philips 37pf7320/102140 and
  • willyam1
    • Feb 2012
    • 112
    • israel
    dears
    power up can hear click and go back to stby red led is on by powering again red led is off no green led not powering up no relay clicks no backlight nothing
    5v stby ok 3,3vstby ok
    by forcing stby pin 7 in stby/audio board plug 1m03 to gnd can hear clicks relay is on power supply main is working ther 24v 12v 18v and -18v but still no backlight no comand to bl on i check r 3318 in the main power supply is ok100 ohm.its seems that the problem is in the main board and its in protection mode
    in the stb/audio board i check the 11v stby in the catode ofdiode 6140 and also in capi the reading is 23v and going down slowly any idia?
    willyam
  • Rensiee
    Panasonic TH-50PX8EA Black screen, only relay clicks
    by Rensiee
    I have been reading a few threads on here regarding Panasonic plasma tv's. I've found one thread which explains the same problem as mine, unfortunately the thread has not been completed.
    I got a free tv (TH-50PX8EA) from a friend which shows no screen. When plugged in only one red light shows up and when pushing the ON button, the red LED turns of and will only turn on again when pressing the ON button again.
    When plugging in the TV i hear two relays click fast and after a few seconds the third relay clicks.
    I have measured the voltage in the VSUS line, which...
    06-18-2024, 12:58 PM
  • thstuff
    Sony OLED XR-77A80J - Initially dead, now 4 Flashes
    by thstuff
    A) TV initially dead
    B) On a hunch of a locked up Google OS, plugged in a USB memory stick with latest FW and plugged it in. It booted into the update screen, completed the update and restarted to Home screen.
    C) Was able to perform a Reset from Settings menu and completed out of box configuration.
    D) Ran a 4K screen saver demo for about 6 hours, then turned it off for the day. Did not notice any stripes, dead zones or other artifacts in the image.
    E) Powered back on and it now runs for a few minutes before relay clicks, screen goes blank, Main Board Red Digital Optical...
    12-26-2024, 09:10 PM
    Samsung LN46b530p7f – relay clicks and backlight cycling, sound OK
    by momaka
    I got this TV a little over a year ago from a coworker from my previous job. It’s a Samsung 46” TV, model number LN46b530p7f.
    Problem:
    Backlight cycles On and Off.
    Basically, when the TV is turned On, there is a relay click heard from the TV PS board. The relay cycles On and Off 4 times in about 2-3 second intervals. Each of those 4 times, the backlights also cycle On and Off with the relay. The screen TFT isn’t cracked/damaged and appears to work - I can see a “no signal” image when the backlights turn On briefly – though the image is a bit dull/dark....
    01-17-2019, 11:23 PM
  • samtron786
    toshiba 46xv555d relay clicks
    by samtron786
    Hello
    The red and green LEDs both light up and you can hear the relay click. (no picture, no backlight, no sound)
    2-3 seconds later the relay will click again and only the red LED will stay on.
    I would be very grateful for any advice or a little help.
    circuit diagram?
    Thanks very much
    02-04-2023, 04:39 PM
  • CoinCoin88
    Garage door RX unit (Cardin S38C) does not short relay to send opening signal
    by CoinCoin88
    I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
    Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
    09-15-2025, 03:36 AM
