32 inch lcd sound no picture
  • gobby009
    replied
    Re: 32 inch lcd sound no picture
    update= grabbed a mainboard from ebay same board number just my board was a rev 6 this board i got of ebay is a rev 8 fitted the board tv works ok just the picture is a little dark.after examaning the board i got of ebay i noticed it has sum bulging caps on it and i think one cap is leaking.could this be the problem with dark picture?or is it because its a different rev number.
  • gobby009
    replied
    tv was on all last night working fine on hd connection went to turn tv on this morning with hd connection lost picture after 3 minutes.backlights are on and so is audio.would it be worth putting some heat to the over the back of the mainboard with a heat gun.
  • gobby009
    replied
    so do you think the bad part of the board is where the scart and svideo connections are as they are down the side and the hd is on the underneath
  • ReeceyBurger123
    replied
    Originally posted by gobby009
    no the backlights were on with those voltage readings,tv has been on around 6 hours now on hd connection with no loss of picture
    Bad mainboard then, you can get the for cheap on ebay.
  • gobby009
    replied
    Originally posted by budm
    So those Voltage readings on the inverter connector as shown when the backlights are not on?
    https://www.badcaps.net/forum/attach...2&d=1414623817
  • ReeceyBurger123
    replied
    so the problem with this tv is that from a cold start it would work for like an hour then loose picture but not sound with scart,tried svideo yesterday and the same.got sky hd plugged in today and its been going for 3 to 4 hours and hasnt lost picture yet.gonna leave it plugged into the sky hd all night and i will report back if it does loose picture.i plugged it into the sky hd to try and get a picture that reecey requested when it does loose picture but as i say its been going 3 to 4 hours on a hd connection with no loss of picture.
    Sounds like there is a motherboard fault probably cold solder joins under one of the chips.
    replied
  • gobby009
    replied
  • ReeceyBurger123
    replied
    Can you take a picture of the sceen with the set on so we can see if the backlights are on or not.
  • gobby009
    replied
    hope you can read the readings
  • gobby009
    replied
    ok took some voltage readings hope you can read them.this was with the tv on.
    picture 1 is the inverter plug on the mainboard
    picture 2 is the psu
    picture 3 is the mainboard from psu
    again any help is appreciated.
  • ReeceyBurger123
    replied
    took the plug out of the socket and the pins on the mainboard are fine as are the clips inside the plug.is there a way to cut that burnt looking cable back and reinsert it into the plug.looks like its hanging on by a thread.
    Ok now put the inverter back in and set your meter to 20-200v dc then put the black probe to a ground then use the red probe to see if there is a voltage going though the connectors to the inverter while the set is on, can you get the model numbers of the psu ect and I will find a pin out diagram and show you where to test.
  • ReeceyBurger123
    replied
    this is my multimeter.as i say i am new to this kind of operation i have repaired things like ghd cables ghd fuses iphone screens but there basicly taking things apart and replacing voltage troubleshooting is all new to me i do appreciate your help on this
    To test that cable simply set your meter to ohms and the probe on one end of the wire and on the pin out on the bottom of the inverter and see if the ammount of ohms changes this will show if there is a connection or not make sure the set is off, also pull the wire block out of the connector and inspect it physically then resolder it if it is loose.
  • gobby009
    replied
  • vinceroger69
    replied
    so these are some pics as you can see in the inverter cable at the top of the mainboard not sure if that looks like a burnt cable second from the end,could that be the cause? as you can see there is no way to test the inverter while its connected to the mainboards as it is under the main chasse.i took a picture of the old inverter i pulled out.can i check voltage from mainboard to inverter from that inverter cable at the top of the mainboard.once again any help is appreciated.
    picture 6 the plug/socket with the damaged wire can you pull the wire block out and check the pins to see if they are melted or damaged.
  • gobby009
    replied
  • ReeceyBurger123
    replied
    could you explain in detail how i do this.im new to a multimeter.do i put the red and black cable of the multimeter in the red and black on the mainboard inverter connector.did you notice the burnt cable in that picture?and how would i check the psu.thanks in advance
    Can you take a picture of your meter please just help clarify things better.
  • gobby009
    replied
  • ReeceyBurger123
    replied
    Check if the psu and motherboard are giving voltage to the inverter, dont test the inverter only test the connectors coming off the psu/mainboard.
  • gobby009
    replied
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
  • TR103
    by TR103
    - it keeps rebooting
    01-22-2025, 04:12 PM
  • howardc64
    by howardc64
    07-24-2025, 05:17 PM
  • slimmy182
    [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
    by slimmy182
    Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
    I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
    Looking on google I found this:...
    01-14-2023, 11:55 AM
