LG 60UH605V no picture no sound no backlights
  • notallbad
    • Oct 2012
    • 1200
    • Save the techie from asking silly questions giving them more time to solve isuues
    psu : EAX66923301 (V1.3)
    main : EAX66882503 (V1.0)
    tcon : 6870C-0628A (V0.2)
    panel : LC600EGE
    2016 model
    TV red standby light comes on when plugged in, press remote on button or tv power on button and standby light flashes 3 times, exactly the same with tcon disconnected from main or either left or right panel ribbon cables disconnected.
    There are no diagnostic leds on psu or main that I can see.
    No faint or dim picture visible, no backlights, no sound.
    psu stby voltages (with main connected or disconnected) are
    ms 0v
    gnd 0v
    13.2v 8v bouncing
    13.2v 8v bouncing
    gnd 0v
    pwr-on 0v
    p-dim1 1.88v
    gnd 0v
    13.2v 8v bouncing
    13.2v 8v bouncing
    13.2v 8v bouncing
    p-dim2 1.88v
    psu on voltages are
    ms 0v
    gnd 0v
    13.2v 13.1v
    13.2v 13.1v
    gnd 0v
    pwr-on 3.38v
    p-dim1 0.27v
    gnd 0v
    13.2v 13.1v
    13.2v 13.1v
    13.2v 13.1v
    p-dim2 0.27v
    both led output circuits show 190v stby
    both led output circuits show 320v on
    tcon fuse has 13v on both sides.
    Led tester shows 179v powering both led strips which are strips of 66leds.
    Is this looking more like a panel issue? or are there other checks before condemning.
  • notallbad
    • Oct 2012
    • 1200
    So looking like its more likely the psu or main, what I have noticed is that the spdif out (optic) port does not light up and usually on main boards they light up with a red led, there seems to be power at the usb port as it powers a hdmi streaming stick.
    So from this I would suspect the main board to be most likely at fault but not knowing what voltages should be on the psu, other than the obvious 13.2v, like the ms pin, what is the ms pin as it reads 0v in stby or when switched on.
    To replace the psu or main would be too expensive to chance as both are equally highly priced for an old model tv.
    • notallbad
      • Oct 2012
      • 1200
      So, it would seem I'm missing the MS pin 2.1v signal from the Main board. All other pin voltages seem ok.
      • notallbad
        • Oct 2012
        • 1200
        Found an LG main and power board from a different tv in my spares shed which has the same pinouts on the psu to main.
        So I can get the backlights on at least with the spare main board so looks like psu and backlights ok but as it has a different tcon (doesnt actually have a tcon, connects directly to panel) I cant test the screen so looks like I need to get a replacement main and hope the screen is ok. Had a look at the main and cant find anything obvious other than the main soc chip has very hard thermal paste so my guess is its cooked, if its not then quite sure the issue is firmware so either way beyond repair I guess.
        • notallbad
          • Oct 2012
          • 1200
          So having sourced a main bd, well actually its from a 60UH625V-ZA.BEKWLJP, but says compatible with 60UH605V-ZC.BEKWLJP, dont suppose anyones able to confirm this is correct?
          TV now powering on however picture has the odd few horizontal blacks lines, some go then come back, others just permanently stay and also screen shadowing - almost certainly looks like a panel issue or could it be the main needs settings changed to be a 60UH605V so it has correct configuration for the tcon/panel.
          Any advice on testing to determine if it is a panel issue? Inspected top and underside of panel tabs and no obvious signs of burnt/shorted panel or tab ribbons.
          • notallbad
            • Oct 2012
            • 1200
            Yes, can confirm its working and compatible.
            Issue sorted and working fine.
              Back Again?
              • 32756
              How did you resolve the issue, for others who may have this problem in the future?
              For service manual, bios, schematic, boardview (board view), datasheet, cad - use our search.
              Subscribe to support us. It only takes 1 minute: https://www.badcaps.net/settings/subscriptions
              • ChaosLegionnaire
                by ChaosLegionnaire
                09-13-2022, 09:02 AM
              • mecha1166
                KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen.
                by mecha1166
                KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen. Already tried reset POWER/VOL-. Anyone else have this problem? Possibly bad T-Con RUNTK4244ZZ or panel? Could main or power supply cause this? There were 2 blown 560u 35v on power going to backlights but they were still working fine. Thanks for your help.
                11-25-2024, 05:22 PM
              • stinger
                Samsung UN70TU6980FXZA no sound no picture but does have backlights
                by stinger
                When I turn tv on, the backlights come on but there is no sound or picture. I have read that these tv's have problems with the panels going bad but the "no sound" has me questioning if the main board is bad. Is there a way to troubleshoot the main board to determine if that is the problem?
                04-17-2024, 03:06 PM
              • LEECH666
                Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                by LEECH666
                Good day ladies and gentleman!
                I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                01-19-2024, 05:46 PM
              • Christos Tsiligiannis
                Marian Trace Alpha sound card repair help
                by Christos Tsiligiannis
                Hello to the forum.
                My name is Christos, I am new to the forum here and i am posting from Greece.
                So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                So i tried asking for a schematic from the company and they would not give me one. Instead they...
                11-18-2024, 05:26 AM
