset it, then after about a minute, and then after about a minute more...
Name:	Initial Logo Screen.jpg
Name:	After Several Seconds.jpg
Name:	After a Minute or Two.jpg
        • odie34
          • May 2016
          • 56
          EazyBone The problem isn't that the logo screen fades. The problem is that the TV doesn't progress past it to the Roku menus.
          • EazyBone
            • Jun 2023
            • 1434
            • United states
            Yea I still wrote what I wrote for you to try it.
            TV repair is process of elimination. You have an odd problem where screen fades AND is stuck. So I gave my suggestion. Haven't seen this problem before either but now that we have pictures I would assume main board also. The screen fading doesn't look too much like it's backlights but who knows
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8721
              Kinds similar what my TCL Amazon TV did. There is a mile long thread if you search my nickname. I heard the startup chime, had backlights, but black screen and it wouldn’t boot.
              Problem is to find correct full images. The best version TCL TV to get is the Google TV one as it has most support in the community plus there are a lot of eMMC images available. Firmware updates don’t contain everything. We tried flashing my Amazon TCL to no avail and ended up purchasing a new board for like CAD$65 on eBay and replace it and the TV is still going.
              A while later I tried to look at that old main board. Confirmed it being a software issue at Boot. But to lack of Amazon TCL version dumps I junked the board and use it for parts.
              It seems to me the TCL’s main boards that don’t have a reset button, have very slim success rate of being fixable.
              • Diah
                • Feb 2013
                • 6703
                ROKU / GOOGLE / AMAZOON / ANDROID TV are same shoes source, try to push the Joystick and pull it down the plug in wall socket show us the Recovery menu you got.
                • EazyBone
                  • Jun 2023
                  • 1434
                  • United states
                  Yea but the TCL roku main boards are like $20 in america. Not even worth flashing an EMMC for that. In canada maybe
                  • odie34
                    • May 2016
                    • 56
                    I'm not able to get a recovery menu. To be clear, there is a reset button that I'm able to push, but the screen just goes blank if I hold it for 30 seconds or so. Otherwise all I ever see is the logo screen (which fades out over a few minutes).
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8721
                      Try a firmware update. I remember my TCL didn’t have that recovery menu either. Other than that you need a full dump and flash that.
                      • odie34
                        • May 2016
                        • 56
                        A firmware update is complicated without a screen, but I was able to use the text-to-speech mode to get it done. Unfortunately that didn't help. I was told that the firmware update doesn't necessarily update everything, so it still may be a software issue. Unfortunately I don't have the ability to reflash the entire chip.
                        • lotas
                          • Jan 2016
                          • 5381
                          • Russia
                          If the eMMC is dying or has already died, then no reset, recovery, or update will help; only replacing the eMMC or replacing it with a working motherboard will help.
                          • odie34
                            • May 2016
                            • 56
                            Thanks for the confirmation. I had pretty much come to that conclusion as well. I'm going to get a new main board and let everyone know the result.
                              Back Again?
                              • 32695
                              eMMC/NAND failure is unfortunately killing a lot of embedded devices. Many times I see the mistake of putting these chips right near CPU since signals need to go that way, but the CPU runs hot and NAND flash hates the heat.
                              Suggestions for extending the life:
                              - Keep TV out of direct sunlight if possible
                              - Consider adding a fan to the mainboard area if possible
                              - Turn off smart standby features. TV might take longer to boot up but will wear chip less
                              - Uninstall background services where possible, if it runs Android
                              For service manual, bios, schematic, boardview (board view), datasheet, cad - use our search.
                              Subscribe to support us. It only takes 1 minute: https://www.badcaps.net/settings/subscriptions
                              • CapLeaker
                                Leaking Member
                                • Dec 2014
                                • 8721
                                I am just about willing to bet, that there is nothing wrong with the EMMC.
                                • lotas
                                  • Jan 2016
                                  • 5381
                                  • Russia
                                  I don't know if it's expensive or not, but they're selling a motherboard for your TV.
                                  https://www.ebay.com/itm/266554778927
                                  • lotas
                                    • Jan 2016
                                    • 5381
                                    • Russia
                                    No one is arguing here, this is just a guess, it could be the SoC that is faulty via HDMI or LAN port, or maybe the RAM... here you need to connect to UART and look at the boot log to see where the problem is occurring.
                                    • CapLeaker
                                      Leaking Member
                                      • Dec 2014
                                      • 8721
                                      Absolutely agree, lotas.
                                      I just remember my TCL we tried to fix.
                                      • Stunt
                                        Hp Laptop Stuck on Hp protected by hp sure start screen
                                        by Stunt
                                        Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                                        I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                                        I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                                        Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                                        screen that's it and stuck there. I left it until the following day and i still...
                                        09-02-2025, 01:51 PM
                                      • fredyjbi
                                        Please help me, my friend Dell 5420 La-k491p bios recovery failed stuck on logo, thank you
                                        by fredyjbi
                                        Please help my friend Dell 5420 La-k491p rev 2.0 vpro ST.BZD1JQ3 laptop turns on but error bios recovery failed stuck on logo thank you...
                                        05-08-2026, 11:34 PM
                                      • jbaranas
                                        Sony KD-55X8000C - No picture, shows Sony Logo but blue screen after
                                        by jbaranas
                                        Hello Everyone!
                                        i am having trouble with my TV, my friend gave it to me and he told me he got it from somewhere so that is why I did not know the history of it.
                                        When turning on, it shows Sony Logo, then solid blue screen after. Then nothing just stay that way.
                                        I bought Main Board from ebay then T-Con from Aliexpress. Replaced Main board, the TV improved it is like booting up to dashboard, then I put on my chromecast and I try to play youtube videos with it but no picture. I then try remove LDVS from old t-con, then it asks for update showing green and orange...
                                        06-11-2026, 01:39 AM
                                      • NXTPRO
                                        Sony Bravia KD-55X8000G stuck at Sony Logo
                                        by NXTPRO
                                        My Sony KD-55X8000G TV is stuck on the Sony logo. I tried disconnecting LVDS and turning it on again, but the TV only showed a white LED (not blinking) and nothing else. Then, I reconnected LVDS, and it still only showed a white LED with the Sony logo. It seems it's not entering update mode. When I used a USB drive and named the firmware file upgrade_loader.pkg, the TV displayed "Updating..."(Sample image attached) but after about a quarter of the process, it restarted and got stuck on the Sony logo.
                                        Board: 1-982-454-51
                                        04-03-2026, 07:28 PM
                                      • conghuyms
                                        MacBook Air A2179 stuck logo , pls help me !
                                        by conghuyms
                                        Hey everyone,
                                        I’ve got a MacBook Air A2179 that got some water damage through the keyboard. Now it powers on, shows the Apple logo, but just stays stuck there — no startup chime, no keyboard backlight, and no progress bar under the Apple logo.
                                        When I try to boot into Internet Recovery (Option + Command + R), the mouse cursor is extremely slow and laggy — like when I lift my finger off the trackpad, the cursor keeps drifting slowly for a second or two.
                                        I opened it up and found some corrosion around the LED driver IC area on the logic board. I cleaned...
                                        11-05-2025, 08:30 AM
