AS-19 Gamma Chip on T-Con
  • kevinm34232
    • May 2012
    • 1884
    Has anyone had success removing these easily, I just spent about an hour trying to get one off, flux, heating the bottom, the top, sides, repeat, repeat, applying slight pressure in corner... nothing..
    Finally got a sharp razor knife and stuck in under in the corner, heated, pryed, heated, pryed, finally it popped off in the air. 3 traces damaged though.
  • kasfamily
    • Aug 2014
    • 765
    • Russia
    Re: AS-19 Gamma Chip on T-Con
    Here beautifully soldering http://www.youtube.com/watch?v=ezYcYF94_k4
    • flocko
      • Nov 2012
      • 1121
      ChipQuik? Flocko
      • kevinm34232
        • May 2012
        • 1884
        This chip is soldered underneath also, that's what makes it difficult, and for some reason more difficult than others.
          You need a hot air gun. It is still possible to remove these parts with a soldering iron but you risk damage to the board
          • kevinm34232
            • May 2012
            • 1884
            I have one, and I heated both the top and bottom of the boards for a long time, the board was super hot but it still wouldn't come off easily.
            • kevinm34232
              • May 2012
              • 1884
              I feel like next time drilling a hole thru the top of the chip to expose the metal pad on the bottom of the IC just to get heat directly on it.
                Sounds difficult to do. Your hot air gun is probably faulty, as mine will remove AS15/AS19 in about 30 seconds of heating at 390C.
                • kevinm34232
                  • May 2012
                  • 1884
                  Maybe I'm using too low of heat I started lower, and finished around 350C.
                  • ecking767
                    • Oct 2009
                    • 492
                    I had a HDMI chip where it wasn't coming off the board so easy, So I had to drill the top of the IC chip exposing the metal plate on the bottom of this chip. I didn't drill thru the chip, just the top surface so that the metal plate is exposed, then it came off using my hot air gun.
                    • Alastair E
                      Chief Womble
                      • Mar 2013
                      • 1963
                      • U.K.
                      Well--Here's my redneck way of doing 'em....
                      Cut all pins off with stanley-knife--Carefully.
                      Then remove the pins from the board by solder/braid.
                      Then take stanley-blade and wedge under one corner and usually the top of the IC case will pop off leaving the die and the chip.
                      Flood this with solder and a hot iron, the stump/core will then come off.
                      Clean up- and bung a new one on.
                      TELEFIX
                      • zomi
                        • Nov 2011
                        • 505
                        dremel tool the legs
                        then desolder if you have issues
