Panisonic TH-42PZ800b six blink fault
    Re: Panisonic TH-42PZ800b six blink fault
    Probably not - the power supply does not use fuses on the Vsus portion - so that would not be a likely cause.
    • Paniman
      • Oct 2014
      • 21
      I have checked over the board for any visual burning and none found
      I have checked all the caps in circuit with a meter they seem ok I have checked the MOSFETs on the heat sinks they all seem ok with a multimeter
      That's where my electronic testing skills end
      Any specific places on the board that anyone thinks might cause my problem
      Right now I am thinking take the risk and buy the boards that sordids has
      I just surprised that the loud pop does not show black or burning
      • sordids999
        • May 2013
        • 2161
        update : sent him TNPA4410 TNPA4412 TNPA4413 TNPA4411 he fitted two days ago tv now working
          Good to hear. Rare fault on these!
          • howardc64
            Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
            by howardc64
            • Prior owner tried a replacement main board. No difference.
            • Samsung 2x red blinking standby LED = panel fault
            • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
            • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
            • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
            07-19-2025, 10:54 PM
          • Rictech
            Panasonic SA-MAX770PU SMPSU board fault....
            by Rictech
            Hello everyone. 😀
            As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
            Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
            Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
            This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
            There are no devices that have exploded or otherwise show signs...
            08-26-2024, 01:05 AM
          • Vebririon
            panasonic TX-P50V10E 6 blink led problem
            by Vebririon
            I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
            Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
            I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
            05-17-2025, 10:16 AM
            ESR meter came to the rescue again today with a PLC I/O card fault
            by sam_sam_sam
            I have been having a fun time at work with two pieces of equipment that had shorted components or shorted component cables to machine frame
            I would check what my multi meter was telling me about how many ohms I getting with the multi meter was telling versus the ESR was telling me about weather or not it really was a short to machine ground or not
            One note at first we thought that it might be a bad I/O card or a malfunction PLC including me as well but I thought I would try and see if removing the I/O cables would make a difference or not and this time it did make a difference...
            12-18-2023, 08:17 PM
          • reessi
            ACER BM320 Monitor - Horizonal Flickering Lines After a While
            by reessi
            The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
            They are black on the right and gradually fade to nothing on the far left.
            They start either after 5 mins or up to 2 hours after so annoying for testing.
            They flicker continuously very fast! With a slight pause milli-second every second.
            Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
            I tested each half by removing the first the left flex from...
            06-03-2025, 09:58 AM
