Samsung UN70TU7000FXZX A two-times flashing standby light loop with no image.
  • alro7779
    Alex
    • May 2025
    • 97
    • Mexico
    Hello, everyone!
    A friend of mine gave me a 70" Samsung TV that does not show image after pressing the power button... It's in a loop with the standby red light flashing two times while the TV tries to power on with a startup sound. You see, it occurs to me that I could try keep learning how to repair TVs out of this device, so I'll share some pics I took after taking the back cover out; I noticed that someone tried to repair it (or did it at some point) because I found a small power supply glued on the metal cover by the mainboard (3.3v IN and 13v OUT). The idea here is checking the problem on this TV by doing some step-by-step guidance provided by the experienced people here. By the way, last year I purchased an online course but didn't know it was incomplete (and the instructor never responded about that, though), so I'm hoping to learn more here with your help than with that course.
    Thanks in advance!
    Alex.
  • EazyBone
    • Jun 2023
    • 1437
    • United states
    • Anything I can do with my hands
    Means the panel is shorted. TV is dead
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8756
      Someone already modded this turkey with a separate buck / boost converter. Maybe it is dead or something wrong with the input voltage?
      • eltechno
        Samsung LC49G95TSSNXZA — black screen loop after sleep / standby — T-Con BN41-02934A — NTC thermistor location needed
        by eltechno
        TITLE: Samsung LC49G95TSSNXZA — black screen loop after sleep/standby — T-Con BN41-02934A — NTC thermistor location needed
        MONITOR SPECS:
        - Model: LC49G95TSSNXZA (USA / North America)
        - Serial: CX8MH4ZR802493K
        - Firmware: M-T9549GGAA-1015.2
        - T-Con board: BN41-02934A
        - Board project: OSCAR_T_TCON_MNT
        - Board date: 2021-04-16
        - T-Con IC: Samsung DNIE SDP74813 VER.01 NBVGW S2115
        SYMPTOM:
        The monitor enters sleep/standby mode normally and then fails to wake up. The screen stays black with no OSD, no signal indicator,...
        05-16-2026, 12:36 PM
      • Takeatry
        Yet another Samsung QLED Boot Loop
        by Takeatry
        Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
        10-04-2024, 02:57 PM
      • Boardview and Schematic Bot
        09-07-2024, 05:50 AM
      • shlomim412
        samsung ua55es6800 - no image
        by shlomim412
        hi
        having problem with samsung ua55es6800
        tv had backlight on, sound working - responds to the remote control but no image.
        check tcon board - had 12v in but no other voltages present.
        when disconnected left ribbon cable - got back voltages and half image with lines and distorsion
        when leaving only left side connected - again no voltages and no image.
        put a tape on all (cd?! lines) on the left ribbon cable and got complete but distorted image (horizontal lines).
        kept trying to block less pins on the left ribbon cable...
        05-15-2024, 05:00 AM
      • ChristianBr01
        LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
        by ChristianBr01
        I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
        The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
        What I already found is that the 12.8V are not an the connector to the main board connector to the power...
        04-23-2025, 01:48 AM
