Sony Bravia KD-55X8000G stuck at Sony Logo
  • NXTPRO
    • Apr 2026
    • 5
    • Vietnam
    My Sony KD-55X8000G TV is stuck on the Sony logo. I tried disconnecting LVDS and turning it on again, but the TV only showed a white LED (not blinking) and nothing else. Then, I reconnected LVDS, and it still only showed a white LED with the Sony logo. It seems it's not entering update mode. When I used a USB drive and named the firmware file upgrade_loader.pkg, the TV displayed "Updating..."(Sample image attached) but after about a quarter of the process, it restarted and got stuck on the Sony logo.
    Board: 1-982-454-51
ID:	3851007Click image for larger version
ID:	3851008Click image for larger version
  • fredyjbi
    Please help me, my friend Dell 5420 La-k491p bios recovery failed stuck on logo, thank you
    by fredyjbi
    Please help my friend Dell 5420 La-k491p rev 2.0 vpro ST.BZD1JQ3 laptop turns on but error bios recovery failed stuck on logo thank you...
    05-08-2026, 11:34 PM
  • odie34
    TCL 55S451 Stuck on Logo Screen But Working Otherwise
    by odie34
    I have a TCL 55S451 that's stuck on the logo screen. I've done all of the traditional troubleshooting steps (power cycling, holding the reset button, etc.), but nothing has worked. I thought the main board was dead, but then I realized that even though it was only showing the logo screen, it appeared to be responding to remote buttons.
    So I pressed the reset button again and used the remote to put the TV into screen reader mode. I was then able to navigate through the setup menus (including successfully connecting to the internet) in order to update the firmware. I thought that that...
    04-25-2026, 03:40 PM
  • conghuyms
    MacBook Air A2179 stuck logo , pls help me !
    by conghuyms
    Hey everyone,
    I’ve got a MacBook Air A2179 that got some water damage through the keyboard. Now it powers on, shows the Apple logo, but just stays stuck there — no startup chime, no keyboard backlight, and no progress bar under the Apple logo.
    When I try to boot into Internet Recovery (Option + Command + R), the mouse cursor is extremely slow and laggy — like when I lift my finger off the trackpad, the cursor keeps drifting slowly for a second or two.
    I opened it up and found some corrosion around the LED driver IC area on the logic board. I cleaned...
    11-05-2025, 08:30 AM
  • JUCaESAl
    Sony bravia KD-65AF9
    by JUCaESAl
    Hola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
    Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television.
    10-20-2025, 04:03 AM
  • G33RT
    Philips 8200 series 65PUS8204/12 stuck at Philips Logo
    by G33RT
    Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
    It does power up when pressing the power button.
    I already try the power button while plugin the plug with no result.
    Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
    Could this be an PSU or eMMC issue ?
    07-19-2025, 03:43 AM
