Panasonic TH-42PZ85E --> Completely dead!
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    #81
    Re: Panasonic TH-42PZ85E --> Completely dead!
    When i ground the cable to the speaker housing the picture on scope is the same
      Needs to be grounded to the chassis.... Fan mounts work well I've found
      • Moreno83
        • Jun 2014
        • 2008
        • The Netherlands
        #83
        So what do you think of the pictures?
          If you see that, you haven't got a good ground.
          • Moreno83
            • Jun 2014
            • 2008
            • The Netherlands
            #85
            The 3rd picture is the default setting when scope is on. LAst pic is when i put the probe to pin 11/12/13
            • Moreno83
              • Jun 2014
              • 2008
              • The Netherlands
              #86
              Your right, pin 11/13 the line is horizontal but 1 square higher.
              On pin 12 its default horizontal line
                Is it on 5V/div or 1V/div?
                For 1V/div you may need to move the trace down a little using the V POS control.
                You should now check AC DET signal, MC501.
                • Moreno83
                  • Jun 2014
                  • 2008
                  • The Netherlands
                  #88
                  Its on 5v/div. I took a picture of the setting so you can see by yourself.
                  First picture of the scope setting is on 1V/div
                  Then you asked me to change it to 5 and thats the last picture. The horizontal line is going 1 square upwards. ( Means 5v right? )
                  How do i test AC DET signal? Where do i put the probe?
                  • Moreno83
                    • Jun 2014
                    • 2008
                    • The Netherlands
                    #89
                    Again 2 pictures.
                    First is pin 12
                    Second is pin 11/13
                    If i change the time/div it just slows down the signal ( visually).
                    Vpos is set to the middle.
                      AC_DET is on pin 16 of MC501... look at the schematic...
                      • Moreno83
                        • Jun 2014
                        • 2008
                        • The Netherlands
                        #91
                        I searched for ac det but i did not find it sorry.
                        With pin 16 i get this on the scope
                          Ok, this means the AC detection is working... So... this is where I draw a blank. Did you try bridging MC552 standby switch?
                          • Moreno83
                            • Jun 2014
                            • 2008
                            • The Netherlands
                            #93
                            Ok thats good. Not yet , was thinking i did it all wrong but I'm glad i did it right
                            Does it matter if its pin 11 or 13?
                            • Moreno83
                              • Jun 2014
                              • 2008
                              • The Netherlands
                              #94
                              Btw , scope is a good way to measure! I'm really surprised!! What do you see at the last picture? Its starting at 5v dropping to 0v?
                              So if I'm correct its just a way to measure if the DC line is working throughout the PS?
                              • Moreno83
                                • Jun 2014
                                • 2008
                                • The Netherlands
                                #95
                                Ill start with Pin 11 , standby on.
                                • Moreno83
                                  • Jun 2014
                                  • 2008
                                  • The Netherlands
                                  #96
                                  Pin 11 bridged to P25/Pin 9 did not do anything.
                                  Pin 13 bridged to P25/pin 9 does not turn on the TV but there is something happening.
                                  I used the multimeter to test the 5V STB on diode. ( Pins were connected the whole time ).
                                  I bridged pin 13 to pin 9 and the 5V dropped to 0.8v and i hear something ticking real soft , sounds like a old clock that you wind up. ( tickticktickticktick ).
                                  No power/clicks/led!
                                    Sounds almost like the 5VSB may be shorted on the main board... That would be odd...
                                    Maybe try powering 5VSB from a lab power supply separately?
                                    • Moreno83
                                      • Jun 2014
                                      • 2008
                                      • The Netherlands
                                      #98
                                      5v STB on P25/Pin9 or Pin12 on MC501 or directly on main board? So your now thinking power supply is ok?
                                        I don't know, I'm just brainstorming right now.
                                        Try keeping power board disconnected, just feed in 5V, and set a 1 amp current limit.
                                        • Moreno83
                                          • Jun 2014
                                          • 2008
                                          • The Netherlands
                                          #100
                                          Ok will do that tomorrow.
                                          Thx , and if you have any idea's let me know!
                                          • max-power
                                            Dell E6540 laptop completely dead after dssasembly
                                            by max-power
                                            Hi, I disassemble my laptop to replace the speakers, to access them, you have to remove everything including the heat sink and fan, unscrew the motherboard, lift it up a bit to access the speaker wire.
                                            that was not the first time I dissasemble it, i did replace the same speaker a few year ago and I repaste it last year, so I had nothing to worry about. but when I put everything back together, its completely dead.
                                            After a bit of investigating, i found one pin of the status led ribbon cable that was unglued from the cable and bend touching another pin, I bend it back at his place...
                                            03-24-2025, 08:49 AM
                                          • wangbreeze
                                            T480s random shutoff and then completely dead
                                            by wangbreeze
                                            Hello Gurus,
                                            I got a ThinkPad T480s. It was running fine but suddenly started random shut down. When it turned off, I had to push the reset pin to bring it back to life. But it got aggressively worse and became completely dead. No charging light, no life.
                                            I did some initial diagnostics with just the board (no battery, nothing attached, and no CMOS battery as well)
                                            Initial testing of the coil resistance seems to indicate no dead short. The only low resistance I measured was at PL701. It reads 38 ohms.
                                            charger gave - 20V - ok
                                            U101B
                                            02-03-2024, 04:57 PM
                                          • pavski
                                            Completely dead MSI z490 tomahawk
                                            by pavski
                                            Trying to troubleshoot MSI z490 tomahawk board and would appreciate your help. The board is completely dead and shows no activity when the power button is pressed.
                                            I have tried to look at the Superio, the PSIN signal seems to be correct (goes from 3.3V to 0 on button press) but the voltage on PSOUT pin is quite low. I
                                            t is only 0.8V which seems to be incorrect but goes to 0 when the button is pressed.
                                            Can you please let me know if this is indeed incorrect and what else should I look at next?
                                            Thanks!
                                            06-02-2024, 02:42 PM
                                            HP EliteBook x360 1030 G4 + Casio G-SHOCK Hybrid (2-in-1) Specification for Upgrade or Repair
                                            This specification for the HP EliteBook x360 1030 G4 + Casio G-SHOCK Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1030 G4 + Casio G-SHOCK boardview and 1030 G4 + Casio G-SHOCK schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            09-06-2024, 11:39 AM
                                            HP EliteBook x360 1030 G3 + Casio G-SHOCK Hybrid (2-in-1) Specification for Upgrade or Repair
                                            This specification for the HP EliteBook x360 1030 G3 + Casio G-SHOCK Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1030 G3 + Casio G-SHOCK boardview and 1030 G3 + Casio G-SHOCK schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            09-06-2024, 09:53 AM
