Hello the tv is Sony 65" flickering . I tried my best by taping the corner of the ribbon one by one. Nothing changes anyone knows if there is another way to solve the issue?
Sony kd-65xd7505 flickring
by NXTPROMy Sony KD-55X8000G TV is stuck on the Sony logo. I tried disconnecting LVDS and turning it on again, but the TV only showed a white LED (not blinking) and nothing else. Then, I reconnected LVDS, and it still only showed a white LED with the Sony logo. It seems it's not entering update mode. When I used a USB drive and named the firmware file upgrade_loader.pkg, the TV displayed "Updating..."(Sample image attached) but after about a quarter of the process, it restarted and got stuck on the Sony logo.
Board: 1-982-454-51
...04-03-2026, 07:28 PM -
by rzsnHi, I have got for myself this fancy unused board (no usage markings on mounting holes) with a damaged corner.
The damage looks like to be in not that important corner - not much of components, so not expecting lot of traces.
Is there a chance to get Gerber files or a PCB design screenshot - or board views are most one can get from the east?
What would be your choice of repair?
I was to cut the corner off with the thinnest saw I could find and the analyze the piece alone.
But then - I do not want to loose any potential sign of trace (that...1 Photo01-15-2026, 06:18 PM -
by Carlos#2003%Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
by reessiHello,
The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
They are black on the right and gradually fade to nothing on the far left.
They start either after 5 mins or up to 2 hours after so annoying for testing.
They flicker continuously very fast! With a slight pause milli-second every second.
Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
I tested each half by removing the first the left flex from...-
by LINCKODEHello!
I have a Sony Bravia(the specific model is in the title) that is exhibiting the following behaviors:
- Color inversion on the whole screen(or rather it has trouble displaying gray and black correctly)
- Static-like flickering on the dark parts of an image(it will flicker between black and white on some dark parts of an image)
- Bad image detail/sharpness
These issues switch between each other from time to time.
After consulting some online resources and the LCD TV troubleshooting guide I found on this forum, I believe I am... - Loading...
